Question about Sewing Machines
Part for sewing machine
Got the tension assembly part DP60683 for my sewing machine,but old part was broken off so I don't know how it goes on
You'll need a very small Allen Wrench, open the door where the light is, see the tiny whole near the assembly? unscrew and pull the entire assembly out. put the new assembly in and tighten.
Posted on Aug 09, 2008
any one have a power cord/manuel for a Janome 2049 Harmony Sewing Machine?
Posted on Jun 06, 2008
I can figure out how to install a new tension dial that I ordered. When I install the part (as it came) it will not work. There is an extra ring that came with it but there are no instructions with t
This is why you let the professional do the repair correctly and safely. Please take it in for service and adjustment for happy sewing times.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Nov 03, 2014 | Sewing Machines
Tension knob on sewing machine part # DP60683
For future reference SEARS branded parts can be found at part.sears.com
You know the part number so it was an easy matter to search that part number. Here's your link
http://parts.sears.com/partsdirect/part-number/DP60683/0020/158?pathTaken=&filterPart=&pop=flush
Aug 19, 2012 | Kenmore 15718
What can I do to wind my bobbin tighter
Make certain you are passing the thread through the tension for the bobbin winder when setting up to wind the bobbin. Check that tension assembly for anything that could be stuck in it, preventing the assembly from putting tension on your thread, such as another thread. Wiggle the disc on the assembly to make sure it isn't stuck. If none of that works, disassemble that assembly from the top of the machine (NOT the tension you use when threading to sew!) and see if the spring inside is broken. If it is, replace the spring if you can get it, or the whole assembly if you cannot.
Apr 28, 2012 | Brother LS-2125 Mechanical Sewing Machine
My bobbin keeps bunching up. I've changed the tension to 2, taken the bobbin case out, used a different bobbin....I don't know what to do. My machine is a month old and I've used it, maybe 4...
Put the tension back up to about 5. Rethread the machine entirely, and make sure you have the pressure foot in the up position when you rethread. If your getting bunching on the bottom, it's probably your top thread that's bunching up. After you rethread, put a small piece of fabric under the pressure foot, lower the pressure foot, and turn the handwheel in the forward direction and watch the thread as it comes around the bobbin case. If it goes around smoothly, try it with the foot control. If it hangs up as it goes around the bobbin case, you might have a burr on the black plastic bobbin case. Take it out, check for any burrs, sand them down, and try again.
May 07, 2011 | Brother SE350 Mechanical Sewing Machine
I need to know how to thread my tcm sewing machine as i have no instructions as it was given to me thank you
I do not know this model but why don't you visit www.about.sewing.com, there is good general threading information there as well as care and maintenance tips for sewing machines. Older machines need oiling, many modern ones have nylon parts or oiling wicks so not required so often. If you can see red marks on parts of the machine, these are usually oiling spots.
sewing machines are usually horizontal top loading bobbins where the bobbin goes into a bobbin holder and the thread gets clicked into a tension spring.
Or vertical front loading bobbins inside a removable bobbin case with a tension spring on the outside of the bobbin case.
Top threading up is usually through a number of eyelets, through a tension device of some sort, then down to the needle.
Remember, the scarf (cut out) of the needle should face to the back of the machine. Most domestic sewing machines use 130/704H needle system and the needle has a flat shank which goes to the back in the needle holder so you get this right.
You can also try www.sewingpartsonline.com or www.sewusa.com, both list some instruction manuals and threading diagrams for some makes and models.
Apr 26, 2011 | Sewing Machines
I need to check the tension on my Janome 534D, I think the upper and lower looper tensions are not right
Here's a couple of solutions to try.
* Re-thread your machine
It may be threaded incorrectly. And when you re-thread it, make sure your thread goes in between your tension disks. (If you don’t know where your tension disks are, consult your machine’s manual.)
* Check your tension disks for dirt or lint
Lint or dirt between your tension disks may be keeping your tension from working properly. Clean out any you find.
I hope this helps.
Sep 23, 2009 | Janome MyLock 644D
My tension is set at 5. but it does not sew right it is really loose. what is the problem? it does that off and on.
Here are a couple of things to try.
It may be threaded incorrectly. And when you rethread it, make sure your thread goes in
machine’s manual.)
Hope this helps.
Sep 15, 2009 | Brother LS-2125 Mechanical Sewing Machine
Loose tension
*Re-thread your machine
machine’s manual.)
*Check your tension disks for dirt or lint
Hope this helps.
Sep 14, 2009 | Singer Sewing Machines
No tension on bobbin thread
You might remove the bobbin assembly looking for a broken tension spring (maybe a piece of it lying in the bottom the bobbin case.
Jul 19, 2009 | Husqvarna Freesia 425
Replace the needle thread tension dial
If the entire assembly has fallen out you will find if you remove the top left hand cover that there is a small screw in the casting where the tension assembly goes, replace the tension body to the correct position and tighten the little screw.
Jun 30, 2009 | Singer Tiny Tailor TT700
Sewing Machines Logo
186 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
