Question about Apple Cinema HD 23" LCD Monitor
Blank screen (Apple Cinema HD 23"LCD)
My monitor screen remains blank when I turn it on. The little display light at the bottom right is on. The brick has been tested and is fine. Anybody has any idea? I took it to a few Mac shops but they all refused to open it, so they don't know what the problem is. Apple will take it but it will cost me the price of a new monitor. I'm really not happy about it and I won't go there but the monitor was only 16 months old when it stopped working. (no more warranty).
  • 3 more comments
  • morgantastic Aug 08, 2008
    I've got exactly the same problem, same response from apple.
    I've done some research and it seems that the inverter board may be the problem...does this sound right? and where can i get one?
  • redinhawaii Nov 13, 2008
    this is my second 20" apple monitor, blank screen.
    Is there any option besides buying a new monitor?
  • bilco5 Nov 14, 2008
    Apple 23" Cinema Display, worked one day, not the next. Screen is off, power light is on. We have two, tried the other brick, same result on the monitor. Looking into repair options.
  • Anonymous Dec 22, 2008
    I've had the same problem twice.  Dual 23" displays.  The first one went while still under warranty, the 2nd one went after.  This seems to be a common issue among these displays.  Look here: http://discussions.apple.com/thread.jspa...
  • sunbird808 Jan 01, 2009
    My 20" Apple Cinema Display just went blank two days ago. DVI power adapter is outputting the correct voltage. The problem appears to be in the display itself, since I can use another monitor just fine. My display is just 4 years old. I've had other monitors last more than 8 yrs. Shouldn't have to buy another monitor so soon. Apple should be able to repair existing one for a reasonable cost.
Hey, listen to this! I bought a brand new Cinema 23" and it worked for 1 hour then it shut down. Man, if there was an Apple-dude here he would be so spanked.
Posted on Oct 20, 2008
Had a similar problem with similar symptoms. Try unplugging the firewire and usb. Might help for a while. It did for me. In the end I risked the price of a new power supply. That fixed it and my 23" has been working fine since. Have to order the power supply directly by contacting Apple's service people. I found no other way to get one.
Posted on Sep 14, 2008
Damn gay i got t is 23 apple screen for 14month and it has a black screen now :( .. what can i do to fix this .?
Posted on Aug 27, 2008
30" apple cinema display suddenly went blank.
It's probably the backlight. If you look very closely, perhaps using a flashlight, you might be able to see that it is still working but just not being lit up from the back. In that case it may be worth fixing, but if not, then it's probably past its useful life.
One other thing you might try is a different power supply.
Feb 14, 2014 | Apple Cinema HD 30" LCD Monitor
Blinking light on 20 inch apple display
Blinking light on Apple cinema display usually indicates insufficient power from the power supply. Test it with another power supply from ANY cinema display (23" and 27" power supplies are ok to test with).
Feb 03, 2014 | Apple Cinema HD 30" LCD Monitor
Monitor will not power on
the best sway to deal with apple products is to bring it to apple themselves......9 out of 10 times they will fix it for nothing
Jan 11, 2013 | Apple Cinema Display 23" HD Monitor
Apple 23 monitor 3 blinks and then pause, top screen is dim.
I have an older 20" display. I have had this same problem on occasion, and coincidentally, just experienced it again this morning. It seems to occur after I do an OS update. I powered down the computer, disconnected the display, reconnected by pushing firmly into place, then powered up. The flashing stopped and the display works fine. You might have a different problem, but that simple solution worked for me.
Apr 04, 2009 | Apple Cinema Display 23" HD Monitor
Need disassembly instructions
-After removing the plastic ends, remove the two other metal pieces that the plastic ends were attached to. -Turn monitor upside down and you will see two small tabs on each end. Just pull those outward. They don't move far, but that releases the bottom seam of the monitor. - Carefully pull the two pieces apart. Remember that you will put a crease on the front of you monitor if you open it too much. - If you have a tool to remove the power cable great, but if you don't you can carefully pull the cable through the hole. -Then the whole LCD with all the boards can be removed and serviced.
Mar 29, 2009 | Apple Cinema Display 23" HD Monitor
Apple 23" HD display screen is black, power is on... All wires are connected. The computer is booting up fine. The monitor light is on. The monitor is remaining black. This has never happened before. Any...
you need to open it up and replace the backlight(s), you will be quoted nearly the price new to get this fixed. might aswell bin it or eBay it! you intrestedin selling it?
Jan 06, 2009 | Apple Cinema Display 23" HD Monitor
Apple 23" Cinema HD Display went off
Hey - I just got done with 30 minutes of trying my cinema HD on my macbook pro and plugging and unplugging. When I plugged it into an extension cord in another socket the monitor started right up. I've had this configuration in my office for years with no problem...until today. Did mac send us a system upgrade that caused a problem with the monitor's power source???? Good luck!!!!
Jul 28, 2008 | Apple Cinema Display 23" HD Monitor
Screen does not turn on
Sounds like the 90w power adaptor. This has happened to my 23" Apple monitor several times. (I'm on my third 90 watt "brick"!) It seems to happen after about one year of use. All you can do in the meantime is never shut down or let the monitor go to sleep.
Oct 29, 2007 | Apple Cinema Display 23" HD Monitor
Apple Cinema HD 23" LCD Monitor Logo
3,143 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
