Hello
Most error codes can be cleared by removing the paper jam and then rebooting the machine. When an error code occurs, make a note of the code and then follow the instructions on the control panel for clearing it.
Paper jams can be caused by a variety of issues in the copy machine, but jamming can commonly be caused by improperly loaded paper in the trays or dirty paper feed rollers.
If you get repeated paper jams, remove the paper from the trays and inspect the stack. Look for folded corners, especially on the bottom of the stack. Fan the paper thoroughly and then reload the stack into the tray. Check the paper guides to ensure they are not too tight or too loose. Both conditions can cause paper jams.
If you can see the paper transport rollers by opening the ordinary access covers and panels inside the machine, cleaning them might help reduce paper jams. Shut the machine off and unplug it, then take a soft, lint-free cloth dampened with water and wipe those rollers off. A buildup of toner and paper dust can cause them to slip while transporting the paper.
