Question about Compaq Presario 700 470024-192 Notebook
PROBLEM WITH 3D GRAPHICAL PROCESS
I got a problem with my C767 laptop when i use it to run a mining software with 3D graphic visualizer function. After several minutes the program become not responding or not working properly.
Please advice...
thanks,
Arif
  • 2 more comments
  • arifh Jun 09, 2008
    Thank you for the advice, here are the minimum HW requirement of the software :
    - Computer with at least a Pentium IV processor.
    - At least 512Mb RAM.
    - DirectX compatible graphics card with at least
    64Mb on-board memory
    I think this laptop has met the requirement but the display filtering still doesn't work & became unstable.
    Is it caused by the unstable VGA series or shared memory?
  • arifh Jun 10, 2008
    My laptop is compaq presario C767TU with the spesification like you mentioned before and I attach additional 1 GB DDR2 RAM memory inside it. It's still new, I bought it 2 weeks ago to replace my broken presario V5000 that striked by thunderbolt when I operated it.
    I use Windows XP Pro SP2 as the OS and AVG 8 as the antivirus and spyware.
    Ok I'll try to download the Window washer.
    Thanks for the help.
    Arif (sorry, wrong posting as Guest before)
  • arifh Jun 19, 2008
    Hi Dean/TandN,
    Yes your solution can solve the problem of graphic filtering function of my software, it's great.
    but the unstability of the software is still exist after I run it more than 4-5 hours (I has ensure it in last few days, the laptop is likely overheat). After the program not responding I sould wait till the comp is cool enough then I can run the program properly again.
    Perhaps there is a problem with cooling device hardware...
    I am in a field duty right now so i can't bring it to HP service centre to get the repairing service.
    Thank you
  • Anonymous Nov 26, 2008
Thanks for the help :)
Posted on Jun 10, 2008
    Sergeant:
  • 458 Answers
The laptop video can not handle the graphics. Did you read the requirements on the mining program?
If you like this answer please rate it as a FIXYA.
Posted on Jun 06, 2008
  • 3 more comments
  • T&N Family Electronics Dean and Sherrie Terrell
    Did you solve your problem? Let me know if you are still having problems so I can help you more.
    The only thing that you can try is to increase the memory and allocate more memory to the video. The NEW laptops NOW can have the video card changed out.
    What O.S. and Antivirus are you using. X.P. alone takes around 256 mb of memory to just boot up. Vista needs at least 2 gigs for it to half way run. Running graphic software would take a lot more memory. You state that the requirements of the software is 512 mb of ram with a P4 processor and at least 64mb of onboard memory. What are the specs of your system? You can go into the BIOS and set the Video higher. Do this by hitting DEL or one of the F keys when it boots up.
    Is this your specs?
    COMPAQ PRESARIO C767
    INTEL CORE DUO 1.73
    1 GB RAM
    120 GB HDD
    15.4 DISPLAY
    DOS
    LAN,MODEM,WIFI
    DVD BURNER
    I looked that system up and found this. There are two possible laptops listed. Which one is yours?
    Here is something that you can try to give the system a little more speed in case it has spyware bogging it down:
    Turn the system restore off. System restore keeps
    everything in restore. Meaning......... If you have spyware or a virus,
    it will stay in your system. Run Spybot S&D (This program is free and
    is better than using msconfig as long as you go through the settings and
    change everything to the highest settings.) Then do the same with Adaware 2008
    (sounds stupid to use 2 things for spyware, but one catches what the
    other one does not.). I have links on my website
    (tandnfamilyelectronics-online.com). These links go directly to the
    download so you will not get the run around. You would do good to try a
    program called Window Washer http://www.download.com/Free-Internet-Wi...
    This is a great program that completely cleans anything in your computer that
    you do not need. It will not clean out anything that you have to
    have. I have used this for years to clean out my customers computers and
    have cleaned as much as 3 gigs of trash out. If you contact me I will
    give you some tools that I have for free that will do a great job on your
    computer. I have them ready to download and I will give you the link.
    (dean@tandnfamilyelectronics-online.com)
    Send me the complete specs of your system and I can help you more. I hope
    that this helps you. There is no reason the really buy a program for
    spyware when there are free things to use that work great. Free AVG is a
    great Antivirus and yes it is also free. It will check your e-mail coming
    and going. It will also let your friends now that the E-mail does not
    have a virus. It also has a spyware program that is free. This day
    and time with all of the spyware out on the net you can never have too many
    programs for spyware. I would not run all of them at the same time
    though. Make sure that you do not use your computer during any
    scan. Defrag is also something to do after you do everything else.
