Question about Dishwashers
Dishlex Global 500 dishwasher was relocated to a new house upon first run the display showed ND for no drain, the filters are all clean and can manually siphen water out through drain hose so i know there are no blockages. Was working normally prior to disconnection.
    Problem Solver:
  • 12 Answers
When running the drain hose it must be hung from the highest point under your benchtop before draining to the sink waste. ND is sometimes displayed when the hose is not mounted high enough
Posted on Dec 17, 2010
Dishlex global300 is gone into flood mode how do I fix it
Dishlex Global 300 Dishwasher issues - Kitchen - Home - Whirlpool ...
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolAug 31, 2011 - As stated in the title, it is Dishlex Global 300 model and it was here when ... is flooding about to happen inside the DW and prevents flooding). Bosch or Asko dishwasher
Mar 7, 2014
Dishwasher that actually WORKS PROPERLY?
Dec 3, 2012
Dishlex Global 300 dishwasher woes
Aug 8, 2005
Dishwashers ...
Mar 28, 2004
More results from forums.whirlpool.net.au
Nov 25, 2015 | Dishwashers
Starts to fill on normal cycle then stops and fast cycle light comes on
If it's like a Dishlex 300, the fast cycle light means there is a blockage in the drain line, somewhere. Check and clean your filters. Also, check your drain hose going to the sink for a blockage.
Nov 04, 2014 | Dishwashers
Dishlex 500 global. How do you take bottom drain
If you remove the entire dishwasher you will have assess to the hose that runs up to the sink drain and to the bottom of the dishwasher. I don't know if it comes apart but if you fully remove it you will get a better look.
Sep 10, 2014 | Dishwashers
I have a dishlex Global 500 which runs for 3-5 minutes then displays nF
nf= not filling. check inlet vale, or fault will be with pressure switch. If you have poor water pressure, you may need to increase the fill time- insructions can be downloaded from:www.electrolux.com.au, click on "customer service", then "download manuals", then Dishwashers-semi integrated, electronic, then download Dishlex Global Part 1 and Part 2.
Information on setting fill time can be found at the back of Part 2, but Part 1 has a list of the fault codes
Aug 05, 2009 | Dishwashers
Dishlex global 500 rinse and wash problem
This was due to a faulty pump motor which I have now replaced.
Jan 10, 2009 | Dishwashers
I have a dishlex global 450. it shows ND. what does this mean? It also has water at the bottom of the dishwasher.
Hi and welcome to FixYa,
Offhand, error message "ND" refers to "No Drain" and therefore would require that the drain system be checked, cleaned and inspected for any faulty components. Normally, there would be a drain filter, a sump or sorts, a valve, an impeller and a pump that leads to the drain hose. Access to these components would be through removal of the bottom/kick panel. Further the presence of water at the bottom of the dishwasher indicates that the water is not being flushed/drained out but is leaking from any of the above.
Unfortunately, this is a very messy job.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 15, 2008 | Frigidaire 24 in. FDB126RB Built-in...
I have a dishlex global 450 and it shows ND. what does this mean?
theres a round plug in the top of dish washer pull it out and clean could be cloged or the bottom spram arm can be pulled out and cleaned aswell
Aug 24, 2008 | Electrolux 18 in. ESL4114 Slim-Line...
Thomo, make sure the sprayer holes in the spray arms are clean. Grains of rice seem to be a dishwashers biggest enemy as they don't desolve and eventually end up lodged in the spray holes. The holes at the end of the spray arms are the ones responsible for the washing out of the soap powder from the dispenser, if they are blocked this does not happen.
Hope this helps
Cheers
May 29, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Tank is leaking
Is it the tank or just the door seals? Ours was leaking recently, there was an obvious tear in the door seal. Once fixed no probs.
Nov 02, 2007 | Electrolux 23 in. ESL624 Built-in...
Dishwashers Logo
692 people viewed this question
Top Dishwashers Experts
