Question about Acer Aspire 3050 Notebook
Noisy fan? noisy at times sounds like a cd whirring around inside
    Sergeant:
  • 458 Answers
This is normal.. It is keeping your computer cool when it gets too hot.
If you like this answer please rate it as a FIXYA.
Posted on Jun 06, 2008
  • T&N Family Electronics Dean and Sherrie Terrell
    Did you figure out that is was just the fan spinning when the computer got hot?
    You need to make sure that you never put the laptop on a flat surface. The laptop can not breath on a flat surface. It needs to stay propped up on a laptop stand with a fan blowing on it. They sell these at almost any computer store and even at Walmart.
    Are you still having this problem? Did my answer solve your problem?
    Rate this as a Fixya if it is fixed.
The fans have become very noisy what can I do?
there are 2 places to check....Not sure of the model of your fridge but on the backLook for the compressor fan...make sure it is clean and free of dirt...Alot of times there are located on the back but I have seen a couple older ones where the fan is located on the bottom....They get clogged with dust and dirt/....but for a noisy loud fan I suspect your fan inside the fridge is partially frozen...condensation collects around these fans alot and freezes ...the ice hitting and rubbing against the fan itself...so located the fan on the inside....It is usually towards the bottom and behind the little drawers...and hidden behind a sheild of some sort....defrost with a hairdryer if needed....good luck.
Mar 03, 2015 | Refrigerators
Noisy computer fan
If its a loud "whirring" noise almost grindy...you need to replace that fan...it's about to fail. if it's a vibration type of noise, you should try tightening the screws first...if it's coming from processor fan, replace it before you fry your processor...
Jul 03, 2012 | Computers & Internet
My computer makes a highish pitched whirring noise every time it has to do something slightly difficult, typically a video or interactive things. What is it and can I fix it?
Yes, open the side cover and determine where the noise is coming from - Harddrive, fans, DVD/CD player, etc.. If it's the harddrive, start backing up your important data asap before it goes out completely. If it's a fan, power down the computer and clean the fan. If it's t DVD/CD drive, replace the drive.
Nov 08, 2010 | HP Pavilion a1240n (EG136AA) PC Desktop
Noisy motor on fridge side which whirred to a stop
Hi, It sounds to me like the evaporator fan motor is faulty. They will quit working after they make a noise like that, bearings and windings.You have a door switch that stops the fan when you open the door, that opens the contacts on the motor. It should have come back on when closing door. Now you say it has quit cooling,so if this motor has not come back on and is not running quietly, it will need to be removed and replaced.It may be difficult for you if you are going to do this yourself, but if your up to it, you can save yourself some $.You can buy a new one at an appliance parts house, or get all of the info from you're unit and go online to order one.They have universal motors to fit also.It would be a 120volt sealed motor with a plastic or aluminum blade.Try and remove it yourself if you are able, if not you will need to call out the tech which can get costly. Best of Luck to you and please keep me posted.Have a good night, Sincerely,
Shastalaker7
Dec 06, 2009 | Washing Machines
Our LG bottom freezer refridgerator is 2 years old. It is making a whirring noise that stops when the door is opened. It can get pretty loud at times.
The whirring sound is the fan that blows cold air into the refrigerator. It is supposed to stop when the door is opened. If it is making a loud noise there may be ice built up in the fan housing. Turning the power to the refrigerator off for a 2-4 hours may allow any ice in the fan to melt. If you do not open the freezer during that time the frozen food will not defrost.If the noise continues, you may have to take the fan apart to make sure it is not frozen. It is probably located behind the back inside panel of the freezer.
Nov 02, 2009 | Refrigerators
Comp is very noisy while running,keeps making whirring sound
have you opened the case and cleaned the fans with a fine brush?
Oct 12, 2009 | Dell Dimension 4700C PC Desktop
Gateway laptop - whirring, buzzing sound
if it's a continuous whirring sound it is most likely the cooling fan. this is normal. as the computer gets older this will get noticably louder as the fan has to run faster to prevent overheating.
Aug 14, 2009 | Gateway Computers & Internet
E machines t3506 noisy fan or hard drive
Most cases it came from the power supply fan. however sometimes came from cpu fan. or in video fan. This is due power shorted. Its easy to replace fan its only plug in..just bring the sample fan to the vendor of your pc.
may this help.
melnavz
Oct 13, 2008 | E-Machines eMachines Desktop PC
Whirring noise. No other problems.
Sounds like you have a noisy color wheel. Very common on all Samsung DLP`s. The part # is BP96-00250A for model HLN5065W.
Oct 16, 2007 | Samsung HLN5065W 50" Rear Projection...
Acer Aspire 3050 Notebook Logo
122 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
