Question about Argox OS-214 Label Printer
Troubleshooting Argox OS-214 Label Printer, Support
When print command is given the ribbon (thermal transfer model) runs out of the unit along with the paper ( it sticks to the paper) and the printer gets stopped... pls hep me...
  • 2 more comments
  • Indan Jun 06, 2008
  • danishmohamm Sep 12, 2008
    when print command is given the ribbon (thermal transfer model) runs out of the unit along with the paper ( it sticks to the paper) and the printer gets stopped... pls hep me...
  • Anonymous Mar 17, 2014
    i am not using a ribbon but the printer is not printing.
    printer is not printing. the feed button brings out the paper but there is no print-out. i am not using any ribbon.
Your ribbon is not firm enough - roll the ribbon at the top until it is firm. If it is too loose it will stick to the paper. Follow directions to ensure that ribbon is installed properly.
Posted on Sep 26, 2008
Print command goes, but printer do not print
do you send print command by driver or PPLB/PPLA command?
Mar 10, 2014 | Argox OS-214 Label Printer
Where do i buy ARGOX GE-200 PLUS
Argox launched Ethernet industrial label printer
Adopted Ethernet management makes industrial printer strengthened
Argox adopted Ethernet into industrial printer series and launched X-2300E(203dpi) for regular resolution printing and X-3200E(300dpi) for high-resolution printing to meet different demands. Both X-2300E and X-3200E are equipped with enlarged memory - 8MB Flash Memory/16MB DRAM- leading ahead of competitors. The built-in RTC(real-time clock) is also an advantage to work alone with the printer to print time/date on the label without a PC.
X-2300E/X-3200E provides PPLA/PPLB/PPLZ(X-2300ZE, X-3200ZE) emulations for all application. And the auto calibration function supports 4 modes of setup provides flexibility for the users to choose the most convenient mode for different printing applications to ensure accurate label detection.
To satisfy the requirements of industrial printer application like wide area between operation systems in network and large number of equipment, utilizing Ethernet to deliver printing tasks is a more economical choice for enterprises. X-2300E/X-3200E installed Ethernet server to provide the interface of Ethernet data transfer and by using SNMP setup to deliver the error massage back to managing server to simplify the procedure and enhance efficiency.
X-2300E/X-3200E supports Windows 7 system and 1D barcode, 2D barcode, QRcode and etc. It's suitable for the production line of manufacture including safety labels, patent labels, and?parts-name stickers, and fit for the application of shelf-label printing management, storage, delivery, shipping, transportation, luggage labels and wash care labels for clothing.
LINK IS GIVEN BELOW..................
http://www.argox.com/content.php?sno=0000486
GOOD LUCK......................
Sep 22, 2011 | Argox OS-214 Label Printer
Hello i want to use a argox ribbon printer os 214 plus with my mac book pro and osx lion is this possible ? so yes i like to know how Ron
To be able to do that you need to use a cups driver.
Try www.cups.org
try a driver for datamax or for Zebra if you have the pplz option
Else you'll have to write one.
Aug 04, 2011 | Argox OS-214 Label Printer
Argox 214 not compatible with vista
Thermal printers seem to be notorious for that.
Try using Vista's "Generic/Text" printer driver (you'll need to go into device manager, select to update the drivers, go to Have Disk, select "generic" as the brand). That will send raw text to the printer. Many thermal printers support this.
After you do that, you will also need to go into your printer settings and setup a custom page size that matches the size of your labels. Then you should be good to go.
Jan 02, 2009 | Argox OS-203 Thermal Label Printer
Argox OS-214 SOFTWARE
Your printers run Windows XP and Vista.
If you don't have drivers and program. You can download driver and program from below link http://www.barkodokuyucu.com/download/argox/bartender_BT801_2239_UL_Argox.exe
Ufuk
Dec 17, 2008 | Argox OS-214 Label Printer
Software for the os-214 argox printer
Yes it will! It supports Win98/2000/NT/XP
Good luck to you
X2000+: no thermal transfer options and Argobar Pro issues
netsrapcc:
I don't have an Arox printer or Argobar, but I've seen similar messages from other programs.
First, I'd open a file in Argobar and make sure that another printer has not been selected. If the printer name has changed since the file was saved, the program probably selected your default printer, with far different attributes (higher resolution, different fonts, no thermal options).
Also check the printers properties (probably under an "advanced" option) to make sure the driver is installed for the correct model. If your printer supports label sensing other than "Media with Gap", the driver should show other settings. If a label is fed consistantly to the same spot when you Form Feed, then your sensor is working. It might take two From Feeds - one to advance the leading eadge to the printhead and one to advance the trailing edge to the tear bar.
If you just installed XP SP3, you might need to re-install the driver. You can download from Argox, but I prefer Seagull drivers, at http://www.seagullscientific.com/aspx/thermal_printer_list.aspx#Argox . There are several +2000 models listed. These work with XP SP3. You should be able to set many attributes in the Proerties and Preferences.
Occasionally, one or two files may be saved incorrectly and become corrupted (but never ALL files). In these cases, it easier to start a new file, with the proper label size, and copy & paste (if your software lets you) from the old to the new. Once I get files working well, I always copy them to a another folder.
By the way, if you have already printed with Direct Thermal settings, but had a ribbon loaded, the print head has not been damaged. Direct Thermal should turn off the warning when the ribbon sensor doesn't find a ribbon, and probably changes some of the heat attributes to optimize for ribbonless printing, so the quality with a ribbon is decreased.
The printhead can be gently cleaned occasionally with 70% Isopropal Alchohol on a Qtip, but never touch the printhead with a hard object. One tap with a metal object while the printer is on would probably destroy that part of the printhead.
I hope this helps!
God bless,
Label Guy
Nov 12, 2008 | Argox X-2000+ Thermal Label Printer
Argox printer os214
possible prpblems
1. your design need ribbon but your ribbon not installed
2. your label label gab type set but your design set continous type label
3.may be your calibration fail. You can calibration with one key.
best regards
Ufuk
Sep 03, 2008 | Argox OS-204 Thermal Label Printer
Error on feeding and printing
the problems are :-
  • cartridges are not recognised or installed
  • there is a paper jam.
Jul 17, 2008 | Argox OS-214 Label Printer
Argox OS-214 Label Printer Logo
829 people viewed this question
Top Argox Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
sahoo_sanjay
bvmihai
Are you an Argox Office Equipment and Supply Expert? Answer questions, earn points and help others
