Question about HP LaserJet 3050 All-In-One Printer
HP Laserjet 3050 No paper pickup
I am getting the message No paper pickup on HP Laserjet 3050. No apparent paper jam. Removed ink cartridge. turned of and back on printer. Checked for paper clips or staples. nothing working. can you help
My printer now spits out the paper all over the place and jams up all the time. Did not happen when I first got my 3050 a few months ago.
Posted on Sep 26, 2008
Hi all,
Pls toner and check any thing like small peace of paper in the fuser from were the paper comes out.
check if printer gets initiolised when u turn the printer on.if all these things are working and there no paper jam then take your printer to nearest service center it can be issue with solonied.
Posted on Oct 04, 2008
  • 35 Answers
NOTE:
If the printer DOES NOT PICKUP paper .
That is a jam also so the places to look are smoth rollers or smoth spots on the rollers.
trays not adjusted properly and if they have it some trays have a coustom/standarsd switch (should be in standard for letter/legal paper
Posted on Jun 13, 2008
It could be of dust particals on printer's plastic kind of thing looks like xray paper just clean this and restart your printer - it works
Posted on Nov 18, 2009
My HP 3050 Laser printer is not recognizing the print cartridge. I had a paper jamb and the error message started. I have tried to power down the machine, reinstalled a new cartridge, removed and...
Hello, If your cartridges are not empty, but you continue to receive the 'Ink Cartridge(s) are Empty ' error message, follow these steps to override the message. Disconnect any cables (Ethernet cable or USB cable) that connect both the printer and the computer. Restart your computer. (Consider bookmarking this page in your Web browser so that you can easily return to it after the computer restarts.) With the printer turned on , remove the power cord from the back of the printer. Wait 30 seconds. Insert the power cord back into the printer, and turn the printer on. Clear any error messages. Reconnect any cables that connect the printer to the computer. If the above doesn't solve the problem, you will have to download Hp diagnostic utility on your your computer, install is on your computer and it will help to detect and solve the problem. Visit the hp link below, read all the information on the page and download the diagnostic tool from the page. Click here: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02114788&tmp_task=solveCategory&lc=en&dlc=&cc=us&product=441125 Keep me informed if none of the above seems to solve your problem. Good luck.
Jul 11, 2011 | HP LaserJet 3050 All-In-One Printer
Doc feeder jam (hp 3050)
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 17, 2010 | HP LaserJet 3050 All-In-One Printer
My HP LaserJet 3050 will not grab and feed paper from the paper tray but will print on single fed sheets when fed to the input above the paper tray. What is wrong?
Open the top as if you were going to change ink cartridges. Find all rollers yuou can and wipe them with a t-shirt type material dry. Do not use any liquids unless you can get some rubbing alcohol. Turn the wheels and claen them as best as is posible. Open the paper jam door and do the same to all rollers in site. Any way you can get to the rollers, use it. This should solve your problem. Also try fanning your paper before loading it. Thanks, Dana
Sep 04, 2009 | HP LaserJet 3050 All-In-One Printer
My printer had a paper jam. Once removed it now
maybe the problem is on your paper feeder have dust.
Jun 06, 2009 | HP LaserJet 3050 All-In-One Printer
Paper jam
try this....
try this, its probably a small part of jammed paper or then theres a problem with the pickup, try cleaning it.
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jan 19, 2009 | HP LaserJet 2820 Printer
I have a m3027 mfp hp printer top feed won't grab
turn the power off.remove ink cartridge then check there is not any paper jam.aslo check in back side of printer for paper jam .also clean your ink cartridge try other ink cartridge.
Jan 05, 2009 | HP LaserJet M3027 MFP Printer
No paper pickup press
a solution was found to this at http://www.devincollier.com/2009/02/14/hp-laserjet-3050-no-paper-pickup-solution/
there is a spring that has become unsprung.
Article has pictures
Apr 22, 2008 | HP LaserJet 3050 All-In-One Printer
No Paper Pickup
turnoff the printer n reseat the tomer catridge properly ,take care it should not be tilted on side,check it that it seated properly,power on the printer n check ,can u hear any motors moving sound,if yes check the printer now,if not check for any peice of paper inside the printer especially from where the paper comes out
do revert
thnx
Jan 25, 2008 | HP LaserJet 3055 All-In-One Printer
No paper pickup
Hi , I just had a same problem with the HP Laser Jet 3055 printer at our office but I fixed it! try this:
Open the printer door.
Remove the Cartridge.
Look down behind the cartridge, there's a small white roll. Try playing with it. move it back and forth. try emptying the paper tray and place it back in the printer.
Turn on the printer.
I did this and for some reason it worked! GOOD LUCK!
Jan 22, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3050 All-In-One Printer Logo
3,839 people viewed this question
Seeker5211
Seeker5211
