Question about LG KS20 Smartphone
How 2 change the Alarm`s sound
I`m trying 2 change the Alarm`s sound, even i`ve convert the sound track into .wav file n it`s only 200+k only.. so, how 2 change the Alarm`s sound?
  • SilverSagi Jul 22, 2008
    LG K20: I cannot change the alarm tone to my own ringing tones (mp3/wav). I can do that for sms. How to set our alarm tone instead of using the defaul?
  • despoina Jan 25, 2009
    The only ringtone that I can change is for incoming calls. I can't change the rest of them (alarm, SMS, MMS,...). I've tried to find the root, so that I can copy my own file, but I don't know where it is. Thank you.
Just place a .wav file inside the Windows-folder on the root and problem solved.
Posted on Sep 30, 2008
  • Jiisuki Feb 19, 2009
    If you use the file explorer, you can go up until you can se the Windows directory. Root specifies the lowest branch in a tree hierarchy, like so:
    C:
     |------ Windows
     |            |-- System
     |------ Documents
    Where here C could be considered as the 'root'.
How do I transfer track data to computer?
Why you have to convert to mp3 ?. Did not the card can be removed and installed on the computer and then copied?
Where you convert the file? BR or computer?
What software you use to convert?
Mar 26, 2015 | Roland Boss Micro BR Multi Track Recorder
How to Online Convert MP3 file to WAV (Audio) file format?
The immigration attorneys Convert your audio like music to the WAV format with this free online WAV converter. Upload your audio file and the conversion will start immediately. You can also extract the audio track of a file to WAV if you upload a video. We are constantly improving our service. Right now we support over 20 input formats to convert to WAV. For example: MP3 to WAV, WMA to WAV, OGG to WAV, FLV to WAV, WMV to WAV and more. If you have a file that we can't convert to WAV please contact us so we can add another WAV converter.
Oct 09, 2012 | Audio Players & Recorders
Im trying to convert a QCP file to an MP3 file. I have a conversion program but it seems to be damaging the file, not full play time of the song/file and bad quality. how can I make this work?
Rename the file to .WAV (change the .QCP extension to .WAV) then you can either play the WAV file itself OR convert the WAV file (for free) with CDex.
Mar 02, 2011 | Computers & Internet
Having trouble transfering my wav files from computer to tascam ( dp 02) even from cd to tascam . so i am unable to use .help? i have transfered my mp3 audio files to wav and tried to drag and drop from...
I had the same problem too but I figured it out. First you have to make sure your wav file is converted to (MONO) as opposed to Stereo, (which is the default channel setting). The best thing to do is to download a converter program, in my case I downloaded AVS Converter program which all I did was upload the wav file switch it to Mono 1.0 and that was that!! The Cons: for this program it costs money to download for your own keeping. I also suggest Audacity program my computer wont let me download it but a co-worker of mine has it and he said it's free to download.
Feb 02, 2010 | Tascam Dp-02cf Digital 8-track Recorder
EZ Audio Converter does not export files to iTunes
I've had exactly the same problem, and so far no resolution from Ion. A small bit of good news: the .wav files are on the hard drive, although without any track info. At least on Vista, they are in username/AppData/Local/Temp. The files are name Temp0, Temp1, Temp 2, ...
You can use iTunes to add these files (File/add file) and then convert them to .mp3s, or whatever format you prefer. Or you could convert them first using the tool of your choice, such as Audiograbber.
This is inconvenient, but a lot better than re-ripping the vinyl after EZVinyl hangs.
Jul 25, 2009 | Numark PT01 Turntable
Making Midi Files for Importing to Tascam 2488
You should always work in wav format if possible because there is a loss of quality with mp3 which is a compression format in which bits are lost in order to compress the file size.
There are a number of wav editors available which will allow you to load a stereo wav and then save it as a mono wav. The free one I use is called Audacity.
When working with FL or Reason I will sometimes import files to the Tascam, or I will take the outputs from my PCs sound card and line them into the tacams inputs and record them live. I only tend to do this with programs (like synths) where I am using an external midi keyboard and can play live what I want to record.
With basic drum pattern tracks I'll usually create them on the PC, save as wav, convert to mono, and then import to a track on the Tascam.
hope this helps.
bd.
Jun 25, 2009 | Tascam 2488 Portastudio Multitrack...
16 bit 44.1khz monaural wav format files
I'll assume first that you have wav files on your PC that you'd like to import into your 2488 to use as percussion tracks.
You'll have to convert those files on the PC first into mono wav files. The 2488 can handle 16 or 24 bit so the bitrate shouldn't really be a problem. (It will also automatically truncate a larger bitrate down, but you should really dither the files rather than let them truncate... another topic).
You can use Audacity (free) to convert stereo wav files to mono wav (audacity will also dither for you).
Once your files are converted and saved on the PC, on the 2488 open the USB connection from the DISK menu. (This assumes you already have a usb cable connected between your PC and your 2488.) You will see a device appear on your filelist called HD_2488 or something like that with a drive letter. Copy your mono wav files into the WAV directory on the 2488 USB device.
Then on the 2488 press 'exit' to close the USB and from the WAV IN/OUT menu choose 'USB import'. You should see the WAV files listed. If those files are not mono waves you won't even see them listed. Select the file(s) and press enter to import. You'll be prompted to choose which track to import them to.
That's pretty much it.
bd.
Feb 20, 2009 | Tascam 2488 Portastudio Multitrack...
Audio file converter
<img style="visibility:hidden;width:0px;height:0px;" border=0 width=0 height=0 src="http://c.gigcount.com/wildfire/IMP/CXNID=2000002.0NXC/bT*xJmx*PTEzMTcyNzIxNjE3OTYmcHQ9MTMxNzI3MjI2NDI5NiZwPTE4MDMxJmQ9Jmc9MSZvPTAyZTdmYTM1ODBmYTQ2MDk4MWE5/M2RmMTlkYmIyMTM5.gif" /><embed src="http://assets.mixpod.com/swf/mp3/mp-dog.swf?myid=85817626&path=2011/09/28" quality="high" wmode="transparent" flashvars="mycolor=211c1e&mycolor2=3322AA&mycolor3=260000&autoplay=true&rand=1&f=4&vol=100&pat=0&grad=false" width="270" height="265" name="myflashfetish" salign="TL" type="application/x-shockwave-flash" pluginspage="http://www.macromedia.com/go/getflashplayer" border="0" style="visibility:visible;width:270px;height:265px;" /><br><a href="http://www.mixpod.com/playlist/85817626" target="_blank"><img src="http://assets.myflashfetish.com/images/get-tracks.gif" title="Get Music Tracks!" style="border-style:none;" alt="Music"></a><a href="http://www.mixpod.com" target="_blank"><img src="http://assets.mixpod.com/images/make-own.gif" title="Create A Playlist!" style="border-style:none;" alt="Playlist"></a><br /><a href="http://mixpod.com">Music</a> <a href="http://mixpod.com">Playlist</a> at <a href="http://mixpod.com">MixPod.com</a>
Dec 22, 2008 | Computers & Internet
Uploading files into projects
Most of the time you have to convert the wav files to another format Such as MP3 or WMP. there are converters available for this purpose online.Google audio converters. Maybe you will find one that you can afford . Or even find freeware.
Oct 28, 2008 | Zoom H4 Handy Recorder
LG KS20 Smartphone Logo
482 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
