Question about RCA DCM315R Modem
1st and 2nd light Blinking forever!!!!!
It been this way ever since around May 15. Usually it would be like that for 2days and back to normal for 1 day and become that way again. But now it has lasted almost a week. Usually when only 2light lights blink together it would be like 30min-a few hours and it would be ok but it has been nearly 1 week. the 1st and 2nd light blink at the smae time.
YOU GOT TO HELP ME!!!!!
  • 16 Answers
Http://www.amazon.com/RCA-DCM315R-30Mbps-Cable-Modem/dp/B00009UI2Z
read it!
Posted on Jul 01, 2009
The Pacifica will not shift past 4th gear. It shifts normally through 1st, 2nd, 3rd, and 4th gear. Their is no high reeving RPS, no clunking, no lurching. It will just not shift past 4th gear.
is there an OD button that might have been pressed .if it has lots of miles on it it could be needing a flush job . last one I got done was around 100.00 at jiffy lube.
Nov 12, 2015 | 2005 Chrysler Pacifica
On/off light flashing with 1st and 2nd light flashing as well. dryer will not work
These blinking lights refer to a trouble code that is usually listed in the users manual for most common problems. If it's not listed then it will only be available in a service manual.
Jun 21, 2015 | Dryers
A hard shift between 1st and 2nd gear?
Most likely a solenoid on the valve body. It is just a coil that when energized pulls in metal rods, some push. When most coils start breaking down, they only act up when hot. Could also be the valves themselves. Also a bad seal. Ask friends for a good transmission shop. Some one that won't tell you a rebuild and only change a valve solenoid.
Feb 10, 2015 | 2005 Kia Spectra EX
How do you fix a transmission if you put it in gear but it will go in it
If you have a tachometer, shift around "3" (3000 rpm) on each gear or every 15 miles per hour (1st gear 1-15, 2nd 15-30, 3rd etc-----------------------------------------------------------------------------
VAG Dash K+CAN V5.14
Mar 19, 2013 | Cars & Trucks
2nd tv will not find signal after electric power cut
usually a surge like that can damage the circuitry
Jul 21, 2012 | Televison & Video
Flickering
#1 cause is a bad lamp,try changing that 1st, 2nd if they are two lamp fixtues you ballast could be going bad/or is. Another solution could be you have a loose common/neutral which is normally the white wire @ the light itself of if it is junctioned @ your switch. I would check those items befor spending the money for a new switch. hope this helps.
Oct 02, 2009 | Electric Electrical Supplies
95 dodge dakota having hard time shifting.
Try a tranny service change a place that changes the filter the pan gasket and fluid not some of these quick places that just drain a couple quarts out of the tranny lines and thats it that wont help but a complete tranny service should help.
Jul 30, 2009 | 1995 Dodge Dakota
Hard shift and blinking overdrive
The blinking overdrive button is telling u that a serious fault has occurred in the electronic controls or a mechanical fault such as excess slippage is occurring.
Jul 16, 2008 | 2000 Ford Ranger SuperCab
Canon pixma ip1000
I try this to my customer canon printer and it is working even i used only the step one method.
Here's the steps for reseting "Waste Ink Full" problem at iP1000
Step 1: Manual for Service mode (1st method)
1. Unplug POWER and USB cables.
2. Open door of the printer, PRESS and HOLD the POWER button.
3. Connect the POWER cable.
4. Close door, then release POWER button.
5. Power ON your printer a usual (It should not blinking anymore)
Step 1: Manual for Service mode (2nd method)
2. PRESS and HOLD the POWER button,
3. Release the the POWER button
4. Power ON your printer a usual (It should not blinking anymore)
Step 2 : Software for Permanant (1st method)
1. Reconnect the USB cable and turn ON your Printer
2. Open "General Tools for iP1000",
http://www.printersiam.com/data/download/iP1000%20Service%20Tool.zip
3. Select (USB PORT)
4. Choose (SET DESTINATION 1)
It should be reseted already, but somehow it start blinking again if you ever unpluging AC POWER cable. So try the 2nd method by using ServiceTool for IP1500
Step 2 : Software for Permanant (2nd method)
2. Open "General Tools for iP1500",
http://www.printersiam.com/data/download/iP1500%20Service%20Tool.zip
4. Choose CLEAR WASTE INK COUNTER - MAIN
5. Choose CLEAR WASTE INK COUNTER - PLATEN
It should be working, coz my printer now now work normally
Apr 23, 2008 | Canon PIXMA Photo Printer
RCA DCM315R Modem Logo
483 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
shaun taylor
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
