Question about Kenmore 45081 Front Load Washer / Dryer
Kenmore All in One?Dryer Heat Minimal?Excessive Dry time
Greetings,
I just hooked up the All In One, I got from a friend—after completely cleaning all interior surfaces of lint—from years of neglect. The unit is sound, and washed two loads efficiently. The back wall of the dryer became hot to the point of 'un-touchable,' but the load of lightweight items (t-shirts/pyjamas)—took forever to dry. The vent output was warm, the lint collected on the screen, normal.
The items in the dryer were never HOT when I checked the load; not even a little. It was as if ONLY the backwall was being heated by the element.
What do you make of it?
Thank you for your consideration.
Brian Byers
North Hollywood, CA
    Genius:
  • 1,028 Answers
Be sure vent to outside is not plugged or partially block be sure vet tube in back is not compressed flat or folded basically be sure you have good air flow to outside to take the moisture to the outside away from the clothes
Posted on Jun 07, 2008
My kenmore elite HE5 gas dyer won't dry properly. It will heat but not as well. It take along time to dry. Sometimes I have to dry my clothes twice before they will get completly dry. What could this...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Aug 16, 2011 | Dryers
Kenmore Gas Clothes Dryer does not heat sufficiently
Ok, first and foremost, make sure your vent is clean and clear.
If the vent is clean and free of obstructions the most likely culprit is your gas valve coils. When they fail the typical symptom is heat at the beginning of the cycle and no heat about 20 minutes later.
If you can, post the complete model number from the dryer and I will give you step by step tear-down and replacement of parts instructions.
Jun 27, 2010 | Kenmore 63942 Dryer
I have a kenmore HE2 dryer and matching washer. It is 3 years old. It works and eventually clothes do dry. It does heat up. But it doesn't heat up as hot as it used to and it takes twice as long to dry...
Make sure you check your exhaust line and where the air blows to the outside. If your exhaust vent or hose is bent or restricted it will take a very long time to dry the clothes. Sometimes the vent flap on the outside exhaust is stuck shut. Clear dryer exhaust venting is critical for proper operation. Several companies offer a vent cleaning service where they completely clean out the exhaust lines.
Feb 02, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore elite 110 62974100, it heats up and the
kenmore dryer elite he model 110- runs but has no heat
Oct 08, 2009 | Kenmore Dryers
My kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Oct 05, 2009 | Kenmore 73952 Gas Dryer
Dryer takes long to dry cleaned vent hear burner go on but not for long thi is a gas dryer kenmore 70 series
to know if the vent is for sure cleaned unhook the dryer and start in timed cyc using high heat and see how long it runs does it run longer than when hooked up to vent if so vent is still restricted if not then the blower housing/lint screen is also plugged
Sep 10, 2009 | Kenmore Dryers
Kenmore dryer will not dry completelt in even heat cycle
This video will help you to determined what you need,
copy n paste
http://www.youtube.com/watch?v=HRKIU4LiS20&feature=related
for parts n prices
http://www.partselect.com/AppliancePartList.aspx?Brand=Kenmore&Appliance=Dryer&ModelNum=&Type=Electrical%20Parts,%20%20No%20Heating%20Elements&MinSize=U&MaxSize=U&Electrical=Y&Metal=U&Plastic=U&OneColor=U&PageSize=15&FirstPart=1
Was this helpful?
Apr 29, 2009 | Kenmore 63942 Dryer
Kenmore gas front load dryer.Very little heat, takes 3x to dry
Check your heating elements. check the outside exhaust door is it open.
Feb 20, 2009 | Kenmore 93142 Gas Dryer
Kenmore Elite HE4 Electric Dryer - heat but not drying
you have thermistor failure/ located inside machine reason for premature heat
Oct 07, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 90 series gas dryer, NO HEAT!!!
Hi, if you get no glow on the ignitor and you have voltage its the little white two terminal fuse on the exhaust side that has no continuity on the series 80 it has 2 blue wires, these complete the circuit for both gas valves and the ignitor. If you have an ohm meter it you will find it rite away. Hope this helps.
Mar 21, 2008 | Dryers
Kenmore 45081 Front Load Washer / Dryer Logo
59 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
