Question about Nokia 6270 Cellular Phone
Nokia 6270 some butons do not work
I have a nokia 6270 but lately I have notices some of the buttons do not work properly and also when i turn the prwer on the display in delayed for few seconds (ie it does not come on immediately ). please help
    President:
  • 1,257 Answers
Yes its happen with nokia 6270 that after some time key pad do not work properly. so to solve this problem you should know how to open it.i too have the same and i opened it to work keypad normally.so if you want to open it take a knife and use any corner from top,just insert it and pull it up ,you will see it opening do the same for other corner ,when it is open use a cloth to clean the surface of the keypad .if you are unable to open it please take it to any mobile repairing shop..
for your second issue phone delaye when starting phone..
for this there are many reason ,
1st your mobile is filled with too many sms ,
2nd device memory is full.
3re memory card is of 1gb and it is full
so all this can make your mobile delay when starting .
Solution :
You can use settings > Restore factory setting .type security code and let it restart..
If still you see delay for few seconds
You can update your mobile firmware(software).
Just install nokia pc suite and than instal nokia software updater ,if you dont have nokia software updater you can download it from nokia website ..install nokia software updater .after that use your cable to connect mobile with computer .start nokia pc suite you will see a option "UPDATE PHONE SOFTWARE ".click on this and follow on screen instruction to update your mobile firmware with the latest firmware....this will definitely resolve the issue that you are facing and it your mobile will work faster than before as how my nokia 6270 working ................thanks
_____________________________________________________
Low feed backs hurt my ratings and I tried my level best to resolve the issue. so it will be highly appreciated if you provide your feedback..
Thanks for using fixya support..You have a wonderful day
Posted on Jun 06, 2008
    Problem Solver:
  • 10 Answers
Just clean the inner keypad with using eraser now keypad will work if it not work's then show a heat on keypad ic ........ the hanging fault would b caused due to viruse r memory ful ......... just type *#7370# then it ask u code enter 12345 set wil restart before restarting u'r mobile take it's backup
Posted on Oct 04, 2008
Restriction code for nokia 6270
Hello. You can get the accurate restriction code for your Nokia 6270 from Unlock Zone.com at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch on your Nokia 6270 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6270.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6270 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6270 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6270
SOURCE: MobileUnlockGuide.com
Aug 20, 2014 | Nokia 6270 Cellular Phone
I cannot set time and date of my nokia 6270. *#7370# doesnt work
try removing battery for 1 day and then put it back, I think that there is some problem with timer and phone has capacitor inside, so you need to wait until it discharge to reset clock
Jul 11, 2009 | Nokia 6270 Cellular Phone
Want to format nokia 6270
just go to menu >select settings > now select Restore Factory Settings.........that's only you can do to solve your problem because its a java based mobile and not a symbian based.. Well you can do one thing if you are getting problem with your mobile, install NOKIA PC SUITE into your computer now connect your mobile with the data cable and computer through usb port.After that start NOKIA PCSUITE and select option update phone software ,it will install the lates software/firmware for your mobil
Jun 15, 2009 | Nokia 6270 Cellular Phone
Nokia 6270 Display Light
check your backlight settings
May 05, 2009 | Nokia 6270 Cellular Phone
My nokia 6270 won't turn on
CHANGE THE ON OFF BUTTON ON THE TOP OF THE PHONE
Apr 12, 2009 | Nokia 6270 Cellular Phone
FORMET MY NOKIA 6270
You can format nokia 6270 becuase no codes of symbian operating system mobile works on it.It is a java based mobile..All you can do is Restore to factory settings in settings...But you can update the nokia 6270 firmware by installing nokia software updater and nokia pc suite...
Regards
Dilip
Nov 01, 2008 | Nokia 6270 Cellular Phone
6270 upper keypad not working
Inside belt(cable) problem. Change your cable then it works
May 12, 2008 | Nokia 6270 Cellular Phone
Keypad problem of nokia 6270
upper keypad is not working properly
May 01, 2008 | Nokia 6270 Cellular Phone
Animated themes not working on nokia 6270
Install NOKIA PC SUITE into your computer now connect your mobile with the data cable and
update phone software ,it will install the lates software/firmware for your mobile....................enjoy
Apr 04, 2008 | Nokia 6270 Cellular Phone
You are unable to run animated themes on your mobile because you dont have the latest firmware/software for you mobile nokia 6270.
SOLUTION:Install NOKIA PC SUITE into your computer now connect your mobile with the data cable and computer through usb port.After that start NOKIA PCSUITE and select option update phone software ,it will install the lates software/firmware for your mobile....................now install animated themes on your mobile and check it.you will find animated themes working............enjoy
Regard:
dilipbagdi
Technical Associate
Nokia 6270 Cellular Phone Logo
108 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
