Your solution Thanks mate, thats what i thought but when i recently visisted a PC retailer he advised me that due to my limited processor speed it would not be worth putting a decent card in as my pc would fall over under the strain.
  • kogsy74 Jun 12, 2008
    Thanks mate.
  • 98 Answers
Well, according to your link to the specs of your PC, the processor should not be a problem since it's a dual core. However, after thinking about it, an nVidia 8600 or 8800 both use power from the PCI ex16 and an extra connector from power supply. If the wattage on the power supply is to low, the video card could strain it. An nVidia Gforce 8500gt does not use an extra connection from the power supply. I would go with one of those.
Posted on Jun 08, 2008
How to increase the speed of iphone 4 by having ios 7.1.1 software
The issue with the iPhone 4 is the processor. The 4S works well with iOS 7.1.1 with its updated processor. Honestly, I recently replaced my iPhone 4 with a 5S due to the issues with the new iOS. Take my advise, buy the latest iPhone you can afford. When the iPhone 6 is released it will have iOS8. I would guess that they will not even support it on the iPhone4 and the 4S will struggle. Stay away from the iPhone 5 as the 5S is the one with the fast 64bit processor.
May 08, 2014 | Cell Phones
My computer automatically shuts off when not inactive for 5 minutes
Hello jeepmallabo,
The shutdown is probably due to hardware overheating. Make sure that your CPU fan is automatically increasing in speed when the processor is being used. You should hear the sounds.
It is possible that the fan controller may not be working or the fan itself is going bad. When dealing with retail CPUs, its always best to purchase an aftermarket CPU cooler.
Hope this helps!
Jun 29, 2011 | AMD Sempron 3100+ 1.8GHz 256k Socket 754...
What is the maximum limit of Processor my OPTIPLEX GX26- can support? i have currently 2.4ghz processor working and i want to now what is the max limit i can upgrade it to, can i place intel core duo?
Sorry, the GX260 can not support a intel core duo. The processor sockets do not match the motherboard.
Also, it can handle any pentium 4 processor that uses an 800MHz bus speed, because the highest bus speed that the GX260 motherboard supports is 533 MHz. The fastest processor available for the GX260 is 2.6 GHz.
Here are the tech specs:
http://support.dell.com/support/edocs/systems/opgx260/en/ug/specs.htm#1110653
Dec 29, 2010 | Dell OptiPlex GX260 PC Desktop
I have a HP a1630n thee monitor says video cable connected?.The processor fan runs full speed all the time,thats all it does!
The Processor fan usually runs full speed, when the Processor is sensed to be overheating. BIOS, (BIOS program), determines if the Processor is past it's thermal limit. This is done by sensing the Negative value of a Ground to the Processor. If the negative value is too low, BIOS turns the Processor off. [Thermal Limit: A Processor is a type of I.C. Integrated Circuit. http://en.wikipedia.org/wiki/CPU Electrons passing through the miniature circuitry within the Processor, make heat as they move. (One Electron actually hits another Electron. This activates the motion of Electrons, that is soon to become Electricity. Electrons hitting each other create Friction. Friction causes heat) A Processor can only run so hot before it burns up. (Literally in some cases. As in....... On Fire) There is a limit set as to how hot the Processor can still function correctly, and what is the maximum safe limit before the Processor's instructions, starting breaking down. This is the Thermal Limit ] As the heat builds up, the Heatsink, and Processor Fan, cool the Processor down. Helps to keep the Processor, well below it's Thermal Limit. [ The Processor's fan can sit on top of the Heatsink, or it can be a front case fan pushing air through a plastic tuned port, to the Heatsink. Your processor fan is sitting on top of a Heatsink. A typical Heatsink/Fan combo, http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3451342&CatId=493 Typical construction of a Heatsink, is a flat plate of metal with tall, thin fins protruding from it. Heat is absorbed by the plate of metal, and the fins absorb the heat from the plate, where it is radiated away. Your Processor fan is sitting on top of a Heatsink, which is sitting on the top of the Processor's case] The top of a Processor's case, and the bottom of a Heatsink, are not perfectly smooth. An in-depth view shows 'Hills, Valleys, and Pits'. These form cavities, or voids, that are filled up with Air. Air is an Insulator, not a Conductor. Thermal paste compound is used to fill these voids, and transfer heat from the top of the Processor's case, to the bottom of the Heatsink. Thermal paste is a Conductor. A typical Processor's thermal limit, is usually pretty warm. Time, after time of heating the Processor up, has also heated the thermal paste. Thermal paste can dry out, and harden due to this. It reduces the thermal properties of the thermal compound, to a useless state. It is an Insulator now, and not a Conductor. Doesn't conduct heat. Age also causes the properties of the thermal paste to break down. I would suggest taking a look at the thermal compound. It's always a good procedure to clean the Processor, and the Heatsink, and install fresh, new thermal paste. Decent thermal paste averages around $6, but a 'Mom and Pop' computer shop may have a one Processor application, for around $2. [Remember to follow Anti-Static Precautions, BEFORE reaching inside your unplugged from power, computer ]
Aug 30, 2010 | HP Pavilion a1630n PC Desktop
Toshiba L305-S5944 T 3400 Want to upgrade ???processor the bus speed is F/S bus speed is 667 can I break this Limit?? with a processor??? are is that it fast as it will go??? what does efect the board...
With laptops you are severely limited with what you can do regarding the processor. It's highly unlikely that you will break the 667 front side bus barrier at all. A laptop BIOS just doesn't support CPU overclocking and neither does a laptop motherboard.
The only thing you could do is upgrade the processor for a better one like a C2D T8100 for example but the bus speed on that is only 800 MHz so there are limitations.
A desktop motherboard is a different kettle of fish as some motherboards are designed with CPU overclocking in mind and are cheaper to purchase.
If you wanting to upgrade the processor for gaming purposes then i wouldn't bother as the GPU (graphics processing unit) in the L305 is not that good at all.
I hope i have answered your questions for you.
Regards.
Jan 24, 2010 | Computers & Internet
Fan
Either clean and oil or replace the fan.
Jun 11, 2009 | Toshiba Satellite P10-S429 Notebook
Memory upgrade on presario 4403us desktop
Hi yes thats correct you can have only 512mb RAM. This is due to your motherboard limitations or bios limitations. The only way is to change the motherboard this will allow you to also have latest usb 2 support. Just buy a motherboardboard thats compatible with your processor and existing memory.
Mar 14, 2009 | Compaq Computers & Internet
Dell dimension 2400
The front side bus speed of the processor is the limiting factor of your RAM speed.
The Processor has a 400 Mhz FSB, hnece your RAM runs at 266.
For RAM to run at 333 (PC 2700), you'll need a 533 FSB Processor.
Jun 25, 2008 | Dell Dimension 2400 PC Desktop
AMD Athon XP 2600 dropped speed
Some times when a computer shuts down unexspectedly like that it will reset itself back to its defaults in bios thinking there was a problem. Go in there and check your cpu settings. The fsb should be set to 266 mhz. Make sure it didnt default back to 133 mhz.
And FYI the 2600 is acutally a 2.13 gig cpu not a 2.6 gig..
Mar 02, 2008 | AMD Athlon XP 2600+, 2.08 GHz...
LCD Display - Gray Shades/Lines
1ST OF ALL U SHOULD CHECK UR CPU WITH ANY OTHER MONIOR IF IT WORKS OK THEN BUY 256MB XFX 3GP CARD
Dec 14, 2007 | Gateway GeForce2 NV15, (64 MB) Graphic...
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
