Question about Microsoft Xbox 360 Console
How so you fix the red light ring?
When I turn on my Xbox 360, a red light starts flashing and nothing shows up on the screen.
  • 94 Answers
It the red light os death and ill tell u how to fix it .........unplug everything but the power cord....turn it on and rap it up in 3 or 4 towles yes i no it sound weird but do it anyway make sure its raped up all around with 3 or 4 towels and leave it for 25min no longer.......after 25min is up unrap it shut it of and let it cool for 15min....what u just did is over heat the chips in your 360 and it reset theme...so after 15min turn it on and there u go it works post me back when u do it tks
Posted on Jun 06, 2008
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Red ring
hi there,
your xbox 360 need service open it and remove all dust around the fan and prosseser every thing fine again.
Jul 11, 2010 | Microsoft Xbox 360 Console
Flashing red light on the bottom right of the ring and an error code 73 picture on the screen
Hi,Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
This solution will fix your problem for sure. Thank you!
May 12, 2010 | Microsoft Xbox 360 Console
Lower right red light flashes, the TV is showing nothing, just a black screen. Is this serious
if the red light is flashing on your xbox u need to contact the suppiler and they will help you to send it to microsoft to be repair.it should only cost you to send it .or ring mircosoft and the will help you sort it out.my mates one did the same thing and they fixed it no charge, only for sending it to them .its a knowin pro with xbox.
Nov 03, 2009 | Microsoft Xbox 360 Console
Xbox360 power cycles by itself
do any lights flash etc, if so check below;
Two red indicator lights flash on the Ring of Light, or no lights flash on the Ring of Light. uparrow.gifBack to the top CAUSEThis may happen in the following situations: The auto-off setting is turned on,... loadTOCNode(1, 'cause'); This may happen in the following situations:
  • The auto-off setting is turned on, and the console has been inactive for six hours.
  • The console is too hot.
  • There is a problem with the power supply.
uparrow.gifBack to the top THINGS TO TRYTo identify and fix the problem, follow these steps:To begin troubleshooting thi... loadTOCNode(1, 'whattotry'); To identify and fix the problem, follow these steps:
  1. To begin troubleshooting this problem, check if the auto-off feature is turned on. To check if the auto-off feature is turned on, follow these steps:
    1. Start the Xbox 360 console without a disc in the disc tray.
    2. In the System section of the Xbox 360 Dashboard, select Console Settings.
    3. In the Console Settings area, select Auto-Off.
    4. Examine the option to see if it set for auto-off. If it is set for auto-off, change your selection.
  2. If the auto-off feature is not turned on and this is the first time the Xbox 360 console has turned off unexpectedly, let's do a simple test before we continue troubleshooting.
    To do this test, turn the Xbox 360 off for about 10 minutes. Then turn the console on and see if the problem occurs again. If the Xbox 360 console turns off unexpectedly again, make a note of how long the Xbox 360 console is on before the console turns off automatically.
  3. If the auto-off feature is turned off but the problem happens again, check the appearance of the Ring of Light to determine what to do next.
    • The two lights in the left quadrant of the Ring of Light flash red: The internal temperature of the Xbox 360 console may be too high. In this case, turn off the Xbox 360 console, and let it cool down. It may take several hours for the console to cool enough.
      Also, make sure that the ventilation openings on the console are not blocked. (For example, the ventilation openings may be blocked if you place the Xbox 360 console on a soft surface, like a bed or a sofa.) Also make sure that the console is not located in a poorly-ventilated place, such as an enclosed bookcase or stereo cabinet. For more information about what to do if the two red lights in the left quadrant on the Ring of Light flash red, click the following article number to view the article in the Microsoft Knowledge Base: 907533 (http://support.microsoft.com/kb/907533/ ) Two of the lights on the Ring of Light on the front of your Xbox 360 console flash red
    • No lights are flashing on the Ring of Light: In this case, we should check the lights on the Xbox 360 power supply for hints on how to fix the problem. A green light indicates that the power supply is correctly functioning.
      For more information about the power supply light, click the following article numbers to view the articles in the Microsoft Knowledge Base: 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red
Jul 31, 2009 | Microsoft Xbox 360 Console
Black screen with white dots moving around everywhere
It is possible to open your Xbox 360 and fix the problem, which isn't recommended, but there are many tutorials, but if it is not 3 red lights then you don't have the Red Ring of Death. If the whole ring around the Xbox 360 is red then this means that either the Audio-Video cable is not connected properly, or the Xbox 360 is not detecting it. You can try cleaning the AV cable or you could try buying a new AV cable. The easiest way to decide on what you should do is go to:
http://support.microsoft.com/default.aspx/kb/906652
That is the specific page for your problem and should give you a solution, and if it does not, then you should be able to contact Microsoft, and if it is still under manufacturer's warranty, then they should be able to fix it for free.
I hope I helped! ~Flascher
Jul 16, 2009 | Microsoft Xbox 360 Console
2 red rings or lights on my xbox 360 after i tried fixing RROD
ok u need to leave it on for about 30 min. (u only need power cord in) when ur done with that, put it together and it should work for me.
Mar 12, 2009 | Microsoft Xbox 360 Console
X Box 360
It might be Red ring of Death problem, You can either send your Xbox toMicrosoft and wait for 2-3 weeks till you get back your Xbox or you canfix the problem yourself with the help of a DIY fix guide.
Check out the post discussing about RROD problem here: http://www.fix-xbox360.info/2008/08/23/xbox-360-red-light-fix/
Hope it helps...
Jan 05, 2009 | Microsoft Xbox 360 Console
Xbox360 and the 3 red lights
Three of the lights on the Ring of Light on the front of your Xbox 360 console flash red View products that this article applies to. if (!loadTOCNode) {var loadTOCNode = function(){}} Expand all | Collapse all if (kb_page_object) { kb_page_object.kb_imageExpandHoverText = 'Click to expand this image'; } SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Dec 06, 2008 | Video Game Consoles & Games
Xbox 360 red lights
2 red lights flashing is'nt too bad of a deal. just reposition your xbox 360 to a place where more airflow can get to it. plus, dont have anything that gives off heat near the xbox 360, thats vary important to give it room for cool air. it worked for me
Nov 15, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
