Question about Samsung Televison & Video
Samsung rear projection tv about 4 years old. Colours are mixed on the screen looks like a 3d effect.
  • Samsung Master
  • 8,617 Answers
Need to replace the convergence ICs both of them , you can get replacement ICs at the following link and they include free installation instructions with pictures.
http://servicemanuals.vstore.ca/
Posted on Jun 06, 2008
Fix the 3d look on my rear projection samsung model hcl4715w. it is a 2001
Read Chapter 3 about adjusting the convergence controls. These are to do with the alignment of the colours. It will help you fix the 3D look.
TVs
Sep 11, 2014 | Samsung HCL4715W 47" Rear Projection...
I have a samsung sp43w6hpx which started to mix colours and now it just goes to standby can anybody help please as its a good tv and i`d like it fixed
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Mar 02, 2011 | Samsung HCN436W 43" Rear Projection...
My samsung HCM4216W TV has 3-D effect i was told it is a conversion module for the bulbs is this right
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 12, 2011 | Samsung HCM4216W 42" Rear Projection...
When switched on colours fine after short period colours seperate causing a 3d type effect
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 21, 2009 | Samsung HCN4226W 42" Rear Projection...
Rainbow colours on the screen
The projector is starting to go out in it. Depending on your financial situation, you can take it to a shop to have it looked at, or replace the TV. Depending on how long this has been happening, the Pioneer projectors usually last about 100 hours once this happens before they burn out completely.
Apr 30, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Colours are out
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Mar 10, 2009 | Toshiba 42H81 42" Rear Projection...
Colours serparated, not converged, screen looks concave
Replace Both fo your STKs convergence ICs STK392-040s. For Parts Call 1-800-223-3205
Dec 30, 2008 | Samsung HC-P4741W 47" Rear Projection...
Picture shadow on rear projection Sony big screen TV
You have 2 distinct problems that should be addressed separately. Please repost the Samsung problem. I will address the Sony problem here.
If the "shadow" makes the picture seem somewhat of a 3D one, the problem is with the convergence circuit. This could be as simple as bad connections on the pins of the convergence ICs or defective ICs. If you can solder and would like to attempt the repair, update this and I'll provide more details and instructions.
Dan
Sep 25, 2008 | Samsung HCM4216W 42" Rear Projection...
JVC AV-48WP34
The convergence ICs need to be replaced. I can post a link where to get replacement ICs along with free step by step instructions so you can do the repair yourself. Its an easy ,common repair , however a shop will be around 300 to 400
Mar 28, 2008 | JVC AV-48WP30 48" Rear Projection...
Colours not mixig together
You have a problem with the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conducting piece of wood to push the heat sink when doing tests.
If soldering doesn't help, then the modules have died and need replacing. Don't buy the $10 cheap ones. Most of them have an upgraded version that is stronger. Also look for any burned resistors in the vicinity of the modules.
Best of luck, hope ya fix it.
Mar 06, 2008 | Samsung HCN436W 43" Rear Projection...
Open Questions:
Televison & Video Logo
41 people viewed this question
Henry  Thomas
Henry Thomas