    Some people will tell you that should not reload your computer. If
    nothing seems to work then sometimes that is the only good way to get it
    repaired right. Most of the programs that come pre-installed on a store
    bought computer is useless and most are even trail software that causes
    problems when they expire. Let me know if this helps at all. Please
    rate me if it helps.
    Try that and let me know if you get better performance out of the system. When you let me know which system you have or your specifications, I might be able to help you more. We might get the software to work. Do not give up yet.
    Make sure you turn off system restore before runn ing these programs. You can turn it back on if you want to after the scans are done. System restore can be bad if it stores a virus or spyware. Run the spybot and the ADAWARE program that I
    mentioned. I have also used the AVG spyware program. It is a good
    program, but it does not catch all of the spyware. Spybot can catch some
    things that ADAWARE can not catch. Spybot can also be used to stop things from
    running at start up. It has a lot of features to be a free program.
    It has a program called Tea Timer in it that can be set up to run as a Firewall
    for your computer. I would not suggest using this unless you know what a
    Firewall can do. A firewall is good but you can let some things get
    through if you do not know how to use it. Spybot can also run on your
    computer before the operating system even starts up. This is the best way
    to catch spyware. Spyware can run on your computer and not get found
    because your system thinks that it needs to be there. If you do use the
    Spybot, install it with the custom or advanced install. Go through the
    settings and set everything to the highest that you can. Do not worry
    about the legal settings but tell it to keep all of your settings. Don't
    let it back up the spyware because this will keep it in your system. Go
    to the start up settings and shut anything down in your start up that is not
    needed to run the operating system. If you are unsure of anything, do a
    Google or Dogpile search and see what the program is. You also do not need MSN
    Messenger,Yahoo, or any other messenger service on your start up. You
    printer, the Flash Player update, Nero, or some HP programs, do not need to
    start when your computer starts either. The printer will still work when
    you tell it to print. Programs that are starting when your computer starts
    are not needed, unless it is your Antivirus or something else protecting your
    computer. You do not need all of these things in your start up, because
    it slows your computer down, by running in the background. I have direct
    links to these programs on my website. There are so
    many different kinds of spyware that it seems that one program can't get them
    all. The people writing the spyware also know that people are using these
    programs. They write some things so that these programs cn'a detect
    them. The people writing these programs are very smart. I have had
    a problem where spyware will lock up one program and then I have to run the
    other program to find the spyware. Spyware can run a vicious circle in a
    computer. The Window Washer program can really clean out your computer
    good. Make sure you run Defrag after you run the Window Washer. You did not mention going into the BIOS and
    allocating more memory to the Video. The manual mentions that you can allocate
    up to 251 mb of memory to the video. This is done in the BIOS by hitting F10 when
    the system starts. Here is a copy of
    your manual in PDF format.
    Keep me posted on what you do, so I can help you figure out
    how to get this running better together.
    I enjoy helping other people fix their computers. I do more free work than paid work. I always have and there is no reason to stop
    now. You have a nice day. We will get this figured out.
    Did you ever get this figured out?
    Overheating is common with ALL laptops. You need to buy a laptop cooler. If you live near a Walmart or a computer store, go pick one up. You can get a stand and put a small fan under or near the laptop also. This is what a laptop cooler is anyway. I have even put a frozen ice pack under my laptop. Never put anything over a vent hole. You do not ever want to use a laptop on a flat surface.
    Remember to rate this when the problem is Fixed. You can send me another question any time. Just click on my name.
Codes of c++
Microsoft Visual C++ 6.0 is an integrated development environment, or IDE, released by Microsoft in 1998. An IDE allows the user to create a computer application by using pre-designed functions, tools and other resources. Microsoft Visual C++ 6.0 features a source code editor, a compiler, a debugger and graphical user interface.
Install Microsoft Visual C++ 6.0 on your computer. The installation process is fairly simple. Just follow the prompts. Run the program. A window will appear asking you to create a new application. On the "Project" tab, choose "Win32 Console Application." This means that you will create an application with an EXE file extension that can work with 32-bit Windows operating systems after compiling the project. Also, specify the project's name and the location where it will be saved. Click "OK." Click"OK" in the dialog box that will appear next. You will choose to start an open project. Double-click on the form in the center of the screen. Type: #include <iostream.h> int main() { cout <<"This is my first project!!! Hello everybody! \n" return 0; } Press "F5." This will build and run the project. Microsoft Visual C++ 6.0 will compile your project into an EXE file. Then it will open this file. You will see a new window open in which you'll see your greeting, " This is my first project!!! Hello everybody!" Press any key to exit the application. http://elvis.rowan.edu/~kay/cpp/vc6_tutorial/ http://msdn.microsoft.com/en-us/visualc/ee340952.aspx
Feb 03, 2013 | Microsoft Visual Basic 6.0 for PC
My pc has graphics driver
I SERIOUSLY doubt that any laptop not able to support 3D graphics would still be functioning....lol
You may just be trying to ask more of it's 3D ability than it can handle.
