Question about Coleman Mach 15 Air Conditioner
Fan won"t start on it's own.
Fan won't start on it's own, I have to give it a spin to start it. Only has two capacitors, neither of them are start capacitors.
  • Anonymous Jun 07, 2008
    Mine's a Coleman Mach 8333B. Same problem - I have to spin the fan to get it started. Once running I just leave it on continuous fan and/or cool. It runs fine, just won't start on its own. KLZ
  • Frustrated25 Jun 20, 2008
    I too have a Coleman Mach 8333B series RV AC with the same problem. Fan won't start on its own, I have to give it a spin to start it. Only has two capacitors. From my research I find that one is a run capacitor and the other is a fan capacitor. Which capacitor is causing this problem?
    Problem Solver:
  • 10 Answers
Sounds like classic capacitor failure. A capacitor stores electric energy so that the motor can overcome starting torque by making a big shot available. AC motors must run at rpm's that correspond to the 60 hz alternating current frequency. Theory says this rpm is attained in an instant; reality includes momentum that requires a short but big initial current requirement. If that isn't available, the motor can't generate the power to accelerate to operating rpm. The capacitor provides this power. You can also provide it with a spin. A capacitor is a capacitor and as long as you get one with a micro farad rating at least as big as the one your take off, but as close as possible and not too big, that may solve your problem. Their cheap and replacing both may be less trouble than doing the job twice. If it’s built-in, you may need the whole motor. I been there and mine runs fine.
Posted on Oct 07, 2008
    Sergeant:
  • 107 Answers
I had an issue similar to this when my air conditioning wouldn't start on its own. I had to have a service provider come out and fix it. However, it turned out that something was inside of it and jamming it from operating properly. Have you checked for anything that could be stuck and preventing it from working properly? Quality HVAC Services Heating Cooling Systems
Posted on Dec 15, 2015
Why does my airvent whole house fan stop working intermittently?
if fan was able to run normally after a while, you may have problem with the motor starting capacitor, this gives the fan the needed kick to spin , when your fan stops working this may mean that the capacitor have already over heated, turning it off for a while will give it chance to cool off then start up again, have the capacitor checked and replaced immediately.
May 10, 2014 | Air Vent INC. 54508 36" Whole House Fan
My window air conditioner of 12 years turns on but does not blow air. What do you think the problem is?
Fan barrel not turning. Could be a failed start capacitor or tight fan. With the unit turned "OFF", see if you can freely spin the fan. If so, turn the unit on and give the fan a spin. If the fan starts to run, then it will be a start capacitor.
Aug 17, 2013 | Heating & Cooling
Air conditioner
A the fan motor is bad. Or b the capacitor is bad. Try spinning the fan motor with a stick or screwdriver.if it spins freely then it might be the capacitor. Take the side cover off and look for a silver round thing if the top is bubbled up or it has oil on it it's bad.But it's got to be one of those.
May 08, 2013 | Heating & Cooling
Squirrel cage fan won't start and after a bit hot air comes out the front (not blown out just eakes out)
Hello, yes there is a capacitor located in the control panel that should be replaced if the fan does not start on it's own. Usually most motors are permantly lubricated if they are newer so they do not need lubrication.
May 31, 2012 | Friedrich QStar SQ06J10 Air Conditioner
I have a Bryant Model 593C central air - 6 years old - the fan on the outside unit won't run. I checked the breaker and it is fine.
Hello, this could be either a bad capacitor or bad fan motor. If the fan starts by giving it a push then replace the capacitor, if it does not start the motor needs to be replaced.
Jul 07, 2011 | Bryant Heating & Cooling
My outside unit fan doesn't spin. i hear a clicking noise and a humming but the fan won't spin. i've tried to spin the fan and it spins freely by hand.
You may need a new start capacitor or fan motor.I would have the capacitor checked by a electrician and changed if needed. Good luck and thank you.
May 31, 2011 | Ruud UAMB Air Conditioner
The AC fan does't want to begin to spin on its own. if I give it a little help, it will begin to work. Why wont it start on its own the fan will spin very easily and is not restricted at all it...
Hello, sounds like you have a bad capacitor, the capacitor gives the motor a boost and improves the running effeciency of the motor. Replace the capacitor it should fix the problem.
Mar 18, 2011 | Frigidaire Heating & Cooling
Carrier Furnance Fan / Blower Doesn't Start (Model 58GP-125-GA)
sounds like a bad capacitor usually screwed to the blower housing (round or oval shiny can)
this gives the motor a kick start)
depending on the motor there is usally two brown wires that go to it
check the mfd rating on it probably 5mfd and replace it with a matching one
its a very inexpensive part
Aug 02, 2009 | Carrier 38CKC036 Air Conditioner
RV A/C fan won't start on its own
This could be the problem. It is more likely that the motor bearing is bad. Take the fan capacitor and have it tested. Or replace it, (under $20). Was the fan motor loud before this happened? Hopefully it is just the capacitor, the motor runs $60 - $100 and is a FUN to replace.
Jul 02, 2008 | Coleman Mach 15 Air Conditioner
Coleman Mach 15 Air Conditioner Logo
242 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
