Resolution running camera program, switched to auto resolution, now its stuck
    Problem Solver:
  • 5 Answers
Right click on your desktop choose properties goto the tab that titled settings and on there there is a slider you can change the screen resolution with move it up a notch and then choose apply or ok.
Paul
Posted on Jun 06, 2008
Canon powershot stuck in auto mode
In the menu try resetting to factory settings.
Feb 09, 2014 | Canon Powershot A4000 16mp 3" Lcd 8x...
My Mac will not install the Digital camera Solution Disk says my screen resolution is insufficient...
This must be because you have a widescreen monitor or because you have set a screen resolution that's too low for anything.
Most programs ask for a screen resolution higher than 1024x768 (which they rarely actually need) to install.
So you can change yours to that value (or higher) for the installation and if it distorts your display, set it back to the original value later.
To see how to change your resolution, go to this site; http://www.ehow.com/how_2064940_change-display-resolution-mac-osxchange-display-resolution-mac-osx.html
After setting the resolution to 1024x768 or higher, run the installation and it should proceed with no problems.
May 04, 2011 | Canon A3300 IS Digital Camera
My web cam 4tech is not clear
Is the audio not clear or the video not clear?.
If the camera is plugged in and installed correctly then you should be able to open up a web cam program like skype, gmail or messenger and test out the camera, as well as adjust the camera's settings.
If the camera lens does not have auto focus, see if you can move the camera lens around in both directions. Some cameras have this for manual focusing. If you cannot access the camera lens then it SHOULD have an auto focus feature.
Also, play around with the camera settings (brightness, focus, zoom, sharpness) to find the best combination of setting for your environment.
Older cameras dont have very good resolutions so don't expect a high quality image or frame rate.
Mar 05, 2011 | A4tech PK-635 Webcam
I do not know how to change the resolution size on the screen
please go to desktop properties. select setting option and now you can change your computer resulation.
Aug 11, 2009 | Computers & Internet
JVC camcorder won't work inside at night anymore.
check the following in camera mode and the auto/manual switch set to manual:
exposure: set to auto shutter: set to auto or off agc: auto white balance: auto program ae: off gain up: auto display/bright: +1-+3
after all that, hit the auto/manual switch again to set the camera into auto mode, the new settings should sort you out.
Jul 28, 2009 | JVC GR-D290 Mini DV Digital Camcorder
Unable to change color depth...
Ok I think i found your problem. You don't need to install any drivers.
Switch your display to 256 colors To switch your display to 256 colors
Some games and other software programs require that your monitor be set to 256 colors, or they run better in 256 colors. Many of those programs will switch your monitor to 256 colors automatically when you start the program. For those that don't, follow the steps below if you want to switch the display temporarily while the game or program is running.
  1. On your desktop or on the Start menu, right-click the game or other program that you want to run in 256 colors, and then click Properties.
  2. Click the Compatibility tab.
  3. Select the Run in 256 colors check box.
  • The screen will revert to your default color quality when you close the program.
  • Try switching to 256 colors if your software program shows the wrong color or the graphics redraw slowly.
  • If your software program appears in a small window in the center of your screen, you can increase its size by changing your screen resolution temporarily. Follow the procedure above, but in step 3 select the Run in 640x480 screen resolution check box. Your screen resolution will revert to its previous resolution when you close the program.
  • The Compatibility tab is available only for programs or games located on your computer's hard disk. It is not available if the program is stored on a floppy disk, compact disk, or a network.
Please rate this if it fix your issue
May 30, 2009 | eMachines W3611 PC Desktop
Lens Error and Proper switching on Problem
Same problem for me. Try below one. Its working!!!
Press the power-on button, and at the same time Press and hold the shutter button down
Mar 11, 2009 | Cameras
I installed my 913D camera driver and after some trouble and it tells me that there is a connection problem and to trouble shoot. I've already uninstalled and reinstalled and it still isn't working.
Follow steps below :)
Open “Windows help and support” window.
Type “Program Compatibility Wizard “ in the question box.
Select “Click to open compatibility wizard”
To continue, click Next.
-------->> I want to choose from a list of programs
-------->>Select a program: 913D Camera
-------->> Microsoft Windows 95
-------->>640 x 480 screen resolution
-------->>Run this program as an administrator
-------->>ALLOW
Run 913D Camera Software. Should be able to connect and manually download pictures. If not try different OS settings.
Sep 10, 2008 | Cameras
Low resolution/pixels on "auto" mode
Download the user manual HERE and it will tell you exactly how to change the setting.
Is an easy fix when you know it
May 02, 2008 | Canon PowerShot S3 IS Digital Camera
Changing the picture resolution
Turn on your camera.
Trun the switch on the top of the camera to AUTO.
Press the middle button right of the display (x/-).
Then you can first change the size (7M, 6M, 5M, 5M, 3M, 1M).
If you now use the circle button on the right bottom and on this button you press up or down you can change the quality (very fine, fine, normal).
You can change the size and quality if you press left/right on the circle button.
Jan 04, 2008 | Samsung Digimax S730 Digital Camera
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
