Question about Hotpoint NBXR463GBWW Gas Dryer
My gas dryer only heats up the first time...
My Hotpoint dryer will run nicely, then kick on like it should, then naturally the gas turns off, but on the next cycle it glows, but doesn't kick on and makes an annoying clattering sound where the gas should be heating up. When the heating cycle ends, the clattering stops, but the clothes never get dry again. I've got to wait until the machine is completely cooled off (usually over an hour), I'll get it to heat up on the first run, then nothing for the whole cycle. What's wrong?
    Genius:
  • 1,028 Answers
Replace both coils on the gas burner (the round black dohickeys)after first ignition they tend not to pull valve open next time heat is called for
Posted on Jun 07, 2008
Hotpoint dryer will not heat - cold air only also the dryer will not stop running unless on no heat setting
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101'';;
Sep 08, 2011 | Hotpoint Dryers
Maytag Gas Dryer. Gas on. Ignighter kicks on. no heat aftrer running along time. Set idle and retried with no heat... Has ran fine for years... gas source has not been off for years... thanks
heatman101ooo
Aug 18, 2011 | Dryers
Our Maytag Neptune gas dryer is exhausting a natural gas odor now... This smell only occurs when it has been running for awhile and never when it's turned off. Also, it ONLY smells outside the house via...
The burner is not lighting right...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 31, 2010 | Maytag Neptune MDG5500AW Gas Dryer
It is a gas dryer sometimes the burner kicks in drys and other times it won't . I cut the gas off then back on and it worked . then it stop heating again.
Hi
If your dryer is not heating, then check if the power cord is plugged into the wall. It may be loose or disconnected. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working. Now, check whether the heating element in your gas dryer is burned out by using an ohm meter to check for continuity. If the continuity is not there then you would need to replace the element. After checking the element, check out the thermal fuse to see if it's burned out. The thermal fuse is attached to the exhaust duct on the back panel of the gas dryer. It's usually surrounded by a black resin material situated in a housing made of white plastic. If the fuse looks like it
Sep 14, 2010 | Hotpoint Dryers
Kenmore gas dryer works but no heat, model# 110.20702990.
make sure the exhaust vent is not plugged. shut gas off, disconnect hose, start dryer. stop and reconnect hose turn gas back on and try again.
also a propane dryer can work on on natural gas but it is very dangerous to run a natural gas dryer on propane because the orfice is too big.
Sep 23, 2009 | Dryers
GE GAS DRYER DDG7189SBLWW NO HEAT?
SOUNDS LIKE YOU HAVE A RESTRICTION IN YOUR DRYER VENT SOMEWHERE. THE UNIT LABORED TO EXHAUST UNTIL THE THERMAL FUSE BLEW. YOU WILL NEED KNOWLEDGE OF THE USE OF A MULTIMETER TO MAKE THE NECESSARY TESTS ON THESE ITEMS, BUT DON'T FORGET TO CLEAR THE RESTRICTION!
Jan 28, 2009 | GE DBXR463GB Gas Dryer
I moved and after hooking up my gas dryer to gas tank it will not heat up....
were you on propane b4 the move or natural gas? A natural gas dryer will not run on propane nor a propane one run on natural gas
Jan 14, 2009 | Kenmore 73932 Gas Dryer
Heating elements will not heat
If you dryer is running but not heating then you may have one of the following problems.
Make sure you have 220-240 volts to the machine. If one leg of you breaker has kicked you will only be getting 110 volts this will cause the dryer to run and not heat. Simply kick the breaker off and back on to fix.
If you have enough voltage then you may have a bad thermostat, thermostats or heating element. I recommend you take your heating element off and look for broken lines.check continuity if possible. If the heater is good then go to the thermostats. Check continuity. Replace if you find a bad one. Good luck and I hope this helped. mca0824@aol.com
Apr 29, 2008 | Hotpoint NLL113EYWO Electric Dryer
Hotpoint NBXR463GBWW Gas Dryer Logo
188 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
