Question about HP Pavilion dv4000 Notebook
How to disable touchpad?
I would like to disable my touchpad since I just bought a mouse. I can't find the way to do this. There is no option in the control panel when clicked on the mouse icon. What the heck?
  • Anonymous Jun 12, 2008
    I have an HP Pavilion dv4000 with a touch pad, but do not see any button just above the touch pad. i want to disable it because as i type, my plam brushes the pad and jumps the cursor to a different location. Gets really annoying at times.
    Any suggestions would be greatly appreciated.
  • hangitjohn84 Jul 13, 2008
    how do I access my touchpad so that I can disable tapping and get my scroll grate to work
    President:
  • 1,257 Answers
Just above the touchpad you will find a small button just press it .and you will notice it is disable so no need to do any changes from control panel.if you want to enable it again press the button......
_______________________________________________________
Was this solution helpful .Show your appreciation by rating it.
Thanks for using fixya support. You have a wonderful day..
Posted on Jun 06, 2008
Hello, I have the same issue with my HP Pavillion dv4000. I do not have a "smalll button just above the touchpad". The spacebar is just above the touchpad.
Are there any other ideas on how to disable the touchpad?
Thanks
Posted on Jun 16, 2008
    Problem Solver:
  • 12 Answers
Problem with HP Notebook Or Laptops? Follow the links.
For Software problems you can visit a link by just Click Here .
For Hardware problems with this Notebook you can Click Here
Posted on Jul 23, 2010
    Problem Solver:
  • 5 Answers
Hello
Please perform the following steps to disable touchpad
For any touchpad
1. Click Start.
2. Click Control Panel.
3. Click Mouse.
3. Click Device Settings tab in the Mouse Properties window.
5. Click the Disable button.
6. Click Apply and then OK.
If the device settings are not there you need to check the a.net in msconfig for alps touchpad file and reinstall the drivers.
If your notebook has Synaptic Touchpad then there will be "synt" instead of "a.net" .
This should resolve the issue.
Thanks
Regards
If you think the above information is helpful. Then rate me.
Posted on Jun 22, 2008
How do i disable touch pad when mouse is in use
      Click the "Start" button and click "Control Panel." Click "Hardware and Sound" and click the "Mouse" link under Devices and Printers to open the Mouse Properties box. Click the "Touchpad" or "Buttons" tab depending on your PC, then select the "Disable" option next to thetouchpad installed on your computer.
      How to Disable TouchPad While the USB Mouse Is Plugged in
      smallbusiness.chron.com/disable-touchpad-usb-mouse-plugged-52685.html
    Feedback
    How To Turn Off Touchpad When Mouse Is Connected In ...
    www.intowindows.com > Windows 10
    Dec 14, 2015 - How To Turn Off Touchpad When Mouse Is Connected In Windows 10/7/ ... who always use a mouse and don't want to use the built-in trackpad ...
    How to Disable Your Laptop Touchpad ' PCWorld
Jan 31, 2016 | Toshiba Satellite C655D-S5120 Notebook
Why my mouse and touchpad are working at same time
Hi, you can disable touchpad while writing:
Go to Control Panel
Mouse( you can search it or you can change the view)
Then select your touchpad in the window which appeared
Then you should see options for your touchpad
You can find the option to disable it in there.
Jan 24, 2013 | Dell Inspiron Computers & Internet
Dell Vostro 1510 (Win 7) - Can't enable/disable the Touchpad
There is an option to disable the internal touchpad when you connect and external mouse. Please check the screenshot attached.
May 06, 2017 | Dell Vostro 1510 Laptop
I have a HP Probook 4421s and my touchpad is locked. How do I unlock it?
Two options
It may be set to automatically turn off if you have a mouse plugged in. Simply unplug the mouse. You may have to restart the computer after you unplug the mouse for the touch pad to turn on.
Option 2. go to the Start > Control panel > mouse
Click the touchpad tab to make adjustments. Make sure the touchpad is not disabled there.
