Question about Tomtom ONE 3rd Edition GPS
Screen saver after i plan my route a screen saver comes up. how can i turn the screensaver off?
    Problem Solver:
  • 7 Answers
Most likely the demo script in the \script directory of your TT is named "salesdemo.script". A script by this name is run automatically after a certain time. Just rename it to "demo.script". Problem solved.
Posted on Mar 05, 2009
    New Friend:
Hook your tomtom to a pc or lappy. with usb cable!. find the folder called script! now you well see a script file called salesdemo.script! ....change it to....demo.script your don!! ruudb pretty much nailed this!!
Posted on Nov 27, 2012
How do you get Windows 10 free update from Windows 8 to operate the screen saver?
How to customize Screensaver in Windows 10
RECOMMENDED: Click here to fix Windows errors and optimize system performance
There were times when computer monitors used to suffer from image burn-in issues caused by showing the same image for a long period of time and people used to install a screen saver to avoid the issue. The computer screens today no longer face the burn-in issues, but people still use the screen saver on their computer systems for fun's sake. Windows 10 comes with a six built-in screensavers. Let us see how you can customize screensavers in Windows 10.
Read: Are Screensavers necessary and still needed.
Screensaver Settings in Windows 10 You can get to your screen saver settings directly by typing 'Screen Saver' in the taskbar search box in the lower left corner of your system. Click on 'Change Screen Saver' and it will take you the Screen Saver settings right away where you can adjust the settings according to your own preferences.
Alternatively, right-click on your Windows 10 desktop, and select Personalize to open Personalization settings. Next click on Lock screen in the left pane.
Scroll down the Lock Screen settings and click on Screen Saver Settings. The following window will open. Here you can adjust the settings according to your preferences.
By default, Windows 10 offers the following six screensavers - 3D Text, Blank, Bubbles, Mystify, Photos and Ribbons - nothing new here. Select the screensaver from the drop-down menu and change its defaults Settings, if any are available.
For instance, the 3D Text screensaver lets you customize the text as well as a few other options.
The Photos screensaver lets you display your favorite photos as a screen saver.
Once you are done, click on save and exit.
Create Screen Saver Settings Shortcut
If you access the screensaver settings frequently, you can create its desktop shortcut as follows: However, it is easy to change the settings but if you change your screen saver often, it would be better to create a Screen Saver Settings shortcut on your desktop.
To create the shortcut, you have to right-click on your desktop and click on New > Shortcut.
Type control desk.cpl,,@screensaver in the location space in the wizard.
Click Next and give a name to your shortcut. Click Next and you are done. Give it a suitable icon of your choice.
Use this shortcut to change or adjust your screen saver settings whenever you want, quickly.
You can also create a shortcut to launch or change Screensaver state for a specific screensaver.
Nov 29, 2015 | Microsoft CompuRegister POS-1000 POS...
Screensaver set
Hi, go to start- Control panel- personalization. Click here and check if the
screen saver is turned off. It is located on the lower right corner. Click on it
to turn the screen saver back on. This is for windows 7.
If you are running XP go to Start- Control panel- Display. Click on the
display icon and there is a tab that says screen saver. Click here and chose
your screen saver.
Oct 19, 2013 | Acer Aspire One PC Notebook
Computer restarts every time screensaver comes on
try to turn off the laptop, remove the cables and battery, then press and hold the power button for 8 secs. Reinsert the cables and battery and turn on the pc. Observe if the screen saver works...
Aug 03, 2010 | Toshiba Satellite P105-S6197 Laptop
Screensaver 4 n72
go to galleries ,select graphics & then screen saver .from here u will get screen saver provided by & if u want ur file as screen saver ,go to that picture open it , open options->use image->set as screen saver
Aug 05, 2009 | Nokia N72 Cellular Phone
No screensaver will activate on my computer
To activate screen saver right clik on the desktop go for properties click on screensaver tabselect screen saver adjust the time to 5 and click on apply and ok button. so that ur screen saver is activated to the selected time.
Jul 07, 2009 | HP Pavilion dv9000t Notebook
Screensaver not working
just go in setting there will b optin of screen saver click it then you should click on the screen saver it will b on..
May 23, 2009 | Nokia N95 Cellular Phone
No screensaver or power mangement
Hi there.
Right click on the desktop and select properties, then select the screen saver tab, you can set screen saver from there, select a screen saver and set the time you want it to activate.
Remember that the screen saver will not work unless you leave the computer to idle.
Good luck and thanks for using FixYa!!
Apr 03, 2009 | Dell Inspiron 530 PC Desktop
Hi, my screensaver acer aspire one doesn't work. can you help ?
To set up your screensaver, right click on your desktop and choose Properties. Choose the Screen Saver tab. In the drop down menu for Screen saver, make sure something is selected instead of (None). Next click the Preview and it will give you a glimpse of what the screensaver you chose will look like. Move the mouse to get out of it and select apply if you like that one or choose a different one.
Jan 14, 2009 | Acer Aspire One PC Notebook
Getting frequent black screens on 1501 Inspiron Laptop
Black screen is probably a screen saver or the screen is turned off by power management software.
Check your screensaver setting. Change the screensaver to None to disable screensaver.
I assume you are using Windows XP.
If the LCD is turned off by power management, on the same screen with screen saver, on the lower part of the box there is a Power button. Click to open Power Options Properties. Set your monitor power properties there.
When the screen go blank and you have to push power button, probably the computer is set to go to stand by mode after some idle minutes. You can also set it here in system standby setting.
Regards,
Dapid Candra
Dec 08, 2008 | Dell InspironTM 1501 Notebook
Screensaver will not activate...
I would remove the software for your keyboard. This will hand control of the screen saver back over to windows. Some keyboards come with third party software that conflicts with windows. If you want a functional set of "extra stuff" on your keyboard, then your best bet is to try one from another manufacturer.
Jun 16, 2007 | Logitech Cordless Laser Desktop MX 3000...
Tomtom ONE 3rd Edition GPS Logo
304 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
