Question about Canon PIXMA MP530 All-In-One InkJet Printer
Fax The faxed paper has a line down the side
  • 2,012 Answers
If you use the automatic document feeder to make a copy, do you see the same line? If so, the scanner glass needs to be cleaned. Not the entire glass, just the small area to the left side that scans paper as it is fed through the automatic sheet feeder. Use a soft cloth lightly dampened with plain water to remove any material on this area of the scanner glass.
Posted on Jun 06, 2008
Do I insert the paper I want to fax face up or face down?
Having no Operating Guide, I'd type a one line sample, make a note on the paper like "face-up" and put it in with the paper facing up and hit "print".
If it prints on that side you have your answer. If it prints on the backside, then put your papers in facing down.
Jun 20, 2011 | Lexmark F4270 Plain Paper Inkjet Fax
No problem, but don't know if the print goes face side up por down into the printer when faxing
Where you put the paper must be a little icon like a page with lines, if you see this put the paper face up. I am surprise you did not check with a fax recipient to see if they got it (Blank paper or the fax)
Mar 18, 2011 | Office Equipment & Supplies
Line appears down right side of paper when copy is made?
If the line only appears when making copies but recieved faxes come out ok, then the scanner glass needs to be cleaned. Water and a lint free cloth should do the trick.
Sep 15, 2010 | HP 1010 Plain Paper Inkjet Fax
Black line down one side of paper
Lift the auto feeder cover and clean the narrow glass that the originals are scanned across...sounds like you have some dirt there -maybe correction fluid? That's the most common.
Please rate me :)
Jun 23, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Apr 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
When we recieve Fax, the paper is very dark
We had the same problem and we switched out the drum and now the faxes are very clear except for a solid black line going down the right side of the paper.
Mar 14, 2009 | Brother IntelliFAX 2800 Laser Fax
Faxing up or down
Look at the hopper. It will almost certainly have a little graphic on it to tell you which way up the document goes.
If it looks like a sheet of paper with lines of writing on, the paper goes in print side up.
If it looks like a sheet of paper with one corner folded over, and lines of writing visible only on the turned over corner, then it goes in print side down.
If you can't find the graphic, then experiment: Take a blank sheet of paper. Write "Up" on one side and "Down" on the other then stick it into the machine so the writing is telling the truth. Most fax machines have a copy mode - use this to see which side of the paper the machine reads (if you can't get it to copy, fax your page to somebody and get them to phone back to tell you which side of the page they've received).
A.
Jan 18, 2009 | Brother Office Equipment & Supplies
Faxes I send are reduced in size and have series of black line down right hand side.
If its reduced in size during transmit or copy then simply place a letter size document in the feeder and close the two sliders up to the sides of the paper. If you don't close the slider up to the paper it will go into auto reduction
Apr 27, 2007 | Canon LaserClass LC 8500 Plain Paper Fax
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
98 people viewed this question
old marine
old marine
