AKIRA DPS-6702TV I have this product which I just bought quite sometime, like 2 months ago. Then one day I use it to watch DVD movies non stop for 8-10 hours after that all of a sudden when I put the DVD movie in it always said "NO DISC" I tried to leave it 1-2 hours as I thought it might be overheated however I leave it for 1 long day and the outcome still the same..May know what is the cause of it and is there any solution on how to rectify the problem? Thanks
SOURCE: can't read the disc !!
I replayced dvd cd-rom myself it's very simple repair and it cost me $20.00 for new dvd rom. Don't buy CD-RW but just simple black dvd-rom.
I hope this will get you going again.
Posted on Mar 27, 2008
SOURCE: Stops Playing: screen freezes
My friend suggested I clean the dvd optical reader lens inside the player with a fine brush (like a camera brush with a blower bulb). This seemed to help immensely. I'm not certain if this is just a temporary fix, but it seems to be ok so far.
Posted on Jun 23, 2008
  • 4 Answers
SOURCE: go video dvd recorder vhs combo vr3845 - won't read discs - says unknown disc
FIRST UNPLUG THE UNIT FROM POWER !!!!! The problem is dirt/dust/****/crud/stuff on the tiny, little ***** laser lens. Remove the case screws ( 2 on each side, some in the back) with a correct size driver. The cover must be pulled open at the bottom, side to side a tiny bit ( use a hand on each side) to allow the cover to lift up at the rear, it must come up quite a bit as if it is hinged at the front and THEN pulled back out of the front panel. Set the cover to the side. The DVD reader/Burner is covered with a small black cover, it is held on with two TINY screws, STOP!!!! Get yourself the CORRECT size driver at Fry's or Radio Shack, DO NOT get cheap here!!! Remove the two screws and find the two plastic grip tabs, push them to release and lift the cover. There is the laser! It is a tiny blue lens about the same diameter as the tiny screws. find a very, very well washed CLEAN 100% cotton T-shirt. The softer the better, get 70% or higher rubbing alcohol, pull the fabric over the tip of the finger and wet with the alcohol. VERY GENTLY wipe the lens 4 to 5 wipes and the 3 wipes with a dry spot. That should clean the lens. USE NOTHING ELSE!!!!!! The lens tracks back and forth on two tiny bars. The stuff I use is WD-40 wet on a Q-tip swab. Go to a safe place to spray the WD-40 on the Q-tip. The lube should drip. With the Q-tip apply the lube to the tiny bars at the ponts of rider contacts and wipe the bars too. Put the top of the burner back> BE CAREFUL!! Use a magnet driver and then repower and try to read a known good dvd. You will have to do this more in the future, you understand, dist dirt etc in the air. Put the top back on. Enjoy.
Posted on Sep 26, 2008
SOURCE: LAPTOP DVD DRIVE WONT PLAY DVDS
i have just recently updated windows and its took my drive out again, comes up with Windows cannot load the device driver for this hardware because a previous instance of the device driver is still in memory. (Code 38)
Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available.
HELP
Posted on Sep 30, 2008
SOURCE: Samsung HT-Z410: ''Disc Error''
It's not the lens. It's the bottom plate on the disk pickup. Dust gets on the rubber pieces (there are three oval shaped pads) that do not adhere properly to the disk which causes the disk to turn too slowly for the lens to read it properly. Clean those off with alcohol swabs and let dry. Also blow off all the dust in the unit since it will already be open. I have also decided to leave a disk in the player so that dust will not have a chance to get on those bumpers again. I did this last weekend and have not had problems since.
Posted on Dec 19, 2009
My Panasonic DMP-BD655 won't read any discs. I was fine a month ago but hen it wouldn't read Blu-Ray discs, but would still play DVD's. It stopped playing DVD's about 3 days ago. I have upgraded the...
Ive only had mine for 2 months and it just stopped playing dvds all together. I had a brand new dvd playing, went to switch it to another new dvd movie and it wouldnt read it or any other dvd Ive tried. I havent tried a blu ray disc yet.
Jan 02, 2011 | Panasonic DMP-BD30K Blu-Ray Player
I bought a Samsung BD-C6500 to play MKV movies, it does, but the player stops right in the middle of the movie, so I have finish watching on my computer. Any solution ?
It sometimes does it on certain Mkv movies you will notice it will be the ones you cannot fast forward ,it does it on 2 of the other players try it from the begging
Oct 30, 2010 | Samsung BDC6500 BluRay Player
Nextplay dvd player loading but not reading disc
my nextplay dvd player turns on, whirs, says it is loading but never loads. Then when I push stop, it doesn't stop either. Any ideas?
Jun 04, 2009 | Televison & Video
Blue Screen (NO EBRAKE Message) Ebrake code entered and worked
hook your green/white camera override wire to your parking wire that should solve your problem
Feb 20, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
REMOTE
Try going to www.remotes.com you may very well be able to order an orignal remote for your product! and in some cases they will tell you how to revive the old remote!
Please rate my response!
THANK YOU!
Jan 12, 2009 | Memorex MVD4540 DVD Player/VCR
DVD Player is not playing DVDs
Try to take it for remend, or you can get a dvd copy software to copy dvd to your computer so you can share or watch movie on pc when your dvd player is damaged.
Jul 07, 2008 | Computers & Internet
DVD quits while watching a movie
Have you tried cleaning your lens?
If so your dvd drive may be going bad
Apr 08, 2008 | Bose (321GS) System
Televison & Video Logo
121 people viewed this question
Top Televison & Video Experts
Electro Med Services...
