Question about Pantech Duo Smartphone
My duo won't turn on?
My phone battery died, and I plugged it in and the charging light didn't come on and it won't turn on. I took out the battery and put it back in and still nothing.
  • froggiefreak Aug 06, 2008
    My pantech duo's battery died and it wont turn on on. I took out the battery and put it back in and still nothing.
Plug it in for a while. Maybe an hour or so then unplug it. plug it back in. You can try turning it on if that doesn't work. but it seems to work for me.
Posted on Aug 29, 2008
I have the same probably but myn is differant kinda
basically get a new phone...best solution this phone SUCKS i hate it
Posted on Aug 27, 2008
My laptop is not charging but the cbarger is working.
its your battery problem its a simple process remove the battery and the part is get a nail filer and then you can see on the battery that there are golden kind on teeth but there is a space in each of them try to rub the nail filer on the space so it cleans the teeth of the battery it should be between 1 teeth and 1 space then you will see some black kind of thing coming out its carbon ,now then on the laptop and then put the battery back to it with some force your problem is solved
Nov 18, 2012 | Acer Travelmate 8471 Intel Core 2 Duo...
Dell inspiron not charging
Dear Mathew,
You should you Dell Utility and it has the function called Dell Battery Metter, it can enable or disable charging
Nov 12, 2012 | Computers & Internet
My laptop not charging
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
Or: 2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
Or: 2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
http://www.chargerbuy.com/laptop-ac-adapter/universal-ac-adapters.html
Oct 28, 2012 | Computers & Internet
I plugged my LG Cookie Plus in after the battery died and nothing happened. It won`t chrage turn on it`s basically a paper weight and it`s only 3 months old. Plugged it into the wall and plugged it in to...
spiderandy12 lisren rake the battery out of the phone, Next look at the contacts to make dutr their is no corrision on the phone. The charging port sounds like it is shot. Take another charger and plug it into your phone and see if it woks. You may need a micro charger
Mar 11, 2011 | LG Cell Phones
Pantech C810/Duo Power Problem
YOU MIGHT WANT TO REPLACE THE BATTERY THE LIFE MAY BE GONE CAUSING IT TO NO LONGER CHARGE
Aug 31, 2009 | Pantech Duo Smartphone
Pantech Duo Won't Charge
go to any cell-phone dealer and ask for a replacement battery for your model pantech
Mar 22, 2009 | Pantech Duo Smartphone
Motorzor
you simply fried your battery by overcharging it. Just get a new one, let it fully charge and fully die twice before you start normal charging. Then you will want to only charge it for about 2 to 3 hours or find a charger that has a smart chip that tells it when to stop charging once the battery is full.
May 13, 2007 | Motorola Mobility RAZR V3
Pantech Duo Smartphone Logo
Top Pantech Computers & Internet Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Are you a Pantech Computer and Internet Expert? Answer questions, earn points and help others
