Question about Maytag Washing Machines
Error code dc on maytag front load washer - Maytag Washing Machines
  • 868 Answers
Take off the water hoses that connect the hot & cold, clean the screens in the valve that the hoses attach onto.Please rate this THANX!
Posted on Jun 06, 2008
What does samsung washer error code dc mean?
Product: Home Appliances > Washers & Dryers > Washers > WF218ANW
dc = Unbalanced load prevented the washer from spinning.
What Do the Information Codes Mean on the Front Load Washing Machine
Jan 03, 2015 | Samsung WF218ANW 4.0 cu. ft. High...
Error code FL-maytag neptune front load washer won't lock
replace door latch (fl = faulty latch ) good luck APPLIANCES R EN
Mar 09, 2013 | Maytag Neptune MAH5500B Front Load Washer
Not finishing the spin cycle and have a code that says dc
here is a website you can view a bulletin on the error code DC pertaining to your washer
http://fixitnow.com/wp/2009/06/11/e3-and-dc-error-codes-in-maytag-mah6700-8700-and-9700-washing-machines/
May 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
Neptune FAV6800AW Top Load Washer: My Neptune washer is showing error code dc..Once i...
See this post Clutch Fix if you want to DIY I will help you.
Post back if you have questions……..Rich
May 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer? makes a
more than likely it just needs a little leveling...lift front of washer . there are 2 leveling feet on each front corner under the washer.. they turn like a screw ..just adjust these feet till its level and you should be ok....shake the washer by hand . if it doesnt move it shoud be level,,,,an unlevel washer makes terrible noises ...as you know..thanks and have a great day
Jan 03, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Error code of "dc" on my TL Maytag Neptune
If your machine is FAV6800AW or FAV9800AW the dc/UC errors are caused by a clutch malfunction. Your machine is shutting down with those errors so your Tub Displacement Sensor is working as designed.
Fix the Clutch malfunction and you can wash a single sock or a load of blue jeans and you will not take the dc or UC unbalance errors. See this post for the fix.
Post back if you have questions or need help.
Rich
Oct 06, 2009 | Maytag Neptune FAV6800AW Top Load Washer
MAH 2400 AWW flashing error code "dc"
Hi Pepsi,
"dc" means that the control board is trying to ramp up (that is, send a signal to the motor controller), but has encountered an unbalanced load and so shuts down. Specifically, "dc" means "distribute clothes".
I took this opportunity to upload a Tech and Troubleshooting manual for you. Here is the link for it. Read it carefully. You will be required to perform a "board output" test after placing the machine in "Service Mode".
I gotta tell ya, though. Based on my history with these, I highly suspect that the machine control board has failed. Let me know what you find, OK?
(And don't forget to rate this solution as "FixYA!", deal?
SG
Apr 11, 2009 | Maytag MAH2400A Front Load Washer
Maytag washer has error code of dc
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$#$
Mar 27, 2009 | Maytag MAH8700A Front Load Washer
I am getting an error code "DC". What does that mean?
DC means: Unbalanced load prevented the washer from
spinning.
This happened to me when i was washing a single shirt (red shirt, first time washing so i did it seperately so it wouldnt bleed into other clothes)
So i set the washer to "drain", waited for the door to open, and wrung the shirt out by hand. Next load it worked properly.
Jan 16, 2009 | Maytag Neptune MAH9700 Front Load Washer
Washing Machines Logo
880 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
