Question about SimpleTech 160GB USB 2.0 / FireWire External Open Box (STIU2F36160OBB1) Hard Drive
Simpletech external harddrive
Drive has been working fine until the last time I turned it off. My computer had already shut down and I turned the power off the external drive. I needed to move the external drive. It made a clunking noise when I picked it up. It was no longer attached to the computer or power source. It will not restart. Blue light flashes on for a second, you hear a noise like it is trying to read and then nothing. The computer does not recognize it is there.
  • teasert1 Nov 24, 2008
    I haven't used my 160 gb simpledrive for a while, maybe a couple of months or so, and had to disconnect my laptop system to move it out of the room while we had company. Since I reconnected everything, nothing from the simpledrive at all! What can I do?
  • 6,831 Answers
Body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 27, 2010
I have a pininfarina simpletech 500GB usb external harddrive that does not show up in the My Computer folder of Windows Explorer. Tried hooking it up to a different computer with the same results; no...
If it is a new hard drive then it needs to be formatted. You can do this by going into your start menu - control panel - administrative tools - computer management - disc manager. I could be a little off on the wording as I don't have my computer handy, but in the disc management you should be able to right click on the drive in here and choose format. This will format the drive to be used. I hope this helps.
Sep 10, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
My Simpletech 500 gb external hard drive has been working fine for a long time, today it said something was corrupted and then the computer has not picked up on the drive, when you turn it on the blue...
Sorry, but that sounds pretty bad. Generally when a hard drive bricks, its done. However you can try taking it in somewhere like the Geek Squad at Best Buy, and have them try and recover all your stored data from it. Good Luck!
May 17, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
SimpleTech SimpleDrive 640 GB external USB harddrive wont turn on
Loose connection inside the Drive case. Remove drive and check internal wiring.
Dec 23, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
ST-500 not recognized with Epson CX9400 printer
Printer is draining USB power resource. Add a powered USB hub and run drive off of that.
Jul 23, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Simpletech 1TB USB not recognised properly
I had a very similar problem. It turned out to be a faulty case.
If the drive was formatted, there is a very good chance you've destroyed your data and may need professional services to recover the files (if possible)
Chances are you just needed to replace the external case by removing the harddrive from the simpletech case and installing it in a new case.
But again, if the drive's been formatted, it may have wiped out your data.
Jan 22, 2009 | SimpleTech 160GB USB 2.0 / FireWire...
Computer suddenly not reading external harddrive
I managed to fix it by unplugging the harddrive from the main electrical power source.
Nov 23, 2008 | Western Digital 500GB My Book World...
Simple tech 500gb usb hard drive
Youve damadged the harddrive, is the harddrive spinning or making any noise?
Jun 16, 2008 | SimpleTech SimpleDrive Pininfarina 500GB...
Simpletech 160 Portable doesn't show up
go into the control panel and click add/remove hardware... and manually add the device and then use the auto update to download the drivers
Jan 22, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Computers & Internet Logo
184 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
