Question about Motorola Mobility HS850 Consumer Headset
My HS850 worn't hold a charge.
Is there a battery to replace and how do you replace it?
  • Anonymous Jun 14, 2008
    how do you install to phone
  • mfred43 Jul 10, 2008
    Used this headset for a few weeks. I had it sit around for about a month and now it won't charge.
NO YOU CAN NOT REPLACE THE BATTERY AS IT IS INTERNAL WHEN THE BATTERY IS GONE YOU HAVE TO BUY A NEW HEADSET UNLESS YOU ARE STILL IN THE 1ST YEAR YOU CAN SEND IT TO MOTOROLA FOR WARRENTY. IT SUCKS SO I OPTED TO TELL MOTOROLA THAT IF I HAD KNOW THIS I WOULD OF NEVER BOUGHT THE HEADSET FOR $120.00 AT THE TIME. THE DID A ONE TIME EXCHANGE FOR ANOTHER HEADSET AS I AM A LONG TIME CELL PHONE CUSTOMER. I TOLD THEM I DID NOT WANT THE SAME HEADSET SO THEY EXCHANGED FOR THE OLDER VERSION HEADSET THAT USSES ONE ENERGIZER AAA. WHICH LASTS FOR 30 HOURS TALK TIME OR 30 DAYS STANDBY. WHICH I FEAL IS WELL WORTH THE 1 ENERGIZER AAA BATTERY. MOTOROLA MAILED ME A BLUETOOTH HEADSET H300. WHICH I THOUGHT WAS NICE OF THEM. BUT I ASTILL THINK THEY NEED TO MAKE PEOPLE AWARE THAT THERE BLUETOOTH HEADSETS THAT THE BATTERYS CAN'T BE REPLACED. HOPE THIS HELPS
Posted on Jul 13, 2008
Testimonial: "This is a great reply. It gave me my anwser plus ideas of what to do. Thanks FixYa."
Need help with charging. my plantronics c054 does not hold a charge
If it will not hold a charge then the battery pack is worn out/defective and you must replace it. You can find the number on the battery and get them on eBay.
Jun 08, 2017 | Plantronics Radio Communications
Need instructions for connecting ear piece to iphone 4
Hi,to complete the look of a tech-savvy, iPhone-using individual, you must have a Bluetooth headset to accompany it. You can pair any Bluetooth headset with an iPhone. The Motorola HS850 is no exception to this. Both Motorola and Apple's Bluetooth set-up process is fast, so you'll be talking with people through your new Bluetooth on your iPhone in a matter of minutes.
Instructions
Charge the Motorola HS850 headset fully before attempting to pair. Usually, it takes two to three hours to charge the headset.
Press and hold the "Call" button (has a phone icon on it) on the headset for six to 10 seconds. The outside LED light will turn on indicating that the phone is in pairing mode.
Choose "Settings" on the iPhone homescreen.
Select "General," then "Bluetooth."
Select to turn Bluetooth on.
Wait for the phone to search for in-range devices.
Select theMotorola HS850 from the list of devices.
Enter the headset passkey to complete the pairing. By default this is "0000."
Have a nice day..
Feb 23, 2011 | Motorola Mobility HS850 Consumer Headset
My hs850
Press and hold your power button for about 10 seconds, unitl the blue light starts flashing. Most people just push the button and think it will turn on, but you must hold it for a while and it will turn on.
Aug 15, 2008 | Motorola Mobility HS850 Consumer Headset
Hs850
I'm new to this site so I can only see your "I'm having the same problem" so I'll tell you what I know and hope that it answers what the question was.
Make sure your hs850 is charged. Close the boom, hold the multifunction button until the light turns on and open the boom while holding the button--then let go. if the light stays on you're in business, turn on the blue tooth setting of your phone on and search for new devices. then hit connect! ta-da!
Apr 22, 2008 | Motorola Mobility HS850 Consumer Headset
HS850
make sure the ac adapter isnt bad
Jan 19, 2008 | Motorola Mobility HS850 Consumer Headset
Moto bluetooth HS850 WON't turn ON!
I think your guess is right a new battery may be required but try leaving it on charge for 12hrs or so sometimes if they havn't been used for a long time they go dormant and it takes a realy good charge to get them going
Nov 08, 2007 | Motorola Mobility HS850 Consumer Headset
Constant BLue
go to bluetooth on ur phone and select Hs850 delete device. then hold multifunction button until blue then open boom search for new devices from thee cell.
Aug 09, 2007 | Motorola Mobility HS850 Consumer Headset
My headset does not hold its charge
Usually Lithium-Ion batteries have a Memory effect, ie. the battery should be 100% consumed then only recharged. If the battery is only 40% used and recharged then the battery will give you only 40% of it's total charge. The battery starts showing you empty after it is 40% consumed even it was 100% charged. Now there is solution for this-Drain battery upto full, store it in a cool place like Frigde then charge it full then again use it upto last. Repeat this procedure for 2-3 times.Your battery should come to normal state. Also check the charging current of the charger.The charger might also be faulty.
Apr 26, 2007 | Motorola Mobility HS850 Consumer Headset
HS850 charge doesn't last long
Sounds like you've got a defective model. Mine lasts about 4-5 days before I have to charge it.
Apr 10, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility HS850 Consumer Headset Logo
283 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
