Question about Canon Pixma MP500 All-In-One InkJet Printer
Canon mx310 I refilled a empty printer cartridge pg40 black and cl41 color now the printer shows a message low on ink it does print but it is unable to recieve faxs as it says low on ink. Pls help
  • Canon Master
  • 19,396 Answers
Canon cartridges have an intelligent chipset to prevent them from being refilled. To have them working properly you need to reset the chipset.
Try the software on this link.
If the above did not work you will need to use a cartridge chip resetter if you want to refill your cartridge.
Posted on Jun 06, 2008
I do not have manual and do not know how to install ink cartridges
With pluging the power cord,
1. Facing the printer, you can lift up the door..(front cover of printer)
2. The cartridge slot will be centered.
3. Insert the cartridge to proper slots.. (will c the sign for color & black slots)
You must be using PG40, CL41 for your printer.
To save your $$, check out my youtube video for your $$ saving..
Very easy to refill your cartridge!!!!
http://www.youtube.com/watch?v=ubmHgAtHUds&feature=related
Aug 03, 2011 | Canon PIXMA iP1600 Printer
I have changed the colour ink on my canon mp460 but it still say empty
CL41, this is the one you are using for your cartridge.
Did you change your cartridge with brand new one or refilled one??
If you did with refilled one, the ink level won't go back with full.
This is the method how printer measures the ink level.
1. Each cartridge has a serial number.
2. As soon as installation in printer, printer recognizes the cartridge by serial #.
3. And the printer starts to count the printing document.
4. After reaching certain print counting, the ink level will show "low ink"
So my answer is even if you refilled your cartridge, the ink level won't change,
since printer cannot weight the cartridge or.....some other technology to measure each color ink level.
Thanks.
Jun 15, 2011 | Canon PIXMA MP460 All-In-One InkJet...
I am trying to scan a document, however the black ink is empty. It only shows the error message that I should refill my ink. Shouldn't I still be able to scan documents?
Must be using PG830 or PG40 50?
For Canon, if either color or black cartridge is empty or out of ink, "Scanner" doesn't work.
That's why your scanner is not properly working.
It's all connected... That's Canon.
Are you refill your cartridge by yourself?
Try "ROADINK" inkjet refill kit. No drill or sharp needles are needed.
It's not only easy to refill, you can have quality printing.
Check out my youtube video, will find how easy refill can be done.
Apr 20, 2011 | Canon MP490 InkJet Printer
Just replaced ink cartridge and still says cjeck ink and it will not print
did you get a brand name canon pg40 or pg 50 ink cartridge, i replaced the one at works black cartridge with an eco refilled cartridge and it still showed up empty even though i know it wasn't. its canons way of making sure you buy canon. there are ways around it though. hit menu navigate to "rx settings" hit okay then hit okay on "autoprint rx" make sure it is set to on and hit okay, then make sure "print when no ink" is also set to on and hit okay again. it will now automatically print even if the machine thinks there is little or no ink. cheaper knock off cartridges here we come!
Dec 12, 2010 | Canon PIXMA MX310 All-In-One Printer
Canon mx310 how to print color document in black
When you go to save it or just before that you select file then go to print properties under that there should be a selection to print it in black and white.
Let us know ether way but its done under printer properties.
Thanks and please do be considerate that we are trying to help when you leave your positive ratings and feedback, thanks
May 26, 2010 | Canon PIXMA MX310 All-In-One Printer
Refurb. Ink cartridge problems
Make certain that the labels on the cartridges are in the right postion. For instance the PG40 label should be near the two lugs at the top and NOT near the curved lug. It seems that the chip is near the curved lug maybe in the circular indent.
Feb 18, 2009 | Canon PIXMA MX310 All-In-One Printer
How to reset ink level warning when refilling?
EASY!!!!: push the cancel button by 6 seconds, this deactivate the ink level sensor.
Dec 15, 2008 | Canon PIXMA MP470 All-in-One Printer
Reset Ink levels for canon mx310
How to reset Canon MX310 printer low ink signal
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset! Enjoy.
Jul 29, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
To Reset the Canon Cartridges Works 100%
Hold the stop/reset button then press and hold power (for 5 secs)
Hold Power and release the stop/reset button
Press the stop/reset button twice
Relase power button
Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
On the 3rd press the inicator should be orange.
Press the power button to set data
To set data remove cartridges then replace.
leave for 20 or 30 secs
Press the power button again to shut down
Then press power button to power up.
The printer will feed one piece of paper through
then set language and counrty.
Then ink should be reset
Any problems contact me on charmed_halliwell@hotmail.co.uk
Jan 31, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon Pixma MP500 All-In-One InkJet Printer Logo
354 people viewed this question
old marine
old marine
