Question about HP Color LaserJet 8550dn Printer
How to clean a density sensor unit on a hp color laserjet 8550
My print hp laserjet 8550 is displaying ' clean density sensor, please can you explain to me how to clean it. thank you
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 121 Answers
1 Open the right upper door.
Sensor is located on the door lower center of door ther should be a small brush next to it
2 Use the brush located next to the sensor to remove all toner
particles from the sensor.
Posted on Mar 04, 2009
I had a problem my color laserjet printer 8500dn that is asking to clean density sensor I don't no how to do it please help
Hi Elias, The link below is a user manual for a color laser jet 8500, 8500n, 8500dn, I had a look and the answer to your question (Clean density sensor) is on page 155 (To clean the density sensor
1 Open the upper right door.
2 Use the brush located next to the sensor to remove all toner particles from the sensor)..... This WILL Help...CHEERS..
http://h20566.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c00656644
Mar 30, 2016 | Office Equipment & Supplies
How to fix sensor error on hp color laserjet 2600
54.06
Error message
54.06
Description
Color density sensor error
Action
  1. Power cycle the printer.
  2. Calibrate the printer. Click here to view the document "HP Color LaserJet 2600n - Calibrating the printer" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314525).
  3. Change the Print Density settings through the HP Toolbox. Click here to view the document " HP Color LaserJet 2600n Printer - Change Device Print Settings in HP Toolbox" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00310627).
  4. If the problem continues, contact HP Customer Support Center for technical assistance athttp://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Apr 02, 2014 | HP Color LaserJet 2600n Printer
HP Color Laserjet 8550 - Loud grinding noise near fuser
Hi Harden,
Thats an issue with the fuser assembly,try to check the teflon condition/ teeth gear might have worn out.
Jan 30, 2014 | HP Color LaserJet 8550dn Printer
Very light print out of hp p1505 laser printer is cery light even after changing tonner and cleaning scaning unit.
This could be color miss registry, even though your printer is a monochrome printer there is a sensor which determines the color density, Black being a color, and if the sensor is damaged will cause issues like fading. Make sure you are using hp original cartridges, and if the problem is still there, contact hp for warranty options, hp's tech support line is 1800-334-51440.
Al
Eliteprintersolutions@gmail.com
Jul 11, 2010 | HP LaserJet P1505n Printer
WHAT IS DENSITY SENSOR IN LASERJET 8500
The Density Sensor is located inside the right upper door and senses the colour calibration pattern for each colour formed on the transfer drum during a calibration cycle. Press GO. Print a configuration page and then troubleshoot as an Image-quality problem as instructed in the user manual. Check the transfer guide for cracks and replace if necessary. Check the event log for errors numbered 54.00.0<X> the X indicates, 5-sensor abnormality, 4-Cyan, 3-Magenta, 2-Yellow, 1-Black. The last 3 error codes should be seen on the Configuration page.
Dec 29, 2009 | HP LaserJet 8500 Color Printer
8550dn printer showing out of memory message? Is there a way to clear this without having to do all the resets? Or just how to clear the message?
If the error is '20.00 Insufficient Memory'
No action required. It is simply out of memory because the file you printed was too big.
If you keep getting the message, simpify the print job and/or add more memory to the device.
You could also..
Change the setting in the <Configuration Menu>, <Clearable Warnings>, from 'On', to "Job'.
This will get rid of the message a bit quicker.
Dec 08, 2009 | HP Color LaserJet 8550dn Printer
HP 8550 not printing
Disconnect your network cable and printer's hard drive and then power on. Its possible there is a stuck job somewhere.
If that doesn't work, believe or not it could be the fuser.
Jun 02, 2009 | HP Color LaserJet 8550 Printer
Density sensor out of range
CLEAN THE DENSITY SENSORS POINTING AT THE TOP OF THE TRANSFER BELT. A COLD RESET CAN HELP TOO
Jan 20, 2008 | HP Color LaserJet 3500 Printer
HP Color LaserJet 8550dn Printer Logo
3,543 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
