That would be a trick. 824 means 8 lines and 24 extensions. An 82470 fits in one of the 2 remaining slots of the 824 system and it has no lines and 8 extensions. For the price, it's a pretty worthless card, as it will have no resale value. I think the price difference between an 82470 and an 82483 (3x8) is about $100 and maybe $50 more than an 82481 (2x8).
No imation brand is known for problems but maxell usually work great i suggest cleaning the cd burner try compressed air can spray out the cd burner with the door open you may have dust on the laser lens...
double check that you are providing phantom power to it - this is a condenser. make sure there are no transformers between it and the console which might interfere with phantom power reaching the mic. try an alternate cable and or a different channel on the mixer, etc.
That is easy! You don't. Even if you get it to work, you will never pass SMOG, so it would be a worthless car because without a SMOG test with "passed" on it. You have a fancy fully functioning car that you cannot drive (leaglly).
For example, I have a customer that Frankensteined his Jeep, and although it works awesome, it cannot pass smog; so it is a lost cause. It works great, but it cannot be smogged.
These cars have different settings both in design and computer settings. Your smog test might keep you from enjoying your success in making your "Frankenstein".
Clean the unit if possible. does the cartridge eject? if so, load it with a cd player cleaner, preferrably one that uses a cleaning solution. put it in tray slot 1. load and wait. try this a few times then try a good disc, one that is not scratched up. changers are hard on cd's. If it's still not working, below the cartridge slot there should be an inverted dimple that you can press with a ball point pen. This is a reset. It should have this button, I just can't remember the exact location if it's not right there. Hope this helps. If you have a spare cartridge try that as well, as they warp.
First off you need to make sure that your cd player in your car can play recordable media. Secondly sometimes some CD-Rs just dont work in certain players. So try the cd in a different player see if it works. If not the cd is bad, if so try different software. If it plays in a different cd player then its just your car player. Try a different brand CD-R if that occurs. Good luck. Lee
Hi there
Is this problem with windows media player only or with rest players also.
You try to repair your media player using your XP installation CD and then install a good codec pack such as XP codec pack or K-Lite codec pack.These are available for free .
Hope this works for you.