What make/model laptop do you have ?
Tallon41
Sep 17, 2012 | Computers & Internet
Is it possible to add an external graphic card to my laptop for gaming purpose?
no.but their is a software that might work for gaming.call "3DAnalyze" helps you run 3d Gamesgo to google and download it, find its manual also.
hope that will help you.
Jun 23, 2011 | HP Compaq nx6110 PC Laptop
Excel is devloped for which operating system
Microsoft Excel has become a crucial tool in the international workplace, providing basic database functionality, along with spreadsheet and calculation tools. While it is currently the market leader for spreadsheets, the history of excel shows that throughout the 1980s and 90s it faced significant competition from rival software platforms like Lotus Notes, Mosaic TWIN and the Paperback VP Planner. The original Microsoft spreadsheet program was called Multiplan - which began development in 1982 - but it was never as financially successful as Lotus Notes.
Interestingly, Excel was first developed for the Macintosh operating system beginning in 1984. It made use of graphical menus and the mouse, innovating strongly relative to the other major competitors at the time. Drop-down menus and a point and click interface helped to make it more usable to non-technical workers, and in turn helped to influence graphical user interfaces in other software and operating systems at the time.
As such, when Windows was launched in 1987, Excel was one of the most important and popular pieces of software for it. The early exploration of the graphical user interface for Windows had already been conducted and market tested by earlier versions of Excel. While it was certainly not the first spreadsheet software package, it was the first to provide a powerful combination of usability and functionality to business clients of all sizes.
Lotus was relatively slow to bring Lotus 123 to Windows, failing to predict the popularity of the operating system.
One of the major turning points in Excel was the inclusion of Visual Basic for Applications in 1993, which greatly increased the functionality of the software. In turn, it also encouraged a generation of professionals to learn the programming language, further solidifying the long term demand for Excel over other spreadsheet suites
Read more: http://www.brighthub.com/office/collaboration/articles/13188.aspx#ixzz1IWkjtDx5
Oct 30, 2010 | Answer Racing Ion Motorcycle Jersey 2010
Activation code for microsoft office 2007, i lost
go to microsoft websites and ask for the password,
they will give it to you, if it was registered
May 13, 2010 | Microsoft Office Home and Student 2007...
Microsoft Outlook 2007 problems
Outlook Password Unlocker 4.0 is helpful,
Outlook password recovery software designed to
recover forgotten passwords for emails in Microsoft Outlook.
Your Outlook password will be displayed in a minute no matter how long and complicated it is.
Besides, the compact interface makes it easy to use.
May 13, 2010 | Microsoft Office Outlook 2007: Windows
Intel Graphics card using maya software (3D)
Maya would not run on such configuration.
Nov 08, 2008 | Computers & Internet
MP3 PLAYER
Cube Multimedia - Cubix MP3 Player v3.00
http://www.crazy4mobilez.com/dlapps.asp?id=311
BEST CHOICE! Amazing MP3 PLAYER with such features as: 3D VISUALIZATIONS, skinning, albums and M3U playlists support, 10-band graphical equalizer, playlist, and more! CHECK IT OUT!
CubiX MP3 Player is the ultimate choice for any music fan! You get a high quality MP3 player which lets you create your own playlist, displays amazing 3D visualizations, provides a 10-Band Graphical Equalizer, M3U, album support, skinning and much more!
CubiX MP3 Player is compatible with all Series 60 smartphones!
Bye Take Care
Apr 18, 2008 | Nokia 6600
Registration key
Registration key of power mp3 is 255 or 250. I have also power mp3 player on my Nokia N70 register with 255.
Apr 16, 2008 | Nokia N70 Cellular Phone
Linking vb to access
You post it in the wrong product, you should have posted it in Access or Office. But I will try to answer anyways...
In tools look for references and then look for MS ADO Data Control 6.0 or Microsoft ADO... Just select it and press ok then you will have a new control object name "ADO data control". See the explanation about the ado data control which is very easy to use...
Here is also a great tutorial for the ADO Data Control:
http://www.devarticles.com/c/a/Visual-Basic/Implementing-An-ADO-Data-Control-With-VB6/
You can also use VBA in Access, you have exactly the same functions there as well.
Sep 19, 2007 | Adobe Photoshop CS2 for PC
Compaq Presario 700 470024-192 Notebook Logo
78 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
