Question about Mitsubishi VS-60805 60" Rear Projection Television
Fullscreen HD? My new HD box is sending a fullscreen signal to the TV but the aspect ratio is only 16:9. Is there a way to activate Fullscreen HD in the DTV setting or a way to trick the TV using the DVD component setting?
  • Robert Johnson May 11, 2010
    what is the box? cable box? off air box? sat box? hoiw is it hooked up to the tv? is there an aspect or format button on the remote? is the box outputing 1080i or 480i?
    Sergeant:
  • 395 Answers
Check to see if the box has a tv type setting in it's menu since I don't know what the model of the HD box is it must be in the user manual on how to set this up. it is not the tv that is the problem.
Posted on Jun 17, 2008
Can I change any settings so FullScreen doesn't go outside the screen and cut off the image?
get the on screen menu up , then find aspect ratio and use the volume control buttons to change the ratio until the screen and picture match , click ok and exit
Dec 11, 2015 | Televison & Video
How to set aspect ratio
I think you are going to find the aspect ratio is coming from the box--it determines what it will be 4x3 or 16x9 etc and cannot be varied.
sort of what you see is what you get.
May 16, 2012 | Televison & Video
Adjust resolution on lumix dmc-tz3
Select PICT.SIZE from the REC menu. Depending on the aspect ratio, you can choose from 0.3MP to 7MP. For full details, refer to the "Using REC menu" in the manual (page 52 in my copy).
Jul 09, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Screen Resolution
You will need to go into your aspect ratio and change the settings(resolution). You probably have your settings set at 4:3
Apr 05, 2009 | Vizio VP322 32 in. Plasma TV
HALF OF THE SCREEN
Are you referring to the black bars that show above and below the movie? That's normal, it's called widescreen aspect ratio.
If you don't like that, you want to buy/rent fullscreen movies.
Widescreen is 6:9, fullscreen is 4:3. (Square versus rectangle)
Mar 19, 2009 | Durabrand DVD-1002 DVD Player
Unable to view fullscreen in hdtv
That is the way HDTV is viewed on many screens as a wide fromat. So you will get top and bottom non-viewable areas. It is the width that gives the full imagery for that format. To have the screen filled you would get a standard 4:3 format like standard TV. HD is a 16:9 format so it is much wider.
Sep 22, 2008 | Panasonic CT-32HX40 32" TV
Auto aspect ratio
Auto Aspect Ratio is a feature of the set that takes the signal in and determines if the signal is being broadcasted in 4:3 or 16:9 screen size and adjusts it automatically, you can turn it off or on in the tv's menu and either pick 4:3 (bars on the left and right side) or 16:9 (fullscreen) for no matter what signal is being broadcast
Aug 12, 2008 | Televison & Video
LCD tv "burn in"..
there is really no way to get rid of burn in. If you can return your set I would as the only way to fix it is with a new panel which is ver exspensive.
Jul 29, 2008 | Televison & Video
Trying to get Fullscreen HD.
MY TV HAS SOUND BUT NO BIG PICTURE IT HAS A LIL PIC IN THE RIGHT HAND CORNER WHEN U PRESS MENU.
I HAVE MODEL NUMBER VS-50603
Jun 06, 2008 | Mitsubishi VS-60805 60" Rear Projection...
I cannot change aspect ratio
If you are trying to change the aspect ratio on the television make sure you are sending an HD signal Via Component cables. I am not aware of a way to get HD cable without a PC cable card or box, it could be that your television is not receiving the proper signal (analog, or composite) to switch the aspect ratio on your particular television.
Feb 24, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Mitsubishi VS-60805 60" Rear Projection Television Logo
76 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
