Question about Crosley Heating & Cooling
How much tilt does the window a/c need - Crosley Heating & Cooling
3 to 4 degrees
Posted on Apr 26, 2009
Water is dripping into the house from the brand new air conditioner
Make sure the window unit is tilted back. If its not tilted back in the window, it will drain out the front.
Jun 20, 2011 | Haier HWR08XC7 Air Conditioner
Window air conditioner is spitting water
Hello, usually a window AC will spit water if the unit is not tilted back or if the drain is backed up, if the unit is level try tilting it back it the window somewhat. Also, if the unit does have a drain make sure it is not blocked.
Jun 19, 2011 | Haier Hwr10xc6t Air Conditioner
Window air unit is spitting condensation back into room.
Hello, most of the time this will happen when the AC is not tilted back in the window enough or if tne drain i s blocked. If the unit is level make sure it is tilted back in the window somewhat. If the window does have a drain make sure it is clean and the water is draining properly.
Jun 10, 2011 | Daewoo Heating & Cooling
When the airconditioner is on cool.Water comes from the airconditioner inside and dripping on the floor.
If it's a car air conditioner, your condensate drain line is clogged. If it's a home window unit, it needs to be tilted outward more. The downward tilt should be no less than 1/4" per foot. If your unit is 18" from the window to the back of the unit, the back should be 3/8" lower that at the window....minimum.
May 14, 2011 | Mitsubishi Heating & Cooling
Car battery replacement on 2004 RX330
CLOSE THE WINDOW AND KEEP BUTON DEPRESED FOR ANOTHER 20 SEC. REPEAT THIS IN ALL OTHER WINDOWS AND SUNROOF
HOPE IT HELPS
MARKO
Aug 13, 2009 | 2004 Lexus RX 330
98 318 Front window goes up and down but tilts forward and jams
The white clip is on of two located at the top of the window lifter, bottom of window You will need to take of the door panel and replace the missing clip in the window channel in the top of the lifter
Jul 12, 2009 | 1996 BMW 318
Tilt htc 8925 touch screen is cracked
This web site will fix your AT&T Tilt
fixyourtilt.com
Apr 10, 2009 | AT&T 8925 Tilt Smartphone
Air conditioning unit is spitting out water
unit need to be tilted to the rear as it is installed in the window for proper drainage of condensation water off of the interior coil
the fan on the rear will pick up the water and remove it
tilt it back a little
May 27, 2008 | Heating & Cooling
Heating & Cooling Logo
607 people viewed this question
Top Crosley Heating & Cooling Experts
ray gallant
Kiri Amarakoon
Level 1 Expert
Are you a Crosley Heating and Cooling Expert? Answer questions, earn points and help others
