Question about Samsung FPT5084 50 in. Plasma HDTV
No audio on my samsung FPT5084
The sound will not work through the tv alone or the surround sound. I can watch a dvd without issue, but once I switch the input back to the tv/cable box receiver, there is no sound. I've checked every menu I could find related to sound and nothing seems to help. It is only a few months old and has never had a problem before
  • JuniperBliss
    JuniperBliss Jun 06, 2008
    It isn't muted on the tv, the cable box, the surround, any of it. I checked.
CHECK IF THE VOLUME IS IN THE MUTE STATUS TRY TO CHECK THE CONTROL
Posted on Jun 06, 2008
I want to use my TV's speakers with Samsung ht320z not surround sound.How?
You have to hook up the audio cables to the TV from the DVD stand alone player. Red and White is audio and Yellow is Video. The player will play movies and the sound should go to your TV speakers. If not you will need to set it on the TV in the audio source to play from your speakers on the TV. John
Apr 15, 2012 | Samsung HT-Z310T Theater System
Samsung ps wx30 surround sound system. speakers are plugged in to dvd player. dvd player is connected to tv via hdmi cable. speakers only work when using dvd player and not tv/sky etc.. am i missing some...
Hi,here is my simple solution...
To listen your TV on your
samsung ps wx30 surround sound system ,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" or "HDMI out " of your TV unit
** to "AUX input " or "TV" OR "Any input" of your
dvd player or "Optic Cable input" or "HDMI input"
** than just switch to respective mode on
dvd player corresponding your RCA or Optic connection or HDMI ..
There you go..Your TV sound is on the
dvd player By this means whatever you watch on the
TV (
tuner, satellite , Xbox , etc..) ,it's sound will come thru your
dvd player.
Hope this helps!..if more he?p requires pls let me know..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 25, 2011 | Audio Players & Recorders
I cannot get the surround sound to come on tv mode on my friends RCA DLP. Any suggestions? is this a t.v. issue? DVDs and Ipod connections are fine.
The tv must have a stand alone audio output that you would connect the audio composite cables to going to the aux or audio input of the surround sound system. You may need to switch the surround sound system to aux mode or av input 1 or 2 and etc. If you are connecting a cable box or satellite tv box to this television instead of connecting the audio composite cables between it and the tv, connec them between it and the stereo surround sound system.
May 05, 2010 | Zenith XBV441
Samsung HT Q 100 surround sound only works with DVD
Look on the subwoofer. Does it have an upmix switch? If not, you cannot upmix the stereo to all speakers. You can also check your TV menu options to see if it has the upmix feature (or similar).
Aug 01, 2009 | Samsung HT-Q100 System
No surround sound through tv
May be you have to set the Pro-logic option soundfield, this will matrix a 5.1 surround sound effect, unless of course you are sending a Dolby Digital 5.1 audio signal from your TV broadcast into the Home theatre system, also have to check the TV audio output to send audio output to a Home theatre system in other than 2 channel stereo.
Feb 09, 2009 | Insignia NS-H2002 Theater System
CAN ONLY GET THE SURROUND SOUND TO WORK WITH DVD'S NOT WITH NORMAL TV OR SKY?? WHY??
You should have a AUDIO menu in which you can simulate true surround sound. This should be in your owners manual. Your DVD is recorded in dolby surround sound that's why on your set it will be reproduced as recorded. I hope Samsung is using a ATSC tuner in that model?
Apr 04, 2008 | Samsung HT-Q100 System
How do I get surround sound from TV?
see if ur DVD player has a TV/Audio in....you have to set it up so u watch TV threw your DVD player (if you have one of of the Surround Sound in a box systems) if you have SS w/ a receiver then you'd have to run Audio out from your TV/Cable/Satellite to the receiver for it to work
Feb 02, 2008 | Jensen JHT805 System
Sony surround sound hookup
In short, the answer is: Hook up all three to each other. I have a Samsung DLP HDTV, and I was trying to hook up a Sony DAV-HDX500 home-theater system and a Comcast HD set-top box, but I found that the Sony user guide is helpful only for setting up the speakers. Most of what it had to say about HDMI and getting the TV sound or cable sound to go through the speaker system was wrong (or, at least, it didn't work for me). So, here's what I did. I connected Component video cables (Y/Pb/Pr out) from the Cable box to the TV (Y/Pb/Pr in), audio cables from the Cable box (audio out) to the Sony system ("SAT/Cable" audio in), and an HDMI cable from the Sony system (HDMI out) to the TV (HDMI in). This allows me to 1) watch DVDs with surround sound through the TV's HDMI source (when the "DVD" format is selected on the Sony system), 2) watch cable with surround sound through the TV's Component source (when the "SAT/Cable" format is selected on the Sony system), and 3) watch cable WITHOUT the surround sound, as I did before I ever had the Sony system. One item of note: When watching a non-HD channel with the surrond sound on, the audio is slightly out of synch with the video; thankfully, there's no such problem on HD channels. Anyway, I hope this helps. It drove me crazy for two days straight!
Dec 31, 2007 | Sony DAV-HDX500 System
SAMSUNG LE40R88BDX 40" LCD TV with DVD home Cinema system
if ur surround hasnt got digital in then it wont work also its better to use the red white and yellow wire, i have hdmi and them wires hooked up and i have sound through everythin all i have to do is put it on aux 2, try it out
Dec 02, 2007 | Samsung HT-X40 System
Samsung FPT5084 50 in. Plasma HDTV Logo
76 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
