Question about Hitachi Deskstar 7K80 Hard Disk 80GB, 7200RPM, ATA-6, 2MB Cache, Desktop, 20PACK (HDS728080PLAT200A3021020PK) Hard Drive
Burners cannot be read
My HDS728080PLAT20 after i did a clean boot reinstall, I have not been able to read either burners. Is there something I am missing?
Thanks Ron
Do a search for PC Fixer, a free tool. I had this problem on a Gateway I was trying to add this drive to. PC Fixer fixed the CD-ROM problem, but the drive seems to not be compatible with the Gateway for use as a master boot drive.
GC
Posted on Jun 19, 2008
The flames are uneven, i have the ceramic v shaped covers fror the burners, not charcoal or rocks. the heat is all at the back, it gets very hot there and is corroding the burners and the ceramic...
What you have is a bad case of clogged burners. At least the ends closer to you. This will require removing & cleaning the burners and the venturi valves (part of each burner) to thoroughly clean them
This will also provide you a closeup inspection of all the burners for any accessive wear, or rust thru.
Once the burners are removed, use a brass bristle brush to clean the exterior of the burners and then gently yet firmly tap them on something that want damage them, Then turn them so the open end is down and any debris will fall out. Also clean the Venturi valve on each burner. It will be on the burner tube, where it fits over the burner orifice. It will look like 2 slots (1 on each side) cut out of the burner tube. Spiders like to build nest in them. After you have completed all of that, reinstall the burners, turn the gas tank back on Very, Very Slowly and give them a test. You should see a significant difference.
Hope this helps you solve the burner problem. Please let me know and Happy Grilling!!
Jun 19, 2011 | Tuscany TGR30 Grill
There was a spark and then the power light went out on our 1973 electric cooktop. I had cleaning people in a few days ago who took the burners apart for cleaning. Could something just be loose?
Sorry to read about your problem, I hope this helps you out.
yes unplug and replug the burners..but you could have defective sockets
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Thermador Cooktops
My h22L/ns40 cant read anything. it working normal before I reinstal winxp on my pc. on win explorer its recognized as a dvd-ram drive only, but cant read. on device mangr the device work properly
Maybe it is the disks you are using. Perhaps a bad batch. Perhaps there is something patially covering the laser and inserting a cleaning disk could remedy the problem too.
Apr 18, 2010 | LG (DAD-8020B) DVD-RAM Burner
My lg dvd burner is'nt reading disc do i need to reinstall
maybe the iris is dirty, get a DVD cleaning kit and run it, a reinstall is unlikely to be the problem.It may also be a faulty Disc you have inserted have you tried others?
Please rate my help++++Thanks for using FIXYA
Nov 20, 2009 | LG GMA-4020B Super-Multi...
Laptop CD/DVD drive Can't read cd/dvd
Try cleaning the DVD with a CD drive cleaning disk.
Jun 28, 2009 | Compaq Computers & Internet
Uneven burners
you nailed it,you have to clean the burner ,and yes dont be afraid to soak it in soapy water in the sink to clean,the holes around the burner are blocked,could be from an accidental boil over,also clean the others while your at it,let dry and reinstall please rate this solution thanks
May 27, 2008 | Whirlpool GS460 Gas Kitchen Range
New DVD burner won't read blank DVD-r's.
Make sure your burner software supports your burner. Older software doesn't read and write the newer burners properly.
Jan 15, 2008 | Computers & Internet
Doesnt read it
Clean the lens normally the cause of you fault after that reinstall the drivers for it.
Thanks J
Dec 10, 2007 | Compaq (CDD480172) CD-RW Burner
Have multiple burners and neither are recognizing media anymore
Your plea sounds as if the Burners work pretty hard. It seems to me that you have laser burnout. There is as far I know noway to check this You will simply have go get a new one by hook or by crook. You could peruse this list to see if anything turns up. http://www.fixya.com/support/p489676-hp_dvd740ri_dvd_rw_dual_layer_burner
May 13, 2007 | HP (DVD740RI) DVD RW Dual Layer Burner
Computers & Internet Logo
111 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
