Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
Oven no longer works
Both of my ovens with not work. The buttons to control the ovens do not work either. When I push the buttons they do not make the beeping noise. My burners still work ---thankfully. I tried unplugging the range for 24 hours but it still does not work.
  • 4 more comments
  • ltnyc Jul 27, 2008
    same issue... my buttons won't push or make a beeping sound. the stove top works fine, just not any of the buttons. I tripped the fuse and nothing happens.
  • Anonymous Aug 07, 2008
    We have a Jenn-Air dual fuel oven that's just over a year old. We heard a pop, then a fine smoke, like wires were burning. We turned it off at the fuse box. We were told the main keyboard has died and that it's rare; appearently not! We've been waiting for service for over three weeks and are starting to think we're going to have to find a solution by ourself. Any ideas?
  • whataever Sep 10, 2008
    my controls don't work, no beeping, neither oven turns on.  the clock displays but timers dont work.
  • Anonymous Sep 14, 2008
    button panel doesn't respond
    oven comes on without warning!
  • gwc9999 Sep 21, 2008
    We are experiencing many of these same problems. Currently the electronic pad is totally unresponsive. The cancel buttons beep but that is it. We have experienced the ovens coming on spontaneously. Ant the panel seemed to go from bad to worse. We had a spell where it didn't work well, then it worked. Now, it went from working sometimes if we found one button that worked to not working at all. We did think that it was worse after a lot of steam from boiling pots on the stove were directing their steam at the electronic panel. Maybe that is a contributing factor. Bad design if it is.
  • larryfix May 05, 2009
    Our oven has the same problem, neither oven will come on the unit has power and the clock still works but the buttons will no longer start either oven
    Sergeant:
    Champion:
  • 330 Answers
Is a gas unit ?
Posted on Jul 06, 2008
Zanussi ZKC6040
You need a new thermostat control for the oven fan. That is what determines when the temperature of the oven is low enough that the fan is no longer needed. Based on your description, the thermostat has failed in the "closed" position which means that it is always supplying power to the fan.
Nov 05, 2013 | Zanussi ZDQ495 Electric Double Oven
Is there a reset for the oven in a thermador smw? I had it worked on years ago and the repai guy simply pressed a button and all was well...also is there a source for control panels, since mine is almost...
Never use Self-Cleaning!!! It will fry components, melt connectors, and burn wires. If you have violated this rule and an oven no longer works, it is probably not a bad element if neither the bake nor the broil work. It is likely the high heat cut out breaker.
On a Thermador CT 227 double oven, there is a panel on the right side (facing the unit) that is about 3 inches wide and runs from top to bottom held in place by about 6 or 8 screws. Turn off the power, slide the unit out of the kitchen cabinet, remove the sheet metal panel and you will see two high heat cut out breakers. They have a small red button in the center that resets the breaker. Push firmly and you should hear a click. If there is no click, check the unit for continuity. If it is open and the button push does not reset it, the unit may be fried. These breakers trip with high heat and will prevent both elements in an oven from heating. If the breaker is good, you'll have to test the leads to each element and then trace the dead lead to the problem.
Dec 27, 2010 | Thermador SMW272 Electric Double Oven
Oven will not work ,control buttons beep when pushed,oven lights work
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Sep 14, 2010 | Whirlpool RBD275PD Electric Double Oven
I have a STOP message on the oven display. The user manual refers me to the product description sheet or the electronic programmer description, neither of which I have. The oven is not working at all while...
HI. This is a control fault, that may be corrected by simply shutting down the appropriate circuit breaker for 5 minutes. This will DE-energize the control board. Once the 5 minutes have passed, simply re-introduce power to the unit. If the unit continues to produce the error, this will confirm that the main control board has failed. it should be replaced asap.
Nov 04, 2009 | Whirlpool RBS275PD Electric Single Oven
I have a 10 year old MH7130XE Whirlpool microwave oven. The oven and key pad both work, and the oven heats just fine. The problem is the oven begins running as soon as you open the door...without pushing...
I'm assuming you mis-typed and meant the oven begins running when you SHUT the door and stops when you OPEN the door. Please tell me this is what you meant! If the microwave oven runs with the door open, UPLUG IT IMMEDIATELY AND DO NOT USE IT!!!
If the oven begins running without pushing the start button then the controller is bad or the Start button is worn out and making contact without pushing it. (Most likely it is your controller.) Generally, it is not worth the cost to replace the controller on a 10 year old microwave. Probably time for a new one.
But if you want, you can call Whirlpool and see what they suggest at 800-253-1301.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 18, 2009 | Whirlpool MH7130XE Microwave Oven
Inglis Niagara oven not working since power outage
try pushing cook and hold button once until lock comes on, then push cook and hold button again. The lock should be removed.
Aug 13, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Whirlpool MH7140XFQ-1 microwave no longer heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
kggk
Apr 24, 2009 | Whirlpool MH7140XF Microwave Oven
My start button on my kenmore built-in oven w/microwave won't wor
my kenmore model number 911-47699100 oven doesn't work. Everything except the oven and broil works--cleaning, all timers, start button, etc. All that happens when you push start is about every 30 seconds, two relays can be heard making and breaking kind of like a click then immediately a clack. No error codes appear. Replaced sensor but that didn't work. Any help would be appreciated.
Mar 30, 2009 | GE JKP30WMWW 27" Built-in Single Electric...
GE JKP27WP1 Oven Won't Work
Hi Cyrep,
You can fix a suggested fix at the following link:
www.fixya.com/howto/h155060-dreaded_f7_error
Even though you are not getting an error message, they are sometime stored in memory and have to be repeated a number of times before they show up in the display. I have shared this fix with over 1300 folks and most report success. I hope that it works for you too. Please let me know at hutchipop@yahoo.com.
Regards,
Charlie
Oct 15, 2007 | GE JKP27 Electric Double Oven
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
270 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal De
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
