Question about Sony Dvcam DSR-PD170 DV Digital Camcorder
No Power to PD170
Our 2 1/2 year old PD170 gets no power from a charged battery or from the regular and alternate power cords we tried! Does anyone have any advice? is this fixable?
Thanks,
Amy
    Guru:
  • 1,894 Answers
This can be due to faulty power circuit board.
you will have to look for any damaged components due to high voltage
Posted on Jun 06, 2008
  • Sony Master
  • 13,433 Answers
Most likely a hardware or a loose connection problem. Unless your willing to buy a service manual from somewhere and haveing a look inside - possibly replaceing parts. I'd reacommend you contact your dealer for details on a repair man.
Asus UL50VT always shows charging
Either your battery or the power cord has an issue. Does the battery ever fully charge and make the charging light disappear or turn green? If not the battery could be bad.
Try running the computer off the battery by removing the power cord. if the battery starts losing charging strength real quick then your battery is bad. I've see bad batteries that say they are 100% charged but as soon as you remove the power cord it gets down to 5% i a matter of minutes.
Try running the computer on just the power cord. If it stays on and lets you operate without any problem then the power cord is good. A good power cord will not charge a bad battery.
If the laptop does not let you stay on long with the power cord, then either the power cord is bad or the DC Power Jack where the power cord plugs into the laptop is bad. If either of them is bad they will not charge a good battery.
Check your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 06, 2012 | Computers & Internet
Asus always shows charging
Jun 06, 2012 | ASUS UL50Vt Notebook
My computer wont charge..could it be the power cord or the computer battery?
If the laptop is old think about changing the battery.
Stelios.
Feb 22, 2010 | Computers & Internet
I have a gateway pc laptop that is 3 years old. It was working fine this morning. I had to manually power it down because my screen was frozen.(this happens from time to time) When I tried to power it...
Try removing battery and power cord let the laptop discharge. Plug the power cord in without battery after 1/2 hour. If it repeats the same thing plug a regular monitor into the vga output see if you get picture if so it maybe a lose connection to lcd screen or bad lcd screen.
Dec 30, 2009 | Computers & Internet
Battery not charging
It could be the power cord if without the battery the laptop will not power up with the cord.
However, if it does power on, the power cord is fine and it could be a motherboard problem
Mar 05, 2009 | Acer Extensa 4620 Notebook
Need new LG AC Power Supply Model H-P 220
I had a similr problem It turned out that the power supply cord was not the problem, it was the main battery. Luckily, in 2000, I bought 2 extra main batteries. I took out the old battery and put in one the 2 new unused ones and my machine is working and charging perfectly now.
Jan 06, 2009 | LG Phenom Express
Battery indicator flashes even when plugged in to electrical plug, computer recognizes plug-in. Computer will not run with power cord.
The battery indicator flashing when plugged in to electrical plug means your battery is completely dead and won't charge. You're computer should run with just the power cord. Your power cord most likely needs replacement.
If you know anyone with the same model of laptop ask if you can borrow their power cord and/or battery to test it out. It is rare for the problem to be the motherboard, though it does happen.
It may just be the power cord at fault as the computer should run without the battery, so you should replace the power cord, as it is probably the reason the battery is completely dead.
If the battery is at least a year old I would replace it since they generally don't last too much longer than a year.
Sep 09, 2008 | IBM ThinkPad T40 2373 Notebook
Dell 600m Laptop Killing batteries
If you are using known good batteries, and you have the most current BIOS Flash, then it is likely a failure of the charging curcuit on the motherboard. The flashing Amber (Some people see it as red) led indicates a failed battery
The Multiple good batteries, I assume have been recently purchased, because computer batteries are consumable and are rated for 300 to 500 charging cycles before they wear out.
I replaced my 700m motherboard with one from Ebay for about $170.00 about a year ago.
Jul 05, 2008 | Dell Inspiron 600M Notebook
Battery not charging...
My impression is that you might have a defective cord if you still have your old adapter and has the same power specification try this first.
If the battery is hot and does not charge you might have a defective battery . Better have it checked at the service center before buying a brand new battery
Jun 23, 2008 | Toshiba Satellite A205-S4617 Notebook
Panasonic DVD Palmcorder (VDR-D100) 1.5 yrs old will not power up
Nope men... I have Just the same problem... I have a VDR-D105 and suddenly doesn't turn on... i was recording with a full charged battery and suddenly just turn off... forever :S
Jun 04, 2008 | Panasonic VDR-D100 DVD Camcorder
Sony Dvcam DSR-PD170 DV Digital Camcorder Logo
87 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
