Canon CanoScan D646U Flatbed Scanner
Problem for Canon CanoScan D646U Flatbed Scanner
Lost CD for installing scanner
By gatul on Jun 06, 2008
I don't have the CD to install scanner on my computer. I just bought a new computer. It has Windows XP. I don't know if this scanner will even work with the scanner. Can you help? wants driver for winxp os
Same Problem
Jun 26, 2008
-   After downloading, I received this message: I could not create - unzip operation cancelled". And now, whatelse can I do?-   nancycf
Jun 18, 2008
-   My installer was lost for CanoScan D646U... pls help me -   wangyuhan
Jun 15, 2008
-   I don't have the CD to install canoscan D646U ex on my computer. I just bought a new computer. It has Windows XP home edition. Can you help? -   Guest
Jun 09, 2008
-   IMy computer.has Windows XP, but I do not have the CD to install scanner . Would you please help me?-   nancycf
Jun 07, 2008
-   i can, istall the scanner canoscan646u my computer is new but the scaner has no Driver CD-   Guest
Best Solution
posted on Jun 06, 2008
Very Helpful)
TandN
Rank: Guru
Rating: 86%, 276 votes
The thing that you need to do is go to the company site. Go to the company site that made the scanner to download the drivers. If they do not have a driver for XP then you are out of luck.
Comments:
Jun 08, 2008
- Did you solve your problem? Let me know if you are still having problems so I can help you more. If you can't find the driver let me know.
Give me the make and model of the scanner and I will try to find it for you. I will also need to know the O.S. that you are using.
You can try the driversguide site if the company no longer has it.
Jun 19, 2008
- Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Driver Install;
Look on the Company site under drivers and downloads. You will have to put in your model first and then the serial number sometimes. After you find your product you will find the drivers and more programs if they have any.
After you download the driver you might have to put it in a folder for it to be stored in. After you put it in a folder, unzip it in that folder and it should have an .exe file. Click on this and it should do the install. If it does not do your install you can go to the Device manager and click on the device and tell it to install or upgrade the driver. Then you will need to direct it to the folder where you have the unzipped file. This should correct your problem.
You can click on my name from now on and I will do my best to answer your question within a day.
I can't fix this for you, but if I helped you get it fixed, please rate it as a fixya. I did more than try; I sent you exactly to where you could get the driver and explained how to install it.
If you print out these directions you should never have any problem with a driver again.
Was this helpful?
Yes
No
Popular Solutions for Canon CanoScan D646U Flatbed
Questions and Unsolved Problems for Canon CanoScan D646U Flatbed
Do you recommend Canon CanoScan D646U Flatbed Scanner?
Answer
Answer
what does release the lock switch and detach the usb cable and reconnect ?
Answer
where can i get the drivers for a canoscan d646u ex to load onto my windows vista 64bit system
Answer
actully in using windows 7 & not able to install canon u646 ex please help me how can or... (More)
Answer
I have a CanoScan D646Uex. It worked just fin on my old (5 yr old) Dell. I have a new Dell running... (More)
Answer
I have the driver cd for Windows XP which was originally given with the Scanner but now i upgraded... (More)
6 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jun 07, 2008
dont have installer
Describe your Scanners problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Scanner Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
