Question about Samsung HL-R5678W 56" Television
Samsung Mirror Light Tunnel replacement on HL-R5078W
You've indicated that you could send instructions and photos on how to change the Mirror Light Tunnel on Samsung HL-R5078W (pn BP67-00218A). Can you do that for me?
mc51299@hotmail.com
5 Suggested Answers
  • 9 Answers
SOURCE: replacing light tunnel (instructions)
Hi, if you did not get help until now, i can send you step by step instructions and photos how to do it. I did several of these and it is not a big deal.But you will have to take apart a very sensitive optical device and if you are not confident that you can do it do not start this.bp67-00291a is the part number for the light tunnel.post a message here if you need that file with instructions
Posted on Jul 25, 2007
  • 44 Answers
SOURCE: light engine/light tunnel replacement instructions
No, I don't know of one. The service manual might or training manual but you would probably need to buy that.
I've never done one on a Samsung. Do you actually need to change it or just wondering?
Posted on Dec 31, 2008
electronick
  • 505 Answers
SOURCE: Samsung Dlp HL-R7178w not turning On.
If all 3 leds blink, it can be the lamp, ballast (lamp driver), color wheel, or dmd board (all are engine parts = engine failur). its usually the lamp, but you can listen to troubleshoot. when it turns on, you will hear the fans come up (humm..airflow noise), then you will hear the colorwheel (high pitched squeel.. it will come up to speed) and then the ballast will fire up the lamp.. if the lamp doesn't fire, you will hear the spark gap fire (a 1 second buzz noise indicating bad lamp).. the gap will fire 3 times, they tv will then retry again and again until it shuts off and kicks out the error. this power up path will help you listen to find your problem. i can assist further.
Posted on Jan 08, 2009
  • 185 Answers
SOURCE: samsung hl-r5078w no picturead has a buzzing sound
that buzzing sound is likely the power supply letting you know it is overloaded. check the output voltages for 1 that is missing or low, it probibly has a shorted component on it.
Posted on Feb 20, 2009
  • 6 Answers
SOURCE: I have a vertical dark area on the left side of my
Defective DIGITAL BOARD.
Posted on Dec 30, 2009
Tip
Rear projection TV displays a shadow on one corner or side of the screen.
Hi.
This tip may be helpful only if your rear projection TV is displaying a darker shadow on one portion of the screen. If the shadow shape and size will not vary, that means that there is probably a detached mirror in the device called Light Tunnel, located inside your TV.
Most rear projection TV works projecting the light from the internal lamp on the screen. Before reaching the screen , the light will pass through a 'pipe' whose internal surface is covered in rectangular mirrors, located all over the tunnel surface.
A quite common fault is caused by one of the mirror detaching from the the light tunnel internal surface , and falling down or hanging in there. This will be seen on the display as a darker shade located near to one side of the screen.
The light tunnel is located in the light engine. To repair the problem the TV must be disassembled by a technician. Accessing and disassembling the light engine is not a repair that can be done by the owner.
Click here to view pictures of a light engine for a Samsung rear projection model. The tunnel is the optical device located in the light engine.
If you are a technician, to replace the light tunnel you will have to take apart the light engine, that apart of being quite a sensitive optical device, is also the most expensive part on a rear projection TV.
In that case you may find useful the service bulletin posted below, that is illustrating how to replace the light tunnel on a light engine for Samsung rear projection TV. Please be aware, that if you attempt doing this operation without sufficient knowledge and experience, you may damage your TV set beyond repair, as the light engine is very expensive.
How to replace light tunnel on a Samsung rear projection:SERVICE BULLETIN
The file is on PDF format.
Regards.
Ginko.
on Feb 05, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Help please. Samsung DLP no picture just audio
Hi,Is your tv close to 6000-8000 hrs 2-4 yrs.If its it might be time to replace the lamp.Your part # is XL2200 Make sure you get the Philips lamp.There's other components that tend to go bad like the ballast which is the board that powers the lamp.When that is bad it will make continuous clicking noises or attempts to light up the lamp.But if you dont hear any of that then most likely its just the lamp that needs to be replaced.Have a blessed one!
Mar 01, 2010 | Samsung HL-R5078W 50" HDTV
Light engine/light tunnel replacement instructions
Dec 31, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Color wheel replacement.
Here is photo step by step replacement of color wheel.
http://guides.fixyourdlp.com/samsung/bp96-01579a.php
Hope this helps
Oct 05, 2008 | Samsung HL-R5078W 50" HDTV
PICTURE SHADOW
Search for "Light Tunnel".
Feb 05, 2008 | Samsung HL-R5078W 50" HDTV
Lower left quadrant has shadow
By knocking into the tv you have shifted the light tunnel in the light engine. The repair for this is to replace the light engine the part number is BP96-01198B you can order it from Samsung parts.com The cost for the part is 985 dollars but if you return the one the repair man takes out you get a core credit of 350 making the light engine only 630 dollars or so...You should be able to find a repair shop to put this in for labor of less than 300 maybe even 250...our shop does a Samsung for 190 Labor. Hope this helps.
Feb 04, 2008 | Samsung HL-R5078W 50" HDTV
Brightness
Try cleaning mirror with a Lint free cloth with no other cleaning solution just dry lint free cloth. You should have Two access holes that you can pop out to get to mirror. Of course it will not be real easy to get to mirror if you do not have long arms but I have done it many times. Mirror sometimes get fogged causing poor reflection of mirror. This may help.
Jan 20, 2008 | Samsung HL-R5078W 50" HDTV
Dlp problem
The unit has a defective light tunnel contained within the light engine. This part is not easily replaced and you will a qualified tech to replace it. Many service centers condemn the light engine at a much hight cost. Do not buy or let someone tell you the light engine must be replaced. This repair requires only the light tunnel.
Nov 22, 2007 | Samsung HL-R5078W 50" HDTV
Replacing light tunnel (instructions)
Jul 09, 2007 | Samsung HL-R5678W 56" Television
Samsung HL-R5678W 56" Television Logo
208 people viewed this question
cce772000
Level 1 Expert
