Question about Kenmore Oasis HE 27062 Top Load Washer
SPIN THE WASHING MACHINE CLEANS THE CLOTHES BUT AT THE END I GET MY CLOTHES BACK SOAKED. IT DOESNT DRAIN THE WATER AT AT THE END
    President:
  • 1,294 Answers
Refer to manual; your filter could be blocked, or something could be clogged in the drain pipes. Plug off the wall & check the pipes, filter first.
Posted on Jun 06, 2008
SOURCE:
Machine will not agatate when clothes are in the machine
does the machine fill up with water? if you were to put the machine in drain/spin, does it drain/spin? if water comes in and it doesnt drain/spin, then your lid switch is bad. if the machine fills with water, drains but doesnt spin, the your motor coupling is worn.
Feb 03, 2011 | Washing Machines
End of wash cycle (last 2 minutes,) F code, no spin & drain
If your getting an FdL or F11 (and possibly others) code the problem is more than likely the CCU. The CCU is a circuit board at the inside top back of the machine. The board has quality issues in that it is prone to cold solder joints at the spot where the relays and the spade connectors for external connections meet the circuit board. The repair is to remove the board and touch-up those solder joints.
Jul 06, 2010 | Whirlpool GHW9400 Front Load Washer
MY MOFFAT WASHER SPIN SCYCLE WILL NOT WORK THE WASHER WIL NOT SPIN TO REMOVE THE WATER
moffat washing machine does not remove water after spin cycle
May 29, 2010 | Washing Machines
My washer spins but doesnt spin on the final spin and leaves the clothes all soaked. it stops at 6 minutes on the final spin
is the machine draining correctly?
the machine will oftin stop if not doing so.
you can try cleaning out the coin trap/drain pump hose.
Jan 12, 2010 | Frigidaire Affinity ATF7000E Front Load...
Machine spins and drains but clothes r still soaked
checking the hose is good but also check to see if the hose end is above the pumping ability of the washing machine
Sep 11, 2009 | Washing Machines
Whilpool washers drains but when done spinning puts water bk out
If you have a selection for extra rinces deselect it and try. If not almost certainly your timer is faulty.
Jan 24, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
The washer doesn't spin out the water. Clothes come out soaked?
if it washes ,,check your lid switch,,if it doesnt wash and spin check your motor coupling...onthejob
Jan 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Open Questions:
See all Kenmore Oasis HE 27062 Top Load Washer Questions
Kenmore Oasis HE 27062 Top Load Washer Logo
74 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
