Question about HP Photosmart C6100 All-In-One Printer
Cleaning the Flatbed Glass
I need to clean the flatbed scanner glass from inside of my C6180. Can someone please advise on how to get there?
Expanding on unicomuss solution : if you carefully pry off the plate covering the front panel buttons, you will find 2 more screws holding the glass plastic retainer down. I was able to remove all the screws in the feeder and the glass retainer and remove it completely for cleaning.
Posted on Nov 19, 2011
I have the same issue. The underside of the glass has collect a lot of dust and the pictures look terrible when I scan using the HP Photosmart C6180.
Posted on Sep 14, 2008
  • Unicornuss Aug 16, 2011
    Follow this link:http://h20000.www2.hp.com/bizsupport/Tec...
    There is a detailed description of how to open and clean the feeder. But you will also see screws there. These screws have a 'star' profile so you will need a special screw driver.
    First, turn the printer off. Open the feeder and on the back there is a plastic cover hiding connector tape. The part with stripes must be gently pushed and the cover removed, then the wire tape disconnected (you won't be able to remove the feeder otherwise! Do not use any power! you may break the plastic parts!). After you had disconnected the feeder, unscrew the 2 srews at the back and 1 screw in the front. Now you should be able to remove the feeder gently by pulling slightly up. WATCH your steps carefully and order the screws to able to assemble the parts back together! After that there are some more screws holding the flatbed. After you have removed the screws it will easier for you pull the glass with some force BUT carefully to the left (it is like a drawer). Do not hast, it may take some time (I couldn't find the way to remove the plastic cover holding the glass completely, but I managed to withdraw the glass, clean it and push it gently back. I also cleaned the plastic parts below the glass / be careful with the connector tapes! Good luck! PS: if you do not trust your skills, you'd better call a specialist.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 93 Answers
We cannot clean inside the flatbed scanner glass, it is not a removable part.
Posted on Jun 06, 2008
Black vertical line prints on the right side of every page.
Good Day Tkidwell!
Better check and clean the ADF platen glass and the flatbed scanner glass.
Use a lint clothe moistened with alcohol or water and gently wipe the dirt in the glasses of the ADF platen and flatbed scanner.
You can also try cleaning the roller by performing the deep cleaning.
Jul 12, 2011 | HP Photosmart C7280 Printer
Tip
Cleaning your inside scanner glass
Actually it's a very simple procedure!
Read this entire comment first...then start your procedures!
Disconnect the power cord, disconnect the USB cable, remove the top cover cable from the base by unscrewing the two plastic knobs, lift the top cover straight up. Place the top cover in a safe place.
On a clean, flat surface, turn the base upside down. On both ends you will find a total of four (4) black phillips head screws. Carefully unscrew these four screws and place aside. Carefully lift up the base and the top glass will separate from the base. Set the base aside. You have now exposed the inside glass for cleaning! It's that simple!!! Clean the glass by using a streak-free glass cleaner. Don't spray the glass, rather, lightly spray a clean soft lint free glass cleaning cloth, then wipe the glass. Don't press hard! Use good common sense1 There, you've now cleaned the interior glass. Reverse the procedure and you are finished. Wasn't that simple??
on Feb 15, 2009 | HP Scanjet G4050 Flatbed Scanner
Why is there a line on the left side of my copy when I use the ADF on my Canon Image Clas D1150? It does not do it when the flatbed is used. Please help. Thanks, Joann
When lines appear on copies of documents fed through the ADF, it typically means that there is some kind of dirt or foreign material on the glass that the document passes over. A different window is used when scanning from the ADF as opposed to the flatbed. The flatbed window is large, often much larger than a standard sheet of paper. The ADF window, on the other hand, is small and slender. It doesn't need to be large because the document moves over it (as opposed to the flatbed, where the document is stationary while the scanner moves under it).
The ADF window is usually situated next to the flatbed glass on the side of the scanner where the ADF takes in the paper. Open the scanner lid (as though you were going to make a copy on the flatbed) and find the slender piece of glass just under where the ADF would be when the lid is closed. Once you've located the ADF glass, use a mild glass cleaner and a lint-free cloth to gently clean the surface of the glass. If you are able to see the foreign material, you can remove it by hand, but be sure to clean the glass thoroughly afterwards, as fingerprints can also cause poor quality copies.
After the glass has been cleaned, test the ADF copy function and make sure the line has disappeared. If it has not, you may need to remove the slender glass and clean the underside (though this is almost never required, as the underside is protected from environmental debris).
If you find this solution helpful, please leave a positive rating!
Jun 20, 2011 | Canon imageCLASS D1150 All-In-One Laser...
How do I get rid of the line running down the scanned document?
Simple, clean the ADF glass that the paper passes over during a scan (not the flatbed glass itself, just the thin strip of glass at the head of the flatbed glass). A speck of dirt on the glass will appear as a line down the length of the paper.
May 23, 2011 | Epson GT-2500 Flatbed Scanner
Every time I scan lines appears either on document or pictures. I tried cleaning the glass but nothing happens.
Clean the **** glass with alcohol. The **** glass is the little glass that paper is scanned over when using a automatic document feeder.
Jun 18, 2010 | HP 5590 ScanJet Flatbed Scanner
I need to clean the underside of the glass but don't know how to take the glass bed off.
if you are not an expert, you need caution to remove the glass for cleaning.
CAREFULNESS IS THE CODE
Nov 29, 2009 | Microtek SCANMAKER 4850 Flatbed Scanner
When using the ADF for scanning to pdf, it creates black lines vertically down the left side of the document. If I use the flatbed scanner, no lines.
Your machine ADF is dirty or dust in adf glass please clean it by soft cloth and scane again its clear and sharp.
thanks.
Nov 24, 2009 | Brother MFC-7820N Printer
I want to remove glas of CanoScan LiDE 25 Flatbed Scannerfor cleaning
Why? It shouldn't be dirty behind the glass. If the glass is dirty wipe the glass with a cloth dabbed in methylated spirits.
Jul 19, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Cleaning the Scanner
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Jan 19, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
How do I access the underside of the Flatbed scanner to clean it?
remove the lid by lifting up. There are two philips head screws exposed. Remove screws and lift top of scanner off. Pay particular attention to thumb wheel position when lifting. Go to computer repair center and buy double sided tape. replace tape and reverse process
Nov 08, 2007 | Umax Astra 1200S Flatbed Scanner
HP Photosmart C6100 All-In-One Printer Logo
789 people viewed this question
Ben Johnson
