Question about D-Link AirPlus G DSL-G604T (790069265662) Wireless Router
Apple Mac Do you know whether this works for a Mac and how to set the whole thing up.   Also each time it goes through setup on my windows based laptop it never completes the set up as it times out.   I use telstra bigpond ADSL.
  • 600 Answers
I used one of these in the UK follow the directions in the manual, the makers website will have a pdf to read.
Posted on Aug 13, 2009
My desktop has a local area connection with limited to no connectivity. I had my desktop pc connected to a netgear n900 router and a vonage phone connected to the router's lan1 port. This caused i
Did this connection ever work before? I have a similar setup with Iristel and once in a while it goes down (Hurricane Leslie generated the problem last week).
Check whether the setup works without the Vonage device. This will tell you whether the problem is with your router or the Vonage box. If it works without the Vonage, the problem is in the Vonage box, you may find a good time to call Vonage for support.
I don't know whether the Vonage box (in my Iristel case it's a mediatrix 2 something) has to 'call home' before it lets your router set itself up.
If your router does not work without the Vonage, you have a simpler problem, the router is the issue. You can reconnect the Vonage and if the phones work, this confirms that the router is the problem. At least you can use the phones.
With the router, you need to log in to the admin screens and poke around until you find the problem. It is always a good idea to only change one thing at a time and always remember what changed immediately before the problem was noticed.
Sep 16, 2012 | Gateway Computers & Internet
Unable to Configure the Airport Express wireless using HP Pavillion running with Windows Vista
IN WINDOWS YOU CANT RUN MAC (APPLE) APP THIS FOR MAC SYSTEMS LIKE IPOD,IPHONE,MAC PC,ETC...
Mar 29, 2012 | Apple AirPort Express Base Station with...
No sound is heard with calls on Skype, I get video, and i hear sounds made by the program, but no sound from the recipient of the caller. I get sound when I video chat Mac to Mac, but not Mac to Windows,...
Ok, by the sound of it both yourself and whoever you're calling have not set up Skype quite right.
On your end, you need to:
  • Make sure you have a working microphone - try using Skype's built in 'Echo' feature (try calling 'echo123')
  • In Skype -> Preferences -> Audio, make sure that microphone is selected.
On their end, make sure they've done the same - they must have a working microphone, correctly setup with Skype in order to send you sound.
Hope that helped!
Jan 18, 2011 | Apple Customized 15" MacBook Pro Laptop...
Trying to update firmware on y airport extreme but i forgot my password
You need to perform a soft reset of your router. There directions to do this from the Apple web site are:
  1. Connect the AirPort Base Station or Time Capsule to power.
  2. Press and hold the reset button with a pen or pencil for 1 full second, then release it. The light (LED) will begin flashing amber, indicating that the AirPort Base Station or Time Capsule is in soft reset mode.
  3. From the AirPort menu bar item, choose the network created by the AirPort Base Station or Time Capsule (the network name does not change).
  4. Open AirPort Utility in Applications > Utilities on a Mac using Mac OS X, and in Start > All Programs > AirPort on a computer using Windows.
  5. Select the AirPort Base Station or Time Capsule and click Continue.
  6. A window indicating that the device has been reset will appear.
  7. Select "Restore the previous settings" and select OK.
  8. Move through subsequent windows to make changes to your passwords or other settings as desired, clicking Continue after each one.
  9. When you have moved through all of the selection windows you will be able to select Update. Click Update to install the new settings.
  10. Click Continue to allow your AirPort Base Station or Time Capsule to restart.
  11. Quit AirPort Utility.
These directions are from the Apple Support Web Site:
http://support.apple.com/kb/ht3728
Jan 02, 2011 | Apple AirPort Extreme Base Station
Used bootcamp and tryed to install windows and got disc error ,now wont go back to normal statas. how do i fix?
Insert the Mac OS disk in the drive and reboot while holding down the C key. This will launch your computer in Mac OS and then you can access Disk Utility from the startup window.
Rebuild/ repair as needed, then I suggest removing any partition that you may have set up and re partition your drive for the windows stuff. Give yourself ample room on the harddrive for your windows software and files.
Be sure to print out a copy of the instructions for bootcamp before you launch... also be sure to allow it to automatically set up your mac for windows. Do this:
1.set up a partition according to the directions for bootcamp
2. install windows as per bootcamp instructions
3. after it's launched in windows, insert the Mac OS disk and it will launch all the setup for your mac hardware to run windows... modem, wifi, all that mojive that you usually need to spend hours in PC land ..mac will set it up for you.. Also download a copy of Bonjour from the Apple site. this will set up your printers for use in windows very easily and quickly..
The main thing is follow the directions and let the computer do all the setup...
May 21, 2010 | Apple iMac (MA876LL) 20 in (MA876LLA) Mac...
Choppy mac videos and speech on my mac
Your computer was dimensionned for Os 9 and is globaly a little bit weak (sorry) to read full screen videos and 16 bit sounds. on the internet (apple.com and youtube) the videos are over compressed to fit in small connections. But reading .avi or .mp3 necessits hard computing. (sorry for my english)
Mar 20, 2009 | Apple Computers & Internet
SYSTEM SLOW TO LOAD, OVERHEATING AND CANT GET DRIVER
you can hold down the option key while you start up the computer. It will give you a grey screen and give you choices of startup systems... Choose the Mac OS and see if the start up is quicker. Sounds like the windows xp setup isn't working properly. I'd think elimination of the existing pc partition on the hard drive while running in mac mode and then running Boot Camp according to apple's instructions. Boot camp is on the Leopard OS disc and will get your computer ready to instal windows xp with an authorized xp disc. After it's up and running in windows xp, you can reinsert the mac os disc while running windows and the drivers will be installed for you...it works great... Plus you can download a copy of apple's bonjuer software and it will help you set up your printers to work on your mac as well.... Good luck and let me know if you need more help... KEN
Mar 03, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Is there an equivalent program on apple like regedit?
Apple has files that contain the same type of info as the windows registry .
They are referred to as .plist files.
Example:
/Users/YourUserName/Library/Preferences
There is not a typical registry.
Nate P.
Jan 13, 2009 | Apple Mac OS 9.2.1
INSTALLING A CANON D320 TO A MAC
install mac support driver and make a copy
Oct 07, 2008 | Canon imageCLASS D320 Laser Printer
D-Link AirPlus G DSL-G604T (790069265662) Wireless Router Logo
51 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
