Question about Philips Magnavox 27MS343S 27" TV
CHILD LOCK LOCKED!!
HOW DO I GET IT OFF TO USE MY TV AGAIN??
  • vixen01 Jun 13, 2008
    What if you don't have the remote anymore and the child lock is on the tv? Is there a way to reset or unlock the tv?, or do I have to purchase another remote to watch tv again????? We had been using the cable remote to operate the tv, until the child lock somehow was set. PLEASE HELP, FOUR KIDS AT HOME & IT'S SUMMER!
  • 8,596 Answers
1 Press MENU to show the on-screen
menu.
2 Press VOL+ or VOL- repeatedly until
SET is highlighted.
3 Press CH+ or CH- to highlight CHILD
LOCK.
4 Press VOL+ or VOL-
to choose ON or
OFF.
Choose ON to disable all the buttons on
the front of the TV. CHILD LOCK ON
will appear briefly on the TV screen each
time you press a button on the front of
the TV.
You can still operate the TV with the
remote control.You can still use the
POWER button on the front of the TV,
but only to turn off the TV (not on).
Set CHILD LOCK to OFF to cancel this
feature so you can use the buttons on
the front of the TV again.
5 Press TV/AV/EXIT to remove the
menu from the screen.
Posted on Jun 07, 2008
Child locked on my tv
Possibly, you will need an original remote to disable or turn off this feature. And some child lock can be accessible through neither MENU of your tv or remote. Check CHILD LOCK option to remove it. If it is a screen lock type of CHILD LOCK feature of tv (a Blue Background display a LOCK icon) and your original remote is lost, try a universal remote for you to possibly unlock it. Thanks for using Fixya.
Apr 21, 2014 | Televison & Video
Tip
Polaroid LCD TV Parental lock/unlock
Program Lock
Input the default password of 1235, the submenu
of Parent will display if the password is correct.
(a) When changing the password, the changed
password will be updated after four digits are input.
The word "ok" appears after you input the same
number twice, if the two passwords are different the
word "Failure" will appear.
(b) When All Clear is selected, all programs are unlocked.
(c) After you exit from the Program Lock menu and switch to a locked channel, the picture and
sound will be locked unless you input the correct password. The channel will remain unlocked
until the TV is turned off. After the TV is turned on again, the password must be re-entered to
view the locked channels again.
(d) If your program is locked, input the correct password to enter the Auto Search submenu.
Operating Auto Search will cancel the locked status.
(e) The default password is always effective.
(f) Entering the default password allows you to go to the Program Lock menu, then change the
password while the default password is still effective. This branch menu cannot be entered if a
wrong password is keyed in, In this case, press MENU to return to the previous menu.
(g) There will be slight delays while using the Lock All and Clear All functions.
● Child Lock
In Child Lock On mode, the buttons on the TV do not work. A prompt "Panel buttons are being
locked" will be displayed. However, the remote control buttons will still function. When the TV is
on and the Child Lock is on, a prompt "Locked, power off after 6s" will appear. Use the remote
control to control the TV. Otherwise, the TV will automatically enter into Standby mode.
Having trouble with setting your Parental Controls (V-Chip)?
The factory preset password is 0000. This password must be used first before setting your own personal password. It is recommended that you keep your personal password in a safe place and away from children. In the event you loose your personal password the master password is 8202. The master password overrides all passwords. The master password can't be changed and should be kept in a safe place away from children.
on Aug 17, 2010 | Televison & Video
Logic locked tv is locked ineed apassword
Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
Dec 01, 2013 | Toshiba 32AF43 32" TV
It's a big screen tv and it say locked
I think that somehow the child lock has been activated somehow. Try this -PRESS MENU BUTTON THEN UP / DOWN BUTTON TO SELECT SPECIAL MENU THEN TURN CHILD LOCK OFF
Jan 24, 2013 | Televison & Video
My 14 inch Akai tv got tuning child locked..i removed the child lock by holding lock button. for ten sec.. but the child lock for tuning option wont go... help mee
Download the user manual to your tV from net, and refer it about how you can make a factory reset to this TV. Do it. It will make all things right.
May 12, 2012 | Akai CF2791 27" TV
Son lost remote for his tv and the child lock has come on how do i turn it off
THE SOLUTION FOR THIS FIX, AS IT WORKED FOR ME....I WAS LOCKED OUT BBY THE DUMB CHILD LOCK FOR TWO MONTHS, BOOUGHT A NEW REMOTE THAT DIDNT WORK....GET A 10$ REMOTE FROM THE STORE, AND ENTER CODE 0224 IT KILLS THE CHILD LOCK FEATURE..THEN YOU CAN POWER ON THE TV..GO TO MENU AND SELECT CHILD LOCK AND DEACTIVATE IT! THANKS ALOT MAGNAVOX..IT WAS NOT IN THE MANUAL FOR THE TV OR THE REMOTE FOR THE TV EITHER......CAPERS~
Oct 04, 2011 | Philips Magnavox 27MS343S 27" TV
MY TV IS LOCKED WITH A CHILD LOCK AND I LOST THE REMOTE TO UNLOCK THE TV PLEASE HELP.
Goto the near service center and a new remote of your tv brand and unlock your tv by child lock. its the simplest solution for your problem
Jan 06, 2011 | Televison & Video
Unlock child lock
Unknown password--ITC008 chassis with TV off press and hold volume down on the front of the tv and clear on the remote for 5 seconds
Apr 10, 2010 | RCA 27F650T 27" TV
My LG flatron golden eye tv got Child Locked -
dear sir,
my tv had gone child lock problem & one chenal show the tv. please slove this problem. because remote has been not working.
Sep 30, 2009 | LG Flatron 295LM 22" LCD Monitor
Child lock
my AKAI tv is locked. All i see is a blus screen with a little red lock on the bottom left corner! the only button that works on the tv OR remote is the power button on the remote. PLEASE HELP i have tried pushing every button but nothing happens
Feb 15, 2008 | Akai CTS2550 25" TV
Philips Magnavox 27MS343S 27" TV Logo
352 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
