I want to plat videos in my van. Currently, the set-up is as follows: The videos are on the hard drive of my laptop (Sony Vaio VGN-TX610P), the monitor is a Bravo OVR-121FM, the PC and the monitor connect through a K-World PC to TV converter. Problem: I cannot get the videos to appear on the monitor. When I power everything up and tell the PC to go to an external monitor, all I see on the monitor is the Windows 7 logo---no icons, no mouse cursor, etc. So, the monitor is obviously getting some kind of signal, but it is incomplete.
The HDD has not been placed correctly leading to a short circuit so the laptop does not switch-on . Remove the HDD and power-on the laptop if it switches on then need to check the HDD .
The VAIO VGN-T350 is a notebook computer designed and
distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit
that stores data, consists of many clusters of data that can be rewritten with
new data.
If you are looking for a memory capacity upgrade, or if your
old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the
use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other
peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive
chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in
place.
Gently lift the hard drive and its cage away from your
laptop and disconnect the data cord.
Remove the four screws located at the corners, and then
remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and
replace the screws.
Connect the data cord to your new hard drive and place your
new hard drive into its chamber.
Close the lid and replace the screw to complete the
operation. http://www.fonerbooks.com/laptop_1.htm http://www.youtube.com/watch?v=rg_GvaMunas Sony Vaio Hard Drive Replacement This might not be your specific laptop it might give you
an insight into the hard drive installation.
You have one of two problems...
1. You have a short in your charger cord (AC Adapter)
2. You Have A Faulty DC Jack (the port where your charger plug plugs into)
