Question about Dell 5100cn Laser Printer
I have lost an important document
I have printed important contract yesterday, then today my young child broke the paper sheets. Unfortunatelly I have already deleted the word document. Friend of mine suggested that maybe DELL printer has some kind of memory that I can restore last print? Is that possible? I WILL BE VERY VERY GRATEFULL, SINCE MY BOSS WILL KILL ME :(.
Regards, Kate
    Genius:
  • 2,785 Answers
You can retrive the data(from hard disk), you can try by downloading any free software from www.majorgeeks.com
Posted on Jun 06, 2008
My printer has started printing a black line down the edge of the paper?
Remove the laser print cartridge, shake it lightly, and place it back into your printer. That should solve the problem.
Mar 15, 2013 | Kyocera FS-1030D Laser Printer
I have a canon MF 8350 cdn and when i try to print certain documents such as pdfs or excel sheets the printer prints out a couple pages then gives the error "check paper size" even though it is...
Check paper size refers to the fact your documents are for say and A4 sheet of paper but your drivers properties are set to letter size. Go into the drivers printing preferences and set the paper size to the correct value. All should work fine now.
Jun 01, 2011 | Canon MF8350Cdn AllInOne Laser Printer
While printing, red turned to pink on printed sheets. All cartridges have ink.
Try
Clean the Scanning Area sikaku.gif Cleaning the Platen Glass and Document Cover i_expl.gif Caution
Be sure to turn off the power and disconnect the power cord before cleaning the machine.
i_important.gif Important
bullet_s2.gif The inner side of the Document Cover (white sheet) (C) is easily damaged, so wipe it gently.
bullet_s2.gif If the glass of the ADF (A) is stained with ink, correction fluid, or the like, black streaks may appear on the printed paper when the document is loaded in the ADF. With a clean, soft, lint-free cloth, wipe the glass of the ADF.
With a clean, soft, lint-free cloth, wipe the Platen Glass (D), the inner side of the Document Cover (white sheet) (C), the glass of the ADF (A), and the inner side of the ADF (white area) (B) gently. Make sure not to leave any residue, especially on the Platen Glass.
sikaku.gif Cleaning the ADF i_expl.gif Caution
1. Open the Document Tray.
2. Open the Feeder Cover.
3. With a soft, clean, lint-free and dry cloth, wipe off any paper dust from the inside of the Feeder Cover (A).
4. After wiping, close the Feeder Cover by pushing it until it clicks into place.
5. Close the Document Tray.
6. Reconnect the power cord then turn on the machine.
Oct 27, 2010 | Canon PIXMA MX850 Multifunction Printer
I have an HP 4V laserjet printer. It was printing fine until today. Both trays are full but it wont print. Form feed light is on, LC load letter message is flashing.
This is looking for Letter Sized Paper and presumably nit A$ that you normally use. This is usually caused by printing US documents and not resetting the paper size in the application before printing as the paper size will be embedded in the document in its original format.
Simply select the whole document and then reset the paper size to A4. You may need to check the document for lost images and tables but generally the text should be OK. Also the index and table of contents will also be affected as you will presumably have more A4 pages in the reformatted document that in the original.
Sep 21, 2009 | HP Office Equipment & Supplies
I printed a long (75pp) IRS document on my HL2040 yesterday, but when I tried to print something else, the memory persisted and it began the long document all over again. I did not know how to stop it--...
You'll need to cancel printing by:
Cancel printing
While printing press the Go button for about 4 seconds until all the LEDs light up. The Ready and Paper LEDs
will flash as the job is being cancelled.
Sep 01, 2009 | Car Audio & Video
Problem printing multiple pages on one sheet!
This is not the fault of the printer but the fault of word.
The way I did it successfully was as follow:
File > Page Setup > Layout = Landscape (sounds like you have already done this)
In the print dialoge, instead of OK, click Properties. On the layout tab, select landscape and below that select pages per sheet = 4 and then click ok... Then click OK to print.
May 22, 2008 | HP LaserJet 2200 Printer
Paper is feeding unevenly on black & white prints
If the paper is lodged too far into the printer and can't be removed:
  1. Press the power button to turn the printer off.
  2. Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
  3. Close the front cover.
  4. Press the power button to turn the printer back on.
  5. Resend your document to print.
Ensure that:
  • The paper is a recommended paper for inkjet printers.
  • You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
  • The printer is on a flat, level surface.
  • The left paper guide is against the side of the paper.
  • You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
  • The left paper guide does not cause the paper to bend in the sheet feeder.
  • Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
  • Envelopes or the appropriate specialty papers are selected in the printer driver.
  • You are using a paper or envelope size supported by your printer.
Important: Your application may not be designed to print envelopes. For help, consult the documentation that accompanied your application.
May 21, 2008 | Lexmark X4270 All-In-One InkJet Printer
How Can I Reprint a Fax?
Here's a trick that I used on the Canon thermal transfer years ago. First take out the thermal transfer unit and roll up the black transfer sheet to the begining of the lost fax. Then reload the paper. Next get a solid black original equal and make a copy. The result you should get a negative copy of the lost fax. Repeat this step until all the faxes are recovered..
May 31, 2007 | Panasonic KX-FC195E Plain Paper Thermal...
Pohot paper jamming in Brother DCP-115C printer
This is a common error of this printertype. Please use only paper of max. 220g. There is no problem reported with that.
Jan 14, 2007 | Brother DCP-110C All-In-One InkJet Printer
Dell 5100cn Laser Printer Logo
22 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