You should also be able to disable the "turn off it mouse detected" feature on this tab.
Please rate me and good luck.
-Mark
May 05, 2011 | Computers & Internet
How to enable touch pad operation in ubuntu 10.04
Ubuntu provides configuration of the most common touchpad options in System > Preferences > Mouse, under the Touchpad tab.
Try the touchpad after unchecking the Enable mouse clicks with touchpad check box.
Check operation after Enable horizontal scrolling is checked. This may not have been the default setting.
Disabling Touchpad while Typing
  • Go to System > Preferences > Mouse > Touchpad and uncheck 'Disable touchpad while typing' and 'Enable mouse clicks with touchpad'
Feb 15, 2011 | Dell F3534 Touchpad
Toshiba u505 cursor jumps to other line when typing n
Hi.
Based on the information you have provided, it seems that the issue might be due to the Touchpad "Tapping feature".
This issue usually occurs when the Touchpad Tapping feature is enabled.
You may disable this option by following the steps mentioned below:
1) Click on the "Windows" logo icon. 2) Then, type "mouse" in the search option. 3) Click on the Mouse options which should be mentioned on the search list. 4) Once you have the Mouse options window open, click on the "Device Settings" tab. 5) Then, click on the "Settings" tab. 6) This will open the "Touchpad settings" window. 7) In this window, check for the "Tapping" option. 8) Once you have found that, disable that. 9) By doing this, you will disable the Touchpad tapping feature.
Hope this helps.
Please feel free to contact for further information and assistance.
Feb 01, 2011 | Toshiba Satellite U505-S2940 Notebook
I can not disable touchpad of INSPIRON 1545 of DELL Computers There is no option for disabling touch pad in the MOUSE option of Control Panel
Go to the Control Panel. Under the 'Hardware and Sound' options, click 'Mouse'immortal4u.png
Since you have a Dell laptop, you'll have a special tab called 'Dell touchpad' in the window that pops up. Click on the touchpad picture in the window.
In the new window that appears, click 'Device Select'
Click on the 'Disable' radio button to disable the touchpad completely. If you want to disable the touchpad of your Dell laptop only when an external device like a mouse is attached, check the last option that says 'Disable Touchpad/Pointing Stick when external USB mouse is present'
That's it. You've disabled your laptop's touchpad for good. If you don't find an option to manage your touchpad in Mouse settings, you have to install Synaptics drivers from here. Similar options can be found in other laptops as well.
Good luck ! if your problem is solved don't forget to rate
Dec 30, 2010 | Computers & Internet
How do I disable touchpad when mouse is used DELL 1525 vista home
Follow these steps to change the touchpad settings on your laptop:
1. From the Start menu, click Control Panel. With Control Panel in Category View, click Printers and Other Hardware.
2. In the Printers and Other Hardware window, click the Mouse icon.
3. In the Mouse Properties dialog box, click the Device Settings tab, and then click Settings.
4. There is a setting calleed "Disable Touch Pad when USB Pointing Device is present"
Jan 28, 2010 | Dell F3534 Touchpad
Disable Touchpad Clicking
Hiya, At the bottom right of the screen, by the clock, you should see an icon for the touchpad.....
Hint : Hover the mouse over the icons and wait for the "Pop-Up" Display to see what they do if your not sure.
When you find the one for the touchpad, simply right click it and scroll down to the option that says "Tap To Click" and left click it so that there is NO TICK next to it..........
........ This will DISABLE all tap click options and leave the touchpad as a touchpad and the buttons as buttons...........
Hope This Helps, Kind Regards,
Me :D
Mar 19, 2009 | Compaq Presario 700 470024-192 Notebook
Touchpad/mouse problem
Same thing here, I can not find out how to diable the touch paid. I spent an hour chatting on-line with Dell Tech support and they did nothing to help!! I am starting to think it can not be done on this machine. Please someone tell use how to do this?
Jul 10, 2008 | Dell F3534 Touchpad
HP Pavilion dv4000 Notebook Logo
980 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
