Monitor distortion monitor has major distortion like wave across the screen..the hard drive is constantly running to hard seems like it has something to do with it
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 265 Answers
Hey edwardaaron,
If you are encountering any kind of visible distortion on your computer monitor, there are a couple of things that I would suggest.
First, if you have a cathode ray tube (CRT) monitor, you may want to try manually degaussing the monitor. Whenever a CRT monitor is in use, it slowly builds up a magnetic charge that can interfere with its operation. Degaussing then, is the process by which CRT devices rid themselves of this excess magnetic charge. This is normally done whenever a monitor is first turned on, but many monitors will also have either a button on the front control panel you can press or an option in the main menu to perform a manual degauss.
In many cases, the degauss option will be marked with a horseshoe or magnet-shaped picture. Once you've selected this function, you may notice a metallic-sounding "twang" noise, followed by one or two "clicking" noises as the image on the screen is reset. Keep in mind that images on the screen may appear to vibrate and color may distort for a few seconds after you do so, but this is a normal part of the degaussing process. The screen should return to normal after a few seconds.
Second, interference can also be caused by placing your computer speakers too close to the monitor. Many speakers will produce a magnetic field of their own, which only adds to the magnetic field generated by your monitor. In this case, repositioning your computer speakers should help minimize the problem.
If degaussing fails (or you don't have a CRT monitor), you may wish to then test the cable connections to your computer. In some instances, simply replacing your monitor cable will resolve these types of problems.
You may also be encountering a problem where your monitor is simply set on the incorrect refresh rate. If the refresh rate is not correctly set, a monitor may display a "wavy" image or appear as if lines are periodically scrolling across the screen. Without knowing the exact make and model of your monitor however, I would not be able to provide any suggestions on how to change this setting - you would need to contact the manufacturer or refer to your owner's manual for specific instructions.
The worst case scenario would be if you are encountering an actual hardware failure. Both the video card and monitor can cause images to be distorted if they are not functioning properly, and even power supplies have been known to cause other components to sporadically malfunction. If you are unsure how to perform a hardware diagnostic, I would strongly suggest speaking with your local computer repair technician or a Geek Squad® agent at your local Best Buy™ store for further assistance.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 16, 2008
Toshiba 32AF45 CRT TV Distortion and Flicker During Moments of High Contrast?
Check its main power regulator section circuit. Replace all the electrolytic capacitors there. This is a power supply fault.
Mar 21, 2013 | Toshiba 32AF45 32" TV
Distorted Picture
Problem is likely main board (processes all signals) or even the power supply board is possible.
Considering brand parts may be hard or impossible to find.
May 16, 2012 | Dell W4201C 42 in. Plasma HDTV
W2753v screen flicker - refresh
Hi
What causes monitor screen to flicker?
Answer
keep electronics away from your computer. Mobie phones etc. can distort the image shown on the screen for periods of time, usually when a text or call is coming through.
Answer
A nearby device can cause stray magnetic fields that will cause the display to be affected.
A problem inside the monitor will cause the display to have problems.
If somebody turns on their monitor nearby, the monitor's degaussing when it starts up will cause your monitor to dance wildly for a moment or two.
Answer well one major cause can be the weakness of the electron gun that fire electrons on the silicon plate (pixels) that produces image on the screen so there must be some problem in electron gun in my view
Jan 29, 2010 | Computers & Internet
I have an HP 2009m monitor. When I try to have
The problem is that your picture is not of high enough resolution. You need to get a higher resolution picture. There is nothing wrong with the monitor. The picture is distorted because the picture does not contain enough photographic data to scale to the size you are stretching it to. Higher resolution = larger picture without distortion.
Jan 03, 2010 | HP 2009M Monitor
Red and green fuzzy waves across the screen
my screen just became distorted (red picturer to the upper right & green picture to the bottem left ? can you help me ? wuzuphippie55@yahoo
Sep 08, 2008 | Philips Magnavox 9P6034C 60" Rear...
Pixels?
Seems your screen is about to die unfortunately.
To verify this see if you can connect your PC to another LCD screen, if the problem persist it is not your screen but your PC.
In case it is your PC, just clean it out (blow compressed air to remove all dust from your casing) and reinstall driver displays.
Otherwise i'm afraid a new (or used) monitor will be mandatory...
Aug 08, 2008 | Acer AL1914 19" LCD Monitor
Distorted white lines running across screen
Disconnect the monitor from the computer and turn the monitor on
it will display a diagnostic colorbar are the lines still there.
if not they are likely a cable or video card.
if they are still there have a tech evaluate the monitor.
Dec 21, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
"Waves" generating from the right of the screen.
It's power distortion. If you move the monitor away from the pc, the waves will stop. It's magnetic distortion causing this interference. Your monitor is fine.
Jul 05, 2007 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor display
You might want to check the refresh rate in your advanced settings under display properites. Under Windows it shouls be something like: Start Button > Settings > Control Panel > Display Then click on the Settings tab, and on that screen click Advanced On that screen, click on the Adapter tab. At that point, make sure the adapter listed matches yours, and refresh rate should probably set to adapter default. Hope that helps.
May 18, 2007 | Dell E173FP 17" LCD Flat Panel Monitor
Faulty screen
You might need to replace the surface mount capacitors. measure the ESR on them, the higher it is, the more likely you are to get ripples. If this doesn't say much to you, take it to a lab. Use the warranty if you have it offcourse. Good luck
May 05, 2006 | HP D5060A (White) 14 in. Flat Panel LCD...
Computers & Internet Logo
382 people viewed this question
David Payne
David Payne
