Question about Westinghouse SK-32H590D Television
DVD Stuck inTV/DVD combo unit
My DVD got stuck with no way to eject it with the remote or the eject button on the TV. No hole found for a paperclip to try either. BUT found another post where someone unplugged the power cord at the back of the TV and plugged back in and magically it ejected once I turned he TV on! Brand new TV so dont know if this could be a concurrent problem though...
  • Anonymous Apr 03, 2009
    Thanks! This worked wonderful! I have the same television and have been trying to figure out how to get the dvd out for weeks... did this and BAM. It worked like a charm. :)
Same here.  Had the TV for about 6 months and had a DVD get stuck for the second time.  Used the same method of unplugging and plugging back in.  Then hitting the Stop/Eject on the side and it came out.  When plugging it back in I could hear the DVD "engage".
Posted on Dec 25, 2008
Tried this it worked thanks
Posted on Jan 19, 2009
Thank you so much, it worked right away~my daughter was so upset her movie got stuck in our brand new TV and mommy was freaking out at the thought of having to take the TV back to the store!
Thanks again!!
Posted on Jan 29, 2009
Unplugging and plugging in tv worked for our stuck CD as well! THANK YOU!
Posted on Jul 03, 2010
Thanks! Just tried it and it worked!!!
Posted on Apr 28, 2010
This worked for me too, thanks!
Posted on Aug 25, 2008
Dvd won't eject from tv/dvd combo stuck
Try looking for a small hole where the DVD goes in the TV about the size of a paper clip. Some of the times like on a computer there is a small hole that you can put a paperclip in and push on an internal button and this will release the DVD.
Jan 06, 2014 | Proscan Televison & Video
DVD stuck in tv combo player
There should be a very small hole or opening on or near the DVD drawer. Straighten a small paper clip to insert in the hole. It should trip the drawer open.
Dec 15, 2013 | RCA 26LA30RQD 26 LCD TVDVD Combo
Dvd stuck in tv/dvd combo
There is sometimes a pin hole in the front of the device near the tray, you push something very slender into it and it opens the disc tray. If This doesnt have that feature, you may need to manually dissasemble to retrieve your disc.
Sep 20, 2012 | Sanyo Televison & Video
Dvd is stuck in tv/dvd combo
here you can mess the unit up completely if your not carefull,,some of the many different types of system unit have a small hole on the door itself,carefully power on then push a straightened paperclip into this hole,,if you can find one that is,,your only other options would be to use a very flat knife and try to time pressure on the door in conjunction with the power on button the door itself is ,or can be operated by internal cog mechanisms which can break easily--good luck--Davey
Jun 18, 2012 | Haier HLC19R 19 in. LCD TV/DVD Combo
I have a flat screen TV with a built-in DVD player. It plays DVD's even though there is one stuck in it. How do I get the stuck DVD out?
Below the slot, about an inch down, and about inthe center- look for a small hole that does not match the pattern of the plastic- this is the manual release button- insert something like a stip pin into the hole gently until you feel it land on something about 1 centimeter in, and push- you should feel the mechanism move as the pin is pushed in further until it stops.
The machine should eject the disk. There is also an eject push button on the side of the set buried with the other buttons. I assume you already tried the blue button on the remote.
Sep 14, 2011 | Westinghouse W4207 42 in. HD-Ready LCD TV
Dvd stuck in RCA widescreen tv
There are two things you can try to correct this problem on your TV/DVD combo unit:
  • If you're using the remote control, press the DVD/TV button first to make sure the remote control is in TV mode.
  • If you're trying to use the buttons on the front of the unit, unplug the TV/DVD for two minutes, and then plug it back in. Press the ON/OFF button and try again.
Feb 20, 2010 | RCA L40HD33D 40 in. LCD HDTV
I have a dvd stuck in a toshiba tv dvd combination
Try a reset on ur tv,Like unplug ur tv an hoour.Replug it back.Should get power to the DVD port to take out the DVD disk.
Feb 08, 2010 | Toshiba 23HLV87 23 in. LCD Television
We have a Audiovox KLV3913 under cabinet tv/dvd combo that has a DVD stuck in it. Push the open/close button & "Open" shows on screen but door never comes open. No longer have manual & couldn't...
There has to be a small hole at the front of the door where u will be able to insert a paper clip and press then dvd shud eject. If not open door with a paper clip and manualy pull the drawer outwards, though be careful and do it slowly thus not damaging the gears of the ejection system. hope it helps. regards.viv
Dec 23, 2009 | Audiovox KLV3913 12 in. LCD TV/DVD Combo
A dvd is stuck in the dvd player of my polaroid combo tv/dvd player
if you will look under the drive where you put the dvd in there is a little pin hole push a small paperclip in there and the dvd will pop out
Jul 20, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
DVD stuck in tv combo unit
Had same problem! Husband took back off tv, lots of screws, unscrewed the dvd player and turned it over. There is a white wheel, turn that slowly. It opens and closes the dvd "tray". He turned it until DVD came out. Tried another DVD but no good. Had only used the DVD once since owning tv. Won't use it again.
In the past we would not buy combo units. Won't ever again!!!!
Jan 31, 2009 | Westinghouse SK-32H590D Television
Televison & Video Logo
1,064 people viewed this question
Top Westinghouse Televison & Video Experts
Dave Naylor
Dave Naylor
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
