Question about Yamaha HTR-5830 Receiver
Component selection won't work
I hooked up new DVD player in the component video under DVD. To watch the DVD, receiver must be set to Cable/Dtv, but to use the remote to control the functions of the DVD player, it must be set to VCR, so you select scenes and such with no picture. I've had it two years, and this just started, whats up?
  • folderon Nov 12, 2008
    I have the same problem the DVD imputs video is on v aux and the sound is vcr and nothing on DVD
    Sergeant:
    Champion:
  • 297 Answers
Try to clean the connection checked the wire also if not cut...
Posted on Jun 19, 2008
Video Does not work on New Magnavox TV
Hi, it sounds like your problem is that you've selected the wrong "video input" for your DVD player. Your new television most likely has at least 3-4 (sometimes 6-7) different inputs for video. With your DVD player connected and turned on, press the "Source" button on your TV to cycle through the different inputs. Be sure to wait 2-4 seconds between selections to give your TV enough time to switch inputs. If your DVD player has "color coded" output cables, it's most likely a "component" video connection. See if one of your video inputs on the TV is called "Component". Some other video types are Video, DTV, HDMI, SVideo, Component, Composite, RGB, PC Input, etc...
Jul 24, 2013 | Sylvania SDVD7014BJ 7 in. Portable DVD...
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
Component video problem. Hi I got the Denon AVR-3806 receiver and has it hooked up with a component cable to my background projection TV. To the reciever I have a satellite box connected also with a...
Just fixed this myself - made my head hurt to figure out. 1. Switch to a setting (say DVD). 2. Watch the AVR screen as it switches. You'll see the audio and video settings. For example, Audio = DVD, Video = DVD (Mine showed Audio = DVD, Video = DBS even though is was set correctly using the SETUP for audio and video)3. Under the round control knob on the left, push the (tiny) Video Select button. 4. Turn control know to choose the correct video source
Your system should work right. Mine did.
Jan 03, 2011 | Denon AVR-3806 Receiver
Yamaha HTR-5750 no sound when I turn to the DTV/Cable setting
If you are not getting sound on "Any" input except "multi channel" you have a bad DSP chip in the receiver.In short, you need a new receiver, it's a 500.00 repair. If you get sound on "All" inputs except "DTV/CBL" You need to get into the main menu of the Yamaha and select audio, toggle to input, then DTV/CBL and select "Auto". If you still do not get audio, it would be due to the version of HDMI software in your receiver. If it's under warranty, Yamaha will update hardware and software for you at N/C. If it's out of warranty, use digital coaxial or optical as your audio input for TV and run your HDMI directly to the TV. (The repair for this too would run 250-350) I hope I've covered all the possibilities. If you need further help, post a comment and I can help you more.
Aug 25, 2009 | Yamaha HTR-5730 Receiver
Mintek 2110 no component video
You need to change the Video out in the menu.
Press set up on the remote
move down to video out and select YUV output
it should now work
Aug 08, 2008 | Mintek DVD-2580 DVD Player
Sony receiver
change yellow cable and try.
Aug 01, 2008 | Sony STR-DG800 Receiver
DTV Cable No Sound
Check if DTV/CBL is set receive COAXIAL or OPTICAL inputs. Good luck
Apr 09, 2008 | Yamaha HTR-5930 Receiver
No color or sound on DVD Player when hooked up with the ShowStopper
Svideo requires the audio cables too, Red and White. Svideo is only carries video.
Dec 30, 2007 | Panasonic PV-HS2000 Showstopper 30-Hours...
"No Signal" when DVD player is hooked up via component video
If you are using the same cables,same input and the cable box works ok. I would look into the settings of the DVD player. Such as is it a progressive playback and is progressive turned on. It is not turned on by default because not all TV's could handle progressive in.
Feb 07, 2007 | Zenith Z50PX2D 50 in. Plasma HDTV
Yamaha HTR-5830 Receiver Logo
62 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
