air conditioning compressor grinding
Insert the square tip of a 1/2-inch socket wrench into the square hole in the center of the serpentine belt's adjustment pulley. The adjustment pulley is the smallest pulley the belt wraps around.
Pull the adjustment pulley toward the engine with the socket wrench to release the tension on the serpentine belt, then pull the belt off the air conditioning compressor's pulley.
Remove the bolts which secure the air conditioning compressor to its mounting brackets with an open-end wrench, then position the compressor to the side of the engine compartment. Do not disturb the hoses that attach to the compressor.
Pull the electrical connection off the crankshaft sensor.
Remove the two bolts that secure the crankshaft sensor against the engine with an open-end wrench, then slide the sensor out of the engine.
Slide the new crankshaft sensor into the engine, then install and tighten the sensor's two securing bolts with an open-end wrench.
Press the electrical connection onto the crankshaft sensor.
Position the air conditioning compressor against its mounting brackets, then install and tighten the compressor's bolts with an open-end wrench.
Pull the serpentine belt's adjustment pulley toward the engine with the socket wrench, then position the belt onto the air compressor's pulley.
how do i replace the air compressor?
belt broke hoe do i put a new one on
I just replaced the serpentine belt last year and now it broke, it didn't wear down like the last one just a clean break transverse across the belt. I suspect the A/C compressor or clutch has went out. How do I replace the compressor since I know that the system has no pressure or R-134 left in it. Thanks
the compresser was grinding and then the belt fell off. i havent got a diagram on how it goes back on and i cant figure it out any suggestions
i dont know how to change it
The bearing in the compressor pulley is failing. You'll need a new compressor. Plan for a lot more such as a new accumalator, oriface tube, flush and charge.
