FixYa.com
Tags:
Nakamichi CD-45Z CD Player
Nakamichi cd45z problem
By maartenw - usenet poster
I have a cd45z and it is wiried corectly according to the instructions, the
problem is that it stays hot(chassis) and it will drain the battery on my car
overnight, I would not believe that the mamory wire draws that many amps I have
checked and double checked the wiring and it is correct, could the instructions
be wrong, it is in a 00 civic, red to red y-y black to black remote to remote,
and all tree sets of rcas are being run deck amp is not being used, please help
it is depressing having to jump a new car every day.................
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 11, 2005
Not Rated (0)
M0nica L
M0nica L - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
In article <20000605224630.26435.00002 @ng-fm1.aol.com>, Balsaaq
Yes, that would be a good place to start.........
Peter Lufrano -Owner
The Autophile
http://www.TheAutophile.com
***High End Car Audio!***
*Dynaudio*a/d/s*Genesis*Nakami­chi*Milbert*Velodyne*Kimber Kable*ZAPCO*
*TubeDriver*Linear Power*Powerclass*Focal*CD Technologies*
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Brad
Brad - usenet poster
Rating: 0%, 0 votes
I used the accord harness, it is the only harness that will work in the 99-00
civic, also there is a ppi 5440 amp but it shuts off when the car and deck do,
the deck shuts off when the key is removed, etc. because even if I pull the
maxi fuse out of the distribution block that is poering the amp it has this
problem it has to be the harness i guess, i will have to get out my multi-meter
i guess
Solution #3
Not Rated (0)
Jimmy NY
Jimmy NY - usenet poster
Rating: 0%, 0 votes
I have the same head unit in the exact same car and I have not had that
problem.  Did you use a wiring harness or did you cut your factory harness
off.
Bobby Jacobs
TeamROCS #093
www.teamrocs.com
Nakamichi, Zapco, Diamond Audio, PPI, Monster
Code-Alarm
2000 Civic EX
Solution #4
Not Rated (0)
Cornish
Cornish - usenet poster
Rating: 0%, 0 votes
color codes are great and all, but have you used a volt meter to
confirm that the unit is connected properly? That the 12V is not
constant on the red lead?
Also did you add anything else to your car/system when you installed
the head unit?
In article <20000604222351.01598.00000 @ng-da1.aol.com>, Balsaaq
The Autophile
Solution #5
Not Rated (0)
Duke
Duke - usenet poster
Rating: 0%, 0 votes
Where did you ground the radio to?
Does the radio shutoff when you turn back/take out the key?
Did you add anything else besides just the head unit? (Amp?)
If you have an amp.... is that shutting off when the radio is turned off after the
ignition is turned off(key is removed)?
I'd check the amp ... I hope you find the problem ...
I can totally imagine this sucks.
Can you Help with these In Dash Receivers problems?
nakamichi cd45z car stereo
I installed this unit in my... Answer This...
Need a Nak CD-45Z wiring...
I just got a used CD-45Z in... Answer This...
Dodge P/U
Trying to hook up this radio in... Answer This...
Install Nak CD-45z in '98...
Installing used Nakamichi this... Answer This...
Nakamichi CD40Z users manual
My Nakamichi CD40Z users manual... Answer This...
Repair Service
Find In Dash Receiver Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
