Question about Canon PIXMA MP760 All-In-One InkJet Printer
No power not getting power to my printer. checked both ends of the cord- seems to be fine. please help
  • Anonymous Aug 13, 2008
    yes the same problem happened to my MP760. The unit is completely dead
    Genius:
  • 2,785 Answers
If you have adapter then check it, otherwise the printer powersupply is to be checked
Posted on Jun 06, 2008
Tv turns off and on over and over
Hello, This may seem kinda silly but please check that the power cord is fully seated into the tv's power socket. Just remove the power cord from the TV, and re-insert it back in. Also verify that the other end is fully seated into the wall outlet or extension cord!
Good Luck
Rich Lilja
Dec 20, 2013 | Sony KDL55NX810 55 inch 1080p 120Hz 3D...
Error 931
In most cases this error has something to do with the printers LVPS (Low Voltage Power Supply ).
If the printer is connected to power surge, try to connect it to an outlet from the wall. Do an An AC power check - check the AC line voltage at the end of the AC line cord. If the Ac line cord is incorrect, replace the cord.
Also check if the cord is in good condition. if not, replace the cord. If you still get the same errror, you may need to replace the printers' LVPS.
For further assistance assistance please contact Lexmark Technical Support.
Feb 09, 2012 | Lexmark C750 Laser Printer
I cannot turn the printer on
These are the possible solutions:
  • Press power button.
  • Disconnect and reconnect the power cord. Plug the printer's power cord straight into an electrical outlet that other electrical devices have been using. Bypass any surge devices or power strips.
  • Unplug the power adapter from printer (rectangular black box inserted in the printer where the power cord is attached). With the power cord attached to it and other end plugged into the power outlet in the wall, check if it's warm/hot but not too hot, that means it's working fine.
If these does not help, it could be a possible defective power adapter issue. Please contact Lexmark technical support for additional assistance. Thanks.
Dec 14, 2010 | Lexmark X4690 Wireless InkJet Printer
I need a replacement cord for my printer, I have the power cord I need the one with the phone jack end that plugs into the printer. Where can I get one?
That would be called an "ethernet" cord, especially if it looks just a little larger than a regular phone cord end and the cord itseld seems just a bit larger, too. It can be found at any major office retailer like Staples, Office Max....ad infinitum.
Regards,
Selk
Oct 19, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
My HP C6150 All in One printer. Was printing just fine...then at once it lost the ability to print in black. A word document has to have the font color changed to, let's say navy blue, and it prints...
Hello and Welcome to FixYa!
Please do cross check that the newly installed ink cartridge is genuine and is installed properly in the printer... Try performing a reset by the following procedure...
1. Unplug the power cord from both ends of the printer.
2. Wait for 2 minutes
3. Reconnect the power cord to the wall outlet. Do not reconnect the other end to the back of the printer
4. While the other end of the power cord is still unplugged, hold the pound (#) and six (6) keys on the printer.
5. While holding pound and six, reconnect the power cord to the back of the printer and after two seconds release the two keys.
6. Wait until the printer will turn on. If not, press the power button to turn it on.
If the problem still persists, then it seems that the print head assembly got alignment problem, and need to visit the repair center for physical repairing of the unit or buy a new unit....
Hope this clears the picture a bit,
Please do RATE the solution, if this helps you,
Concerned.
Jul 29, 2010 | Office Equipment & Supplies
Brand new brother HL-2140 get service call error (all lights flashing for more than 10 minutes). First time to setup. Don't know how to proceed.
You should have a manual with your new printer, please read it before doing anything with your printer. I'll try my best to show you how to set it up properly for the first time. Make sure to plug the right cable at the right place. There should be 2 basic cable for your printer to work properly; the power cord and the USB cord. Power cord is thicker than the USB cord (black). One end goes to the printer and the other to the power outlet. The USB cable is the data cable of your printer (white/transparent). One end should go to the printer and the other to the PC. First, plug the other end of the USB cable to the printer and the other end to the PC. Next, plug in the power cable to the printer going to the power outlet. Press the power button and you can now use the CD that came with the printer to install the driver. If the lights still persist, then check the toner and the tray. It should be properly fitted inside. Also check the paper, there could be a paper stuck inside.
Hope this helps . . .
Nov 08, 2009 | Brother HL 2140 Laser Printer
I need to know what cords do I need to hook up my printer to my laptop, I can't get the power light to come on
Probably a USB cord. I believe this printer has a separate power supply.
Printers do not normally come with the USB. The good news is you can buy this cord just about anywhere. You should know, there is a special USB cord for printers - one end is smaller than the other end - the smaller end goes into the printer.
If you need software, please go to www.lexmark.com/support
I hope this information helps you.
Thanks for visiting fixya.com
a
Oct 25, 2009 | Lexmark X1270 All-In-One InkJet Printer
Cannon i80 printer will not turn on, appears dead
Take the adapter back to the guys at radio shack, they should be able to find what they missed or did wrong the first time.
I suspect the adapter is the power supply and plugs into the wall. That's the item that wouldn't let it turn on, it's either shorted or one of the wires are no longer connected.
The Vanguardian
Aug 26, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Says no paper-its full
Please follow the follwoing steps,
1) unplug the power cord at the both ends from the printer and wall outlet. connect to wall out let directly dont connect to
printer.
2)Press and hold # and 6 while reconnecting the power cord to the product hold for 1 min after plugging the power cord, and
then release both buttons, if your printer goes off then turn ON the printer and it will reset itself and will print a allignment sheet, this should resolve the issue.
Regards,  raj_p5983
Jan 23, 2009 | HP OfficeJet J4580 All-In-One Laser...
Black does not print out correctly
printer.
then release both buttons, this should resolve the issue.
Regards,  raj_p5983
Jan 21, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Open Questions:
See all Canon PIXMA MP760 All-In-One InkJet Printer Questions
Canon PIXMA MP760 All-In-One InkJet Printer Logo
83 people viewed this question
old marine
old marine
Corne Viljoen
