Question about Toshiba 57H83 TV
Replacement Screen I need to replace the screen that covers the speakers on the bottom half of the TV. Can you tell me where to go to purchase it? Thank you Pat Bell
  • 4,234 Answers
As far as I can tell, the part you need is called the speaker grille and is the entire piece, not just the cover. The part number is: 23527269 and costs: $152.29. It is available from tritronicsinc.com
Dan
Posted on Jun 06, 2008
The top half of my Sony Bravia 32" screen plays as
I'm sorry, it sounds problem with lcd panel (screen) that is defective and causing lower half distorted image. If tv is under warranty then call number written on warranty documents for warranty cover or lcd panel (screen) replacement would cost you approx 80% of new tv price.
Hope these info will help you.
Thanks.
Nov 09, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a LG Plasma Flat screen TV. I purchased it
With seeing the picture it will be hard fro me to tell what..I am going to guess according to the information you've provided.
It could a buffer or a signal board(s). This TV is only 4 Months old I would call LG and file a warranty claim. LG (800) 243-0000
Best of luck
N Sabre
Nov 08, 2009 | LG 50PX5D 50 in. Plasma HDTV
I am looking for a replacement part for my Toshiba TV (model # 57H94), the bottom speaker cover.
What is the problem with the speaker cover? Is just the mesh damaged? If so you would have better luck replacing the mesh fabric yourself. You can purchase good replacement mesh fabric and adhesive at www.parts-express.com under speaker building supplies.
Oct 13, 2009 | Toshiba PSS421S TV Speakers
Panasonic TH-50PX20U plasma problem
There will be a fault with the plasma screen, you will have a dual scan type which is why it only covers half the screen. It is possible the flat ribbon connector to the screen internallly may have become loose7 needs to be re-fitted securely, but most often it is a replacement screen is required.
Sep 25, 2009 | Panasonic TH-50PX20U 50 in. HDTV-Ready...
Convergence on bottom half of screen only
Hi, this is convergence board failure. this is the reason for the failed alignment procedure and you will need to replace this failed board in order to restore full functions within the convergence options. i will Post a link to the actual part that you will need to purchase. this is a replacement board board and it can be delivered to your door via UPS.
CLICK FOR YOUR REPLACEMENT BOARD(CONV)
May 20, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
I want to take the screen off but i cant get the back off
Unplug TV, let it set unpluged for maybe a half hour or more (Just for safety) Pop off the speaker covers in the front of your TV, then remove the four screws under each cover, this will will remove the bottem face plate between the two speaker covers, then under that you find (I think four) more screws to remove just under the screen. Now if it is a BIG screen find someone to help you slide the screen up about two inches so that it will be released from the hooks on the inside. The screen is not at all heavy ( less than 5-10 Lb's) just flimsy and aqward. The screen is just a plastic frame holding two very thin plastic screens, one is a magnifing glass the other is vertical lines. If you must remove these from the frame,then as you remove the screen frame from the TV lay it face down and then remove the screws from the inside of the frame, Pay close attention to the way they come out if you put either one of them in backwards it will distort your picture and you will have to do the whole thing over again. The whole thing should only need a philips screwdriver and a half hour of time. GOOD LUCK.
Dec 27, 2008 | Toshiba 57H81 57" Rear Projection...
Phillips 42 inch Plasma -Screen Issues!!!
intermittent loss of picture on either bottom or top half of screen is specific to y buffer boards located on left side of screen going from top to bottom when looking at back of tv. the y lower buffer would be the board to replace to resolve the loss of bottom half of picture. if the top half also is going out intermittently could tied to upper buffer as well but just a note the y main board to right of these buffers drives those two boards so in some cases could also be part of the problem. if only bottom half is affected i would recommend replacing lower buffer only
Aug 07, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Half the screen has gone black
Ok first lets start with the half screen and no lit screen . Samsung plasma panels (S42AX-YD01) HD V4. are really bad about the Y-board (upper,lower) buffers are really bad about getting hot and burining up. If u remove the back cover of TV u will see on the left side the Y-board (it will be marked in small letters) if u look and the rows of IC's with heatsinks on the buffers will be a dark yellow. Majority of the time if u remove the buffers. and look underneath them u will see the solder has melted from the board. U can replace the Y-board and buffers and the TV will work fine.
Next part if u have vertical lines in the panel. There is not much u can do as a repair. Only thing u can do is get panel replaced. because there is and IC that is burned up on the panel, and trust me there isn't anything u can do to fix it. If u want to see for yourself. After removing the back cover, remove SSB, and brackets holding PDP in place. at the bottom of TV there is a row of buffers marked E,F,G, ( i think) there is a long heat sink covering the IC's at the bottom connected to the bottom of PDP. As u can see without a $70k machine to change this there is not much u can do with it. Hope this helps.
Dec 22, 2007 | Philips 42PF7320A 42 in. Plasma HDTV
Outer screen replacement
Lift off the speaker covers and you will see 4 screws around each speaker. remove those. Remove the plastic strip that goes across the bottom.
Also will see screws that hold the front bezel on the the Case, I believe there is 3, remove all those screws and lift lightly so you dont break the bezel clips.
Then put back together in the same way.
Dec 03, 2007 | Toshiba TZ50V51 50" Rear Projection...
How do I Remove Front Cover Screen of Hitachi 53SBX59B53 Projection TV???
Did you ever find the solution to removing the front screen? I have the same problem. Please write at superduper200554@yahoo.com
May 05, 2007 | Hitachi 53SBX59B 53" Rear Projection...
Toshiba 57H83 TV Logo
64 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
